How to: Foglight switch mod - Page 4 - SR20 Forum
Old 08-12-2007, 12:39 PM   #61 (permalink)
Nissan Driven
so is that the right b14 right up then?
1993 Nissan Sentra E 199,671 miles. RIP.
1998 Nissan Sentra SE Cloud White project.
WhiteSE98 is offline   Reply With Quote
Old 05-27-2008, 08:30 PM   #62 (permalink)
the ONLY nx in PALATINE!!
Originally Posted by Toolapcfan View Post
I have pics for the '91-'92 but I need to figure it out for the later models since it can't be done at the lighting switch, it must be done in the engine compartment.
Here's the harness:
Here's the back of the harness, you can see the tap where the purple wire currently is and circled is the red/blue wire you need to tap into:
Here's another pic of the tap with the purple wire:
You remove the purple wire from the tap and tap it into the red/blue wire. It couldn't be simpler.
ok so i have no purple wire anywere near that plug.......how do i do this on my 91 nx?
http://i149.photobucket.com/albums/s...0405071813.jpg
http://i149.photobucket.com/albums/s...17071403-1.jpg
[Today 07:05 PM] Shawn B: Ten bucks is ten bucks. Signing your name "fu*k you"....priceless.
pedronx2k is offline   Reply With Quote
Old 04-15-2009, 07:42 PM   #63 (permalink)
BNB_SE-R
Feedback Score: 31 reviews
Anyone had this work for them? It didn't work for me, my headlights would stay on when I put the battery terminals on. I'd like to finish this up and put all the trimming back. Anyone got pics of how they did it?
91 SE-R
99 G20 KR4/black leather 97K miles FOR SALE
SE-Rious Dino is offline   Reply With Quote
Old 10-07-2009, 02:59 PM   #64 (permalink)
from the dea....still cant figure this on my 91........
Old 02-12-2010, 03:11 AM   #65 (permalink)
hey guys i just did this today, and lket me tell you it took me longer to take the trim offr than to do the actual mod. So theres no confusion i have a 92 se-r . I followed the instructions like it said let me clear this upfpr those that have a 91 92 . the purple wire is attached already to a blue/red wire what you'll wanna do is remove the splice tap from thr purple and blue/red wire.
there a thicker blue/red wire right next to it , thats the one youll want to splice into. i did it and it worked fine . only bad thing is my fogs flash when i put on my alarm
SE-Rgio
sergioqu is offline   Reply With Quote
Old 02-12-2010, 03:29 AM   #66 (permalink)
check this out! hope it helps
Old 04-04-2010, 04:02 PM   #67 (permalink)
cut the fat
Feedback Score: 9 reviews
I just did this as well.
Car is a 92 NX2000. I did not have the purple wire behind the steering wheel so I went with the relay method.
I found the red/yellow wire underneath the fog lamp relay and cut it an inch and half away from the relay. I used a crimp connector to cap off the other end of the red/yellow wire that is no longer in use.
I looked around in my garage for some spare wire and found an old aftermarket fog light wiring harness and cut a piece of 3 inch long wire off of it. I then stripped both ends.
I found a brown wire underneath the fuel pump relay (if your fuse box cover is illegible, the fuel pump relay is the 3rd relay from the left, it is also green). There are 2 brown wires coming out of the relay. One loops from one terminal on the fuel pump relay to an adjacent terminal on the same relay. I did not use that one. I used the brown wire that was part of the main harness leading out of the fuse box. I stripped a section of insulation out of the middle of the brown wire and soldered the spare wire I previously found in my garage to it (at first I just wrapped the wire around the stripped section and taped it, this worked as well). I then soldered the other end of the spare wire to the red/yellow wire sticking out of the fog lamp relay. Taped everything up and I'm done.
Fog lights came on as soon as I heard my fuel pump kick in. Fog lights now work with no lights, parking lights, main beam and high beam.
*EDIT* I guess it wasn't dark enough when I first tested the lights. Today I found that my driver side head light main beam would not work yet the high beam did. Reconnecting the red/yellow wire at the relay fixed this problem but I was back to square one. In addition, when connected to the brown wire from the fuel pump relay, the car would not shut off with the head lights on. Power from the headlights was keeping the fuel pump going. I could pull the key out and the car would idle until I turned my headlights off. Funny but eerie at the same time.
So I'm stuck. I have no purple wire behind the steering wheel and the fuse box method did not work for me. I am unsure why cutting the red/yellow wire on the fog light fuse would affect the headlights. I'm thinking I did something wrong.
featherweight13 is offline   Reply With Quote
Old 04-05-2010, 07:30 AM   #68 (permalink)
born 4 boost live 4 ve
Feedback Score: 15 reviews
Just did this this last night.. Pics helped a ton
was 91 sr20ve-t classic
now 92 sr20ve classic
blackb13se-r is offline   Reply With Quote
Old 10-21-2010, 08:45 PM   #69 (permalink)
BNB_SE-R
My fogs don't want to turn on. I can hear the relay clicking and the fog light button will light up in the cockpit. The bulbs are new. My hid's are coming tomorrow and I would like to wrap all this up. Am i not supposed to tap it directly into the wire?
Old 10-23-2010, 06:00 PM   #70 (permalink)
BNB_SE-R
Anyone????
Old 01-06-2011, 03:39 PM   #71 (permalink)
SE-R ON DECK
Just did this mod last night! loving the new look haha!
96 200sx se-r minor mods
95 200sx se-r dead
ray7se-r is offline   Reply With Quote
HTML code is On
