How To: Disassemble B13 transmission - SR20 Forum
Old 08-22-2007, 11:43 PM   #1 (permalink)
The Genesis
Feedback Score: 12 reviews
I dont know if anyone has ever bothered with disassembling a B13 transmission. I know Coalition did a B15 trans, and its somewhat similar. I was "donated" a cracked transmission from fellow forum member Gee805 from when he cracked his trans at the line at the local dragstrip I had a spare tranny at my parents house with a blown LSD. So I took apart his transmission to steal his LSD and swap it into my otherwise good transmission. Disassembly is rather easy and should not take more than an hour to complete.
Tools needed:
10mm socket
12mm socket
snap ring pliers
a few flat head screwdrivers
First and foremost, we have the specimen..
Remove the top cover using a 10mm socket
Once the cover is removed, you will notice a snap ring that needs to be removed
pic from http://www.sr20forum.com/driveline-t...-type-lsd.html
We can now proceed to remove the 12mm bolts surrounding the bellhousing
The bellhousing is now ready to be separated, and this is what you will see. First thing, is to remove that rod that goes through the
Then remove the rod which holds the selector forks. It will pull right off, but be careful as there is a spring at the bottom that you dont want to lose.
Now, remove the gear selector mechanism held in place by three 10mm bolts
Next step is to remove the 3 bolt bracket located beneath the gear stack attached to the input shaft.
Once the three last bolts are removed, the gear stacks are ready to be removed simultaneously. Be careful with this because you dont want to damage any of the bearings and the rubber seal located on the bellhousing which seals the input shaft.
Now you will see this! The stock VLSD unit is just chillin there not attached to anything. Removing it is the easiest thing evar!!1!
This is the working LSD unit out of the cracked donor transmission that will be swapped over to my transmission.
Reassembly is pretty much the exact opposite of the disassembly.
This is a good thing for those of you who have a crap load of spare trannies laying around with miscellaneous problems. You can essentially build a good transmission out other busted ones. Its nice to have it as a spare just incase.
I know this write up isnt all that great, but i hope it somewhat helps anyone who is going to attempt to repair their own transmission
Dork!
Old 09-15-2007, 05:53 PM   #2 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
that goes thru the ????????
...Currently down due to a clutch disc spring failure....
Old 09-15-2007, 08:44 PM   #3 (permalink)
Im Not A Chick
Feedback Score: 5 reviews
i had the same question lol
B13 XE with sr20 swap(5 speed swapped)
B13 LE parts car
NX2K RIP (Aug 13 2007) parts car
NX2k soon to be parts car
NX2k my new baby!
NX PART OUT CHECK IT OUT!
http://www.sr20forum.com/mechanical-...-nx-parts.html
We are a community!
jen36 is offline   Reply With Quote
Old 09-16-2007, 01:19 AM   #4 (permalink)
The Genesis
gear selector forks
Old 09-16-2007, 01:28 AM   #5 (permalink)
Yea the B13 SR transmssion is quite easy to work with, i've done quite a few 5th gear fixes on them and I been able to drop the transmission take it apart repair the 5th gear pop out with new parts and reasemble the transmission within 2 hours and then let the RTV cure over night before putting GL-4 gear fluid back in it. Good lil write up.
UNISA JECS is offline   Reply With Quote
Old 11-13-2007, 01:42 PM   #6 (permalink)
Drivin the "Egg Crate"
Just to add to this great write-up, the gear stack that terminates under the top cover has the large snap ring underneath can need a little coaxing to let the snap ring seat back in its groove (particularly if you have the transmission sitting as in the photos; two possible solutions are to:
After bolting up the main body to the bellhousing and allowing the RTV to set up, turn the transmission on it's side, on a slight incline, to allow the stack to slide to the front cover, then pop the snap ring in; or
Use a CAREFULLY wrapped flat blade screwdriver to lift the stack via the bearing to allow the snap ring to seat.
Thanks to the author for taking the time to get the info and pics out there!
Darrin
SkyShepherd is offline   Reply With Quote
Old 11-13-2007, 02:16 PM   #7 (permalink)
XxToKeSxX's Avatar
Feedback Score: 44 reviews
Awesome!!!!! Golf Claps Sir!!!!!
Shift_Buy Broken & Build...
Old 11-13-2007, 02:47 PM   #8 (permalink)
Feedback Score: 52 reviews
this might be handy to know down the road
Later, Jay
10 Sentra SR - dd/work car
93 NX2000 - weekend ride
jingjing está en línea   Reply With Quote
Old 11-19-2007, 02:14 AM   #9 (permalink)
DBA/IT
Feedback Score: 22 reviews
thanks for the writeup man, good to know those gear stacks pull out so easily on the b13. i need to remove the cable speed sensor on my spare tranny so I can put my electric speedo in place of it. I'm thinking once the final drive assembly is out, the cable speed sensor should come out easily, since the speedo drive gear is on that assembly. I may addend that info to your writeup, or make another writeup for those interested in swapping speed sensors.
http://www.rollyourcar.com
Old 12-06-2007, 03:39 PM   #10 (permalink)
DBA/IT
well it turns out there is no real need for a writeup for swapping speed sensors. If you cannot pull the speed sensors out with a vice grips, then you need to disassemble the transmission to get them out. Just follow the above instructions, then after the final drive assembly is out, the speed sensor will be in plain view. I used a long piece of metal and a 6lb. drill hammer to tap them out from the inside (this was necessary with both trannys that i had, the speed sensors were just in too tight).
Old 02-10-2008, 11:48 PM   #11 (permalink)
transmission case...
do u still have the transmission case??? if u still have it, would you sell it to me??? contact me at (443) 763-1560. Eddi...
edumbero is offline   Reply With Quote
Old 02-28-2008, 02:09 PM   #12 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Feedback Score: 34 reviews
what about setting gear end play?
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 03-07-2008, 09:54 AM   #13 (permalink)
Feedback Score: 9 reviews
Don't forget!!!!
Put RTV around the edges for a seal.
ScottNotBombs is offline   Reply With Quote
Old 03-20-2008, 07:11 PM   #14 (permalink)
I drive a race car again!
Feedback Score: 3 reviews
Note - on the fourth picture down (above), it's the large snap ring that goes around the inside edge of the case (down in the groove), not the smaller (but easily visible) snap ring that sits on top of the mainshaft rear bearing that needs to be removed before the case will come off.
Steve Linn | Fins Up Racing | #6 ITA Sentra SE-R | www.indyscca.org
138,557 miles of bent-up motor, 50K of the new stuff
Racerlinn is offline   Reply With Quote
Old 05-18-2008, 08:55 PM   #15 (permalink)
Parting out my car
Feedback Score: 25 reviews
What do you do if the case doesn;t want to pull back off the bellhousing? Mine is stuck on, seems like the old RTV is holding it on..
Slow is the new fast
Old 05-19-2008, 08:05 AM   #16 (permalink)
Rubber mallet - careful tapping.
Old 05-19-2008, 08:56 PM   #17 (permalink)
Parting out my car
Did that but used a piece of thin sheetmetal to work my way around teh edges to cut through all the rtv first. Slow and easy got it done.
Old 05-20-2008, 10:06 PM   #18 (permalink)
Proud Italian
Feedback Score: 10 reviews
any chance we can get new pics?
91 SE-R. R.I.P old freind
91 part 2
"Dream as if you live forever, live as if you die today." -James Dean
And, I don't mind at all being looked down upon by purists. Indeed I don't mind at all being looked down upon by those whom I do not look up to at all. -
b13magoo is offline   Reply With Quote
Old 06-14-2008, 11:54 PM   #19 (permalink)
'93 drifting Egg
Please repost pics. I am in the process of redoing the 5th gear pop out with the service kit from Courtesy Parts.
1986 300ZX Turbo with 90k miles
1994.5 B13 Sentra Limited Edition, mint daily
NissanEgg is offline   Reply With Quote
Old 07-04-2008, 01:08 AM   #20 (permalink)
The Genesis
Sorry guys, pics were hosted on a friends photobucket account and he changed the folders on me. I relinked them
Feel free to PM or post here with questions you might have.. I have disassembled and rebuilt 3 or 4 transmissions by now so im pretty good at it i guess!
HTML code is On
