HOW TO: B14: Fog Light Mod - Pic Heavy - SR20 Forum
Old 08-15-2007, 11:48 PM   #1 (permalink)
Feedback Score: 20 reviews
B14 Fog Light Mod
How to make your fog lights turn on with your corners.
Warning do this at your own risk!
I followed Bryant Woo Fog Light Mod writeup, and took pictures while I was doing it.
This was done for a 1999 Sentra SE-L, it should be very similar for all
Disconnect your battery before continuing to step one.
1. Find the Relay box and open it up, it should be located on the passenger side of the engine bay
2. Locate the Pink-Blue wire and try to pull it up so that you have some slack to work with
3. Cut the Pink-Blue wire, make sure you leave enough slack on both sides so that it will be easier to work with.
4. Strip the end of the wire that goes back to the relay so that it could be connected to another wire.
5. Seal the end of the wire that goes back into the batch of wires. I used heat shrink to seal the end of the wire.
6. To be safe get about a foot of 16 gauge wire and strip the ends on it and prepare to connect it to the pink-blue wire.
7. Solder the the one foot 16 gauge wire to the pink-blue wire (which goes back to the relay). Then heat shrink it or use electrical tape. I used both heat shrink and electrical tape.
8. I took the wire and stretched under all of other wires towards the passenger corner.
9. Remove the passenger side corner.
10. Take the Red-Blue wire out of the corner casing. Don't worry about the green-yellow wire or the black wire. The Green-Yellow wire is used to send power to the corner when your turn signal is on, the Black one is the ground. Also, The Red-Blue wire sends power when ever your parking lights are on
11. You can either cut or slice the Red wire. I cut the red wire, but then found out that its easier to just strip the wire casing off and leave the wire in one piece.
When I cut the wire, I didn't have enough to connect it back, so I had to add an extra piece of wire. This is why I suggest you strip the wire in the middle and connect the other wire to it.
Make sure you solder your connection and insulate it, in this case I just used heat shrink.
12. Connect the battery again and test out the the fog lights.
The fog lights now will turn on when you have your parking lights on. The fog lights are still fully functional and can still be switched on/off. Everything else should still be fully functional too.
If you have any suggestions or corrections please let me know
The Final Product
Old 08-17-2007, 12:34 AM   #2 (permalink)
agent camel toe
Feedback Score: 22 reviews
nice write up..ill do this mod in the am
nyce1s.com
R.I.P. RESPECT SR.
96 b14 det--under the knife
2002 quest gxe--pimp wagon
Old 08-17-2007, 12:58 AM   #3 (permalink)
ga16*****.com
Feedback Score: 31 reviews
I did mine with out cutting wires and with out pealing back any wires.
1997 200SX SE-R - 280whp & 264tq
"Shut the fu*k up and sit down"
Old 08-17-2007, 10:36 AM   #4 (permalink)
What did you do then?
Old 08-17-2007, 10:58 AM   #5 (permalink)
Cherry Destroyer
Feedback Score: 4 reviews
Now i have something to do lol thanks Russ
took me about 15min!
im so JDM i even sleep on the right side of my bed
95 B14/U13/safc2/FMIC/Nismo FPR/255 walbo/Turbo Xs BOV/n60 maf
MY95SER is offline   Reply With Quote
Old 08-17-2007, 12:58 PM   #6 (permalink)
My Money SavE-R
Thanks man, I might do this when I absolutelty nothing to do. Good write-up.
1998 200SEXY-R
ImTwoosxy is offline   Reply With Quote
Old 08-17-2007, 01:05 PM   #7 (permalink)
Yep pretty easy, pictures really help make it easier
Thanks man, good luck!
Old 08-18-2007, 02:07 AM   #8 (permalink)
Building my DE
Feedback Score: 16 reviews
I do that before but my passenger headlights turns on, Im going to try it again this week.
thanks for the pics.
srlucino is offline   Reply With Quote
Old 08-18-2007, 02:14 AM   #9 (permalink)
You must wire your 12" wire from the corners to the pink-blue wire that goes to the relay. If you wired the 12" wire to the pink-blue wire that goes back into the stack of wires then you wired your headlight to turn on with your corners... I did that at first too
Old 08-18-2007, 02:43 AM   #10 (permalink)
Building my DE
the only headlight that turn on was the passenger side????
I wire a cable to the whole pink cable. Sh*t , Im going to do it again today. haha.
thanks
Old 08-18-2007, 03:08 AM   #11 (permalink)
thanks
Yep thats it, you MUST cut the pink-blue wire. Insulate the end that goes to the batch of wires (which then goes to your headlight).
Old 08-22-2007, 05:20 PM   #12 (permalink)
YOUR F0RUM SUX
Feedback Score: 14 reviews
Here is something that I drew up awhile ago that might help out
Sentrixx is offline   Reply With Quote
Old 08-22-2007, 06:06 PM   #13 (permalink)
SR90VETT
Feedback Score: 3 reviews
cool paint skills
Originally Posted by Fragranttuna View Post
lol u blew up a tranny, so what do i all need to get a turbo in my car and up and running, about how long to install it? eyah how do i get to the classifieds, i think i was there once, but it didnt have a lot of turbo stuff there, and then i couldnt find the place to puchase the turbo kit i did see.
CLASSIC!!! HAHAHA
brackinassryan is offline   Reply With Quote
Old 08-23-2007, 12:41 AM   #14 (permalink)
Thats actually pretty sweet Wayne!
Old 08-23-2007, 05:29 AM   #15 (permalink)
YOUR F0RUM SUX
Thanx... I always try to simplify things for people. Esp for "text only" write ups. That's just annoys me.
Old 08-23-2007, 10:01 AM   #16 (permalink)
Agreed
Thats why I'm trying to do the picture write ups. Yes there is a text only fog light mod write up, there is also a text only JDM headlights write up, but it just makes it so much easier when you can see what the person is trying to tell you.
Old 04-05-2009, 01:32 AM   #17 (permalink)
my car dosent have the fog switch. but it hass all the wiring and harnesses. does this work to bypass the switch and have them be on or do I still gotta buy a switch.?
nock1 is offline   Reply With Quote
Old 04-06-2009, 08:45 AM   #18 (permalink)
Done.
Feedback Score: 27 reviews
Just bypass the switch by installing your own on the dash somewhere where your left knee would be.
SR20DEEP MD
12 Subaru Legacy 2.5i Premium
04 Subaru WRX 'goon
Cliff is offline   Reply With Quote
Old 04-06-2009, 02:13 PM   #19 (permalink)
What, I take the OEM fog wires out of the headlight turn signal switch and wire them to my own switch? What color are they?
Old 11-30-2012, 01:54 AM   #20 (permalink)
BUMP, I'd like to do this mod on my B14, any chance of the pictures up top being resurrected?
Yaaaaaah weeeeee vroom vroom!
JCheong04 is offline   Reply With Quote
HTML code is On
