HOW TO: Custom gauge pod - SR20 Forum
Old 05-03-2006, 12:05 AM   #1 (permalink)
Beware....THE BEAR!!
budsang1's Avatar
Feedback Score: 36 reviews
Items needed:
Fiberglass resin, a small can will do.
A few quart size mixing cups
A handful of cheapo throw away 1" brushes
Acetone for cleanup...fiberglass resin is nasy stuff
A box of cheap gloves helps too, you'll find everything getting stuck to your hands, it's easier to just pull off gloves and put on another pair
Wooden dowel, small diameter
Wood to make the rings to hold the gauges
Blue painters tape, plain masking tape will work, but the blue stuff makes for easier removal.
Fiberglass mat or cloth, i prefer cloth
Bondo
spray paint
Some sort of cloth
Sandpaper
I started with this.
Poor fitment...and way too flashy for my tastes. And it's a lotek, not sure why it didn't fit, i think i got sent the wrong one, but lotek was shady and claimed they had no record of my order at all, and I know i got it directly from their site, anyways. I decided i wanted to make a custom gauge pod that sat ontop of the steering column.
To start out you want to cover everything you don't want resin on, especially where you will be putting fiberglass.
I used tinfoil to rap my levers for my wipers and lights.
Next you want to start laying the glass. Mix the resin and the hardener about 6 oz at a time, otherwise it'll start hardening before you can use it all. Also, cut small strips of the fiberglass about 2x4" or so. I like to paint the resin onto the taped area first so the glass will stick to it better. Then paint or dab resin on the top of it, until it's all soaked up.
You'll need to do about 3-4 layers of glass all at once for this first time, then let it harden up. Once it's hardened you can pull out the mold you have just made.
A dremel will come in handy on this next step. Once you have the mold out you'll want to trim the edges.
Do some test fitting back in the car to make sure you can still use all the levers ok, and turn the steering wheel.
Now you'll want to cut out the rings you'll need...as you can see this took me a few tries, lol. My wood was a little too thin and flimsy, but i made it work. I used a hole saw for this. You'll then position the rings where you want them and cut the dowel in pieces to support the rings. I used a quick set epoxy to do this, you have to make sure the dowels won't interfere with the gauges when put in place.
Once thing to keep in mind, something i didn't keep in mind, which costs me later. Make sure that you keep in mind that when finished it'll be a bit thicker, plus the gauges will stick out a bit. put in the gauges at this step and put it back in the car, make sure they have atleast 1/8" if not 1/4" between the outermost gauge and the back of the steering wheel. I didn't do this and when I put the gauges in at the end I couldn't turn the steering wheel
I put it in to check for clearance, but didn't try turning the wheel...stupid me.
Now you'll want to cover what you've made. I just cut up a old t-shirt. Any fabric will work, nothing too thick and it needs to have a little stretch to it. you'll want to start with the rings, i use spray adhesive for this, it works really well. Spray the wood rings, wait a minute for it to get tacky, then stretch the fabric over. Do the same to attach the fabric around the edges. Pull it tight and glue it down, cut off all the excess you can...building up thickness on the bottom is bad.
Next you'll want to glass it again, follow the same procedure that was outlined before, to make the mold. You'll want to do a few layers so it's decently strong.
Oh, you can see some cardboard underneath the glass. I did this before I covered it with the cloth. I put a gauge in each one then eyeballed and cut out a thin piece of cardboard to keep the cloth up, so I would have clearance for the gauges, I just used more eboxy to attach the cardboard to the rings.
I used the dremel to clean it up a bit on the edges and to clean up inside the rings, then test for fitment again.
Next you are ready for the bondo and lots of sanding.
Follow the directions on the bondo for mixing. You can only do a little bit at a time because it hardens very fast. I put on some latex gloves and just used my hands to smear on the first coat, let it dry and then give it a good sanding.
You'll want to continue this step until you get it just how you like it...coat, sand, coat, sand, coat, sand...i did this many times...once you get towards the end of this a cheap putty knife helps to fill a smooth the small imperfections.
After a few of those coat and sands, it'll look like this.
1998 Sentra SE-->Sold
2004 Jaguar XJR: 13.5 @ 101-->Sold
2003 Infiniti M45
budsang1 is offline   Reply With Quote
Old 05-09-2006, 09:09 PM   #2 (permalink)
budsang1's Avatar
Once you have it just right you'll be ready to paint. Clean it up, hang it up and break out the rattle can. I sanded between coats and did 3 or 4.
This is about where i realized my mistake...with gauges in, i coudn't turn the steering wheel. So, I had to remove the plastic trim around the gauge cluster and trim it so I could slide the custom pod back further.
Once you are finished, you'll need to cut a spot to run all the wires and tubing. I used more super strength epoxy to attach it to the steering column, it's just glued to the black plastic top column piece. I figure if I remove it i'll just pick up another piece from the junk yard. Now you can sit back and marvel at what you just created from scratch. I was super happy how this turned out. It looks much, much better than what I had before.
It doesn't really cover up the cluster as much as it looks like it does in that picture. You can see the cluster just fine.
Old 05-09-2006, 09:24 PM   #3 (permalink)
budsang1's Avatar
Here are a couple more pics.
More of a ride height...you can see it doesn't interfere quite so much as the previous pic made it look.
And a pic from the side.
Old 05-09-2006, 10:26 PM   #4 (permalink)
Feedback Score: 15 reviews
hey make me one just like that.. i need something like that 2
FoolishWayz33 is offline   Reply With Quote
Old 05-10-2006, 12:50 AM   #5 (permalink)
agent camel toe
Feedback Score: 22 reviews
nice brainstorming their...great work and the pics are great
nyce1s.com
R.I.P. RESPECT SR.
96 b14 det--under the knife
2002 quest gxe--pimp wagon
Old 05-14-2006, 06:03 PM   #6 (permalink)
_scott
CivicsSuck's Avatar
Feedback Score: 9 reviews
Sweet, looked like sh*t until the very end, nice job!
13.29 - 108 mph
226whp 225trq
My Avenir Project:
http://www.sr20forum.com/members-rides/157517-avenir-section-402-a.html
06 Frontier, Nismo package
http://memimage.cardomain.net/member...51_26_full.jpg
06 Honda 450R, few goodies
http://memimage.cardomain.net/member...51_27_full.jpg
CivicsSuck is offline   Reply With Quote
Old 06-08-2006, 03:07 PM   #7 (permalink)
1.6->sr20de-t
Feedback Score: 26 reviews
nice work! couldnt you have just used fiberglass resin though?
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers...
99 G20T, black on black, only 1000 miles, 5 spd- daily driver
OneSlow1.6 is offline   Reply With Quote
Old 06-08-2006, 03:21 PM   #8 (permalink)
XxToKeSxX's Avatar
Feedback Score: 44 reviews
Man... that is so innovative. Epitome of the word custom... Good Stuff
Lastly, I was going to ask for your approximate cost for this project...
Peace,
Shift_Buy Broken & Build...
Old 06-08-2006, 09:14 PM   #9 (permalink)
wes
713 ways to be a dick!
Feedback Score: 30 reviews
I have made many projects like this. Nice work overall. Next time just use the plastic column piece as the bottom and attach your baffles for the gauges to that. In fact you could trim the platic panel down to lower the gauges to take up less space overall. The other benefit of this is that you can wrap your cloth to the underside of the factory panel and you would not be able to tell that you added a piece on.
Cool project!
MotoIQ
Old 06-09-2006, 12:23 PM   #10 (permalink)
budsang1's Avatar
I did use fiberglass resin
I didn't have alot of what I needed, such as the hole saws I used, so that brought my total up to about $70-$75, if you have those you could knock that figure down to about $40-$50.
I thought about that, but wanted to make it easily removable...then i just ended up gluing it down So it's still not easily removable. I do agree with you though, i think it would look better if it was wrapped seamlessly around the column. Maybe on the next car.
Thanks for all the nice comments, i was very happy with how it turned out...since the sub boxes i previously didn't turn out so nice.
Old 06-19-2006, 05:17 AM   #11 (permalink)
YOUR F0RUM SUX
Feedback Score: 14 reviews
got pics of the sub boxes?
Sentrixx is offline   Reply With Quote
Old 07-03-2006, 10:07 PM   #12 (permalink)
budsang1's Avatar
I thought i had pics, but turns out I don't have them anymore. Sorry. Have you started your gauge pod yet, sentrixx?
Old 07-04-2006, 05:11 AM   #13 (permalink)
YOUR F0RUM SUX
So far I have bought all the stuff. Other than that, I have not started. Its just to damn hot outside in Fla right now. Hopefully soon! I will keep you guys up to date for sure.
Old 09-15-2007, 02:58 PM   #14 (permalink)
YOUR F0RUM SUX
Ok! Finally on the move man. Got all the stuff and started work on it today. But other than the wood cut outs and the the cardboard cylinders you used, I went with 2" PVC.
I should have it mostly done by this weekend hopefully.
BTW.. Got all 3 gauges for $100 shipped from ebay sale. I got a A/F that I'm going ti use for now just to fill in the pod. But when I find a volt or something else for a good price I will swap it out.
Pics to follow soon!
Old 09-15-2007, 05:17 PM   #15 (permalink)
budsang1's Avatar
awesome man, def post pics up when you are finished
HTML code is On
