How To: install a clutch pedal - SR20 Forum
Old 08-18-2006, 11:22 PM   #1 (permalink)
ga16*****.com
Feedback Score: 31 reviews
Please delete.
1997 200SX SE-R - 280whp & 264tq
"Shut the fu*k up and sit down"
Old 10-05-2006, 01:31 AM   #2 (permalink)
the b14 is my girlfriend.
do you have pictures of the hole you drilled for the clutch cable?
do you use that pre-drilled hole as the top right hole (meaning you dont have to drill ANOTHER hole and you can just use the same hole for insertion)
so you pretty much only have to drill the bottom left insert hole, and the hole for the clutch cable, correct?
so i'm drilling a hole where the red is (pretty much) and the blue hole is already there??
Originally Posted by brooklyn nx View Post
1: Dont give up 2: You need to get a job that pays a little better 3:Get a girlirfriend who supports your cause. I got 2 cars that need help and no steady work but that dont stop me from getting a little done at a time,If you love your car and love what you do youl get through it.
rEf1eX 22 is offline   Reply With Quote
Old 10-05-2006, 01:35 AM   #3 (permalink)
fan boys suck!!!
Feedback Score: 27 reviews
reflex i told u already how to do this...you have to drill ALL THREE holes
expect on his top hole its off a lil and thats why his pedal(clutch) isnt even with the brake.......im gonna have to come buy and show u....u work tomorrow??if not give me a call i get off at 530 peace
HEY ALBERT PANZIE!!!! all i gotta say is....
15.135 @ 92.63mph and 15.318 @ 93.82mph...nuff said..no rhymes needed here to poet your a** haha
dJ gNO cYDZ.................. RIP DJ SPEEDY!!!!!!!!!!!!!!
gEE805 is offline   Reply With Quote
Old 10-05-2006, 10:55 AM   #4 (permalink)
sr20s are leet skeet
nissanboi's Avatar
Feedback Score: 7 reviews
no the blues one was already there from an alarm isnstall he says that
nissanboi is offline   Reply With Quote
Old 10-06-2006, 01:00 AM   #5 (permalink)
ga16*****.com
No, i dont have pics of the hole for the clutch cable, it took us about 8 hours to install this so i was pretty fustrated and didnt take alot of pics.
And, the "BLUE" one (as you have labeled above) was already there before the install, for a alarm.
You are drilling all three holes in the fire wall, and it should look something like this-
However that picture is NOT 100%, it is just a sketch... but it should look exactly like that.
Old 10-06-2006, 03:21 AM   #6 (permalink)
ok, i drilled it... fu*k this was a bi**h and a half... those were some messed up angles to drill from, i ended up unbolting all the stuff in the way. its strait and sits in place... but it looks like it sits deeper then the break pedal does,
is this normal???
i'll take pictures manana
Old 10-06-2006, 06:22 PM   #7 (permalink)
ga16*****.com
is this normal???
You need to break off the spacer that is tack welded to the fire wall off the manual car, i was just looking over my thread and seen that i didnt post that, i did however post it in "my swap progress" thread, sorry.
- you can also use washers to level out the pedal(s)
and yes, it sucks that is by far one of the hardest things of the intire swap.
This is what it looks like (the spacer plate)
Old 10-15-2006, 04:15 AM   #8 (permalink)
so i'm missin some sort of spacer thats on the manual cars?
Old 10-15-2006, 12:39 PM   #9 (permalink)
ga16*****.com
yeah pretty much, but like i said before, you can also use washers to bring the height back up to sit flush with the rest of the pedals
Old 10-22-2006, 03:13 PM   #10 (permalink)
okay, here is what i used.
some cardboard. haha
Old 10-25-2006, 03:15 PM   #11 (permalink)
ga16*****.com
how did that work, does it feel better or like a sponge when the pedal is being depressed?
Old 10-26-2006, 01:51 PM   #12 (permalink)
hi can u tell me where did u get engine harness to do the swap? see i have a 16 200sx auto and i and i also have a 92 sentra with a sr20det 5 speed that i need to put in the 95 200sx but some one told me that i need a 95-96 engine harness so am looking for one can u help?
hondaking96 is offline   Reply With Quote
Old 10-26-2006, 02:17 PM   #13 (permalink)
ga16*****.com
you can usually find them for sale on here Classifieds<--- Click
They are about 100-150$
And you have a PM.
HTML code is On
