Old 05-19-2007, 01:48 PM   #81 (permalink)
gomba
Endless Turbo Preparation
Originally Posted by thinnertenor View Post
i dont see any listing of the U12/U13 (Bluebird, i think) motors.....
are they just the same as the Avenirs?
thats what i would assume, just double checking
Anyone got an answer to this?
'95 200sx SER - Loading Turbo.exe |!!!!.................| 22%
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever” - Chinese Proverb
gomba is offline   Reply With Quote
Old 05-19-2007, 09:41 PM   #82 (permalink)
TeKKiE
work in progress...
Trader Rating: 26 (100%)
IIRC, they are the same. U12/W10 share and U13/W11 share. Or, it could be, that all four are the same. I don't remember which...
SR20DEEP in TX
Old 06-16-2007, 06:10 AM   #83 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Okay, so what about the N60 MAF? Miko?
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 06-16-2007, 06:11 AM   #84 (permalink)
SENTRASER
SENTRASER's Avatar
I think the W10, U13 and U12 all use the 91-4 SE-R MAF, and the W11 uses the 54C01 MAF, which is almost identical to the 54C00 MAF. I could be slightly wrong FWIW
Old 06-16-2007, 12:15 PM   #85 (permalink)
bobbyisking
KASSANOVA!!!
Trader Rating: 37 (100%)
n60 maf is the maxima maf, i think so... n62 is z32, if i got that right...
92 Dark Gray Sentra SER
92 Red Sentra SER
Old 06-17-2007, 09:08 AM   #86 (permalink)
SENTRASER
SENTRASER's Avatar
Yes, you are correct. I would like to know the WHP output.
Old 08-15-2007, 01:37 PM   #87 (permalink)
nsusammyeb
officially a boost addict
so after reading all of this popcorn jumping all over the place stuff, which would be a better maf for a stock turbo with boost control, 370 injectors, and stock internals. Say I'm running about 14 lbs boost, and injectors at 4 bar...which by the way i'm still not sure exactly how that works. Lightning MAF a little overkill? or does it matter really? Just cause it's bigger doesn't mean that it will take in more air, right, that's all ecu related anyways. Just if you want the option to bring more air in you can right?
'96 se-r bluebird swap.
It's a WIP, work in progress. Exhaust and paint coming soon.
T25's feel too small real quick don't they??
nsusammyeb is offline   Reply With Quote
Old 08-15-2007, 02:42 PM   #88 (permalink)
SENTRASER
SENTRASER's Avatar
Wowee. If you need a bigger MAF a smaller one sure isn't going to cut it. You just need to get an appropriate MAF for the power levals you're shooting for, it doesn't hurt anything to have a MAF thats TOO BIG, where as if one is TOO SMALL you will max it out.
Old 08-22-2007, 11:42 AM   #89 (permalink)
geeio
needs to be tuned
geeio's Avatar
i have a hitachi maf the part number is afh70-16a im not sure where this maf comes from. its not a maxima maf is it ? is it the xterra ?
looks like its got a bad sun burn.
geeio is offline   Reply With Quote
Old 09-19-2007, 01:36 AM   #90 (permalink)
UNISA JECS
Part# 22680-79E00
U12 - 89/10 - thru
Part# 22680-54C00
U13 - 91/09 - 95/01
Part# 22680-54C01
U13 - 95/01 - thru
W10 - 95/08 - thru
W11 - 98/8 - 00/05
W11 - 00/05 - thru
UNISA JECS is offline   Reply With Quote
Old 10-06-2007, 09:05 PM   #91 (permalink)
dcrb13
i just did a sr20det swap into my 91 b13 and i want to swap over my stock maf to a maxima n60 maf. but on my stock maf harness there is only 3 wires but on the n60 maf it has 5 wires so i dont know how to do it. is there anyone who knows how to rewire it, thank you
dcrb13 is offline   Reply With Quote
Old 10-11-2007, 09:29 AM   #92 (permalink)
gre
Almera Turbo owner
and n15 GTi ?? almera?
gre is offline   Reply With Quote
Old 10-30-2007, 12:44 AM   #93 (permalink)
200sxse-r
Southern Boy!
my avenir maf went bad i need a maf that will work without any tuning that is also fairly readily available to me.. i.e. and mafs that go into a 240 would be good.. like s13/s14 sr, or sohc/dohc/s14 ka mafs..
91 G20 Avenir Swap
200sxse-r is offline   Reply With Quote
Old 10-30-2007, 02:55 AM   #94 (permalink)
91p10
false ......
gti-r parts fs
http://www.sr20forum.com/miscellaneo...-parts-fs.html
91p10 is offline   Reply With Quote
Old 10-30-2007, 08:05 PM   #95 (permalink)
200sxse-r
Southern Boy!
well if your using a det ecu (BB or avenir) the s13 sr maf will work and a single cam 240 maf works just fine too..
Old 01-13-2008, 09:13 AM   #96 (permalink)
gt auto
Originally Posted by Will View Post
ummm, you motor leans out. If it goes too far it will of course cause serious damage.
what if you use a greddy e manage to take up where the a/f m max out
gt auto is offline   Reply With Quote
Old 07-08-2008, 10:15 AM   #97 (permalink)
Walker
can the 54c00 be bored beyond 54mm
Walker is offline   Reply With Quote
You may not
