How To: Recover Door Panels - SR20 Forum
Old 03-25-2006, 12:45 AM   #1 (permalink)
I Keep It Unique
Feedback Score: 25 reviews
I did this write up based on the NX Door Panel but it is the exact same concept. Both the NX and the Sentra share the common PITA one piece door design so recovering the cloth inserts isnt exactly easy because you have to tuck in the edges. I on the other hand have found a way to recover them pretty easy. With a bit of patience and time anyone can do this I mean anyone. I have no upholstry experience what so ever but I think I can give myself a pat on the back for this one.
What you need:
1. 1 Yard of the material you wish to recover the door panel insert with, the more stretchable the material is the easier to work with. ( I used black Ultrasuede)
2. Spray adhesive, the stickiest sh*t you can get, I used 3M High Strength 90.
3. Razor Blade
4. Putty or Dry Wall Knife
5. Sandpaper 100 Grit
6. Vibrating Sander
7. Blue Painters Masking Tape
Not to get rid of that old dirty peeled up cloth insert.
Step 1:
Remove The Door Panel From The Vehicle:
Remove all other plastic parts like the door handle and such.
(Ignore the red spots and the roughly cut hole, I did a manual to power window conversion)
Step 2:
Peel The Old Cloth Off:
Step 3:
Sand The Door Panel Smooth.
When you remove the old cloth you will notice it left behind a spongy\glue residue. You need to sand the surface smooth, if you dont this will cause your new material not to stick very well and eventually lift. How well your material sticks depends on how well the surface it is to be mounted to is prepared. Thats the key rule here. Be sure to get it cleaned very well in the corners those are most important.
Step 6:
Tape Off The Area To Be Covered.
I used blue painters masking tape, so there is no residue left behind when you peel it back off. You want to cover the outside outer lip as best as possible.
Step 5:
Prepare Your Material.
Take you yard of material and cut it in half put one half aside for the other panel.
Step 6:
Start Mounting The Material.
Decide on a starting point and spray a small area of the panel with the spray adhesive. Put the material on it and smooth\stretch all the wrinkles out.
Continue till the whole portion is covered one small area at a time. Do not rush this it is a process that takes time and you might have to peel areas back up and restretch them several times before you get it right, but you will eventually get it.
Step 7:
Tuck In The Edges.
This is much easier than it looks. Once you have the material stretched and completely smooth and mounted, it time to tuck in the edges what you want to do is spray a good amount of adhesive all down in the groove all the way around the section to be recovered. With the putty or dry wall knife, tuck in the access cloth all the way around.
Should look like this when it is finished. Let the adhesive dry before continuing.
Step 8:
Cut Away The Access Cloth.
Once the adhesive has dried, take your razor blade and score the grove all the way around the newly recovered part and pull the access cloth away. Make sure you score the are well so you dont accidently pull the cloth out of the groove. Peel off the blue painters masking tape and you panel is finished, it will look something like this:
Put all the plastic parts back on remount the door panel and your doors look good as new or even better!
Now Metal Fabricating, Welding And Powder Coating. PM Me With Your Needs!
sinistersntra91 is offline   Reply With Quote
Old 03-25-2006, 02:11 PM   #2 (permalink)
!!!!CAUTION!!!!
blurr.rt.by.you's Avatar
Feedback Score: 69 reviews
sweet it looks like my roof liner. i definately need to do write up like this. where did u get the material from?
***GARAGE SALE***
http://www.sr20forum.com/mechanical-oem-part-outs/215172-garage-clean-up-sale.html
http://www.sr20forum.com/mechanical-oem-part-outs/217115-more-stuff-sale.html
blurr.rt.by.you is offline   Reply With Quote
Old 03-25-2006, 02:50 PM   #3 (permalink)
I Keep It Unique
www.denverfabrics.com
Old 03-31-2006, 08:03 PM   #4 (permalink)
The Genesis
Feedback Score: 12 reviews
looks good!
Dork!
Old 03-31-2006, 08:18 PM   #5 (permalink)
Technician @ Toyota
scortch99th's Avatar
Feedback Score: 45 reviews
nicest headliner ive seen, def do a write up....
nice door inserts
91 classic SE-R (sold)
94 classic LE (falling apart beater)
91 240sx(rps13) (sold)
95 P10 Primera (current daily)
COMPRESSED CLIQ
Originally Posted by STRATTON
freddie your a SICK man.
stratton.
Originally Posted by chriscar
Maximum horsepower is dictated by your wallet.
Old 03-31-2006, 08:22 PM   #6 (permalink)
Canyon_Boogie
Feedback Score: 58 reviews
Man I need to do that. Just need the motivation
Be polite, be professional, have a plan to kill everyone you meet.
~KnuckleDuster~ is offline   Reply With Quote
Old 03-31-2006, 08:24 PM   #7 (permalink)
Technician @ Toyota
rub some oil in the ones you got now...
Old 03-31-2006, 08:29 PM   #8 (permalink)
Canyon_Boogie
lol well there already all frayed and nasty.
Old 03-31-2006, 08:51 PM   #9 (permalink)
I Keep It Unique
Thanks guys Im going to redo the ones on my Sentra next
Old 03-31-2006, 09:33 PM   #10 (permalink)
The Genesis
i did this on my b14 and it was easy because theyre flat pieces...i did the headliner on my b13 and its easy but time consuming and tedious
Old 04-22-2006, 01:37 AM   #11 (permalink)
Master Cunnilingust
Feedback Score: 37 reviews
3M 8080 is a good spray adhesive as well.
- Rob
Old 04-22-2006, 12:07 PM   #12 (permalink)
I Keep It Unique
Yeah take my advice and make sure you get alot of adhesive in the various corners of the pieces, I noticed mine started lifting so now I have to do it over again. The other one is fine though.
Old 04-23-2006, 01:26 AM   #13 (permalink)
The SE-R Sitter
Ha yes, I remember I use to Repair and replace Car and bus seats using Hog rings and stapels.. Pretty easy.. Nice write up.
http://www.s r 2 0-f o r u m.com/
For those looking for a new home.
SE R Madness is offline   Reply With Quote
Old 04-23-2006, 12:57 PM   #14 (permalink)
Any good ideas on where to find perforated leather (faux or real).
I would love to redo my NX doorpanels in that material in black, and then get the matching shift boot from redlinegoods.com
1993 NX2000.
Going through the JDM swap right now, with the help of some friends. EvilSR20DEgg is the man.
More plans for the future.
EssDubNX2k is offline   Reply With Quote
Old 04-23-2006, 01:09 PM   #15 (permalink)
newbie
Pretty White's Avatar
Feedback Score: 4 reviews
FAUX leather is much better, it is more durable. Also it is standard in most BMW's and Mercedes!
One thing, I was always told from upholsterers that I should leave the factory material under it to make it stick better, but i do agree, the foam must GO!
Originally Posted by sonny
Old 04-23-2006, 03:00 PM   #16 (permalink)
hmm....
Why does the factory material make it stick better?
I would think the carpeting would be a pain to stick to.
I was think faux anyways, because of the price, but I just want to find some that is perforated, so I can get the matching shift boot and have a theme.
Old 08-18-2006, 11:01 AM   #17 (permalink)
SR20DEbT
Feedback Score: 62 reviews
Does anyone have pictures of their door panels in a leather/vinyl. I bought some vinyl that looks like leather to match my G20T seats. It came out pretty good for my first time but around the door handle it is a little wrinkly. I also screwed up when cutting the edge. Cut a little crooked and took little bits of the material from what I wanted stick to the panel. Pics please of whoever did the leather or vinyl changeover.
-Bes
92 Sentra 9K ALL DAY. VE
----BNB----
Old 08-18-2006, 09:34 PM   #18 (permalink)
newbie
Old 08-18-2006, 11:20 PM   #19 (permalink)
SR20DEbT
^Wow bro, that looks 100 times better than mine. Mine is all wrinkled by the door handle. I guess I messed up because I did it all at one shot and everything started to dry up on me, lol.
Old 08-19-2006, 12:36 PM   #20 (permalink)
.i love my NX.
Feedback Score: 20 reviews
pretty white that vinyl looks good..
.we are all just a clever metaphor to personify the meaning of thought.
.MuNkey. is offline   Reply With Quote
HTML code is On
