HOW TO: remove old rubber engine mounts - SR20 Forum
Old 09-02-2007, 10:09 PM   #1 (permalink)
wants 2 dry hump chriscar
Feedback Score: 8 reviews
i have never seen a how to on prothains so here is mine. i have done no less than 6 prothain installs and never got the idea to do a write up.......i didnt have any prothains this time but jen36 was selling his old mounts to another forum member and i decided to remove the old rubber to make it easier....i also sand blasted and painted so i took pics of how i did this useing only 3 basic hand tools........i didnt cheat and use any of the hydro presses at jen36's shop
this is how you start out. BFH, 2 chissels, and your old mount.
you need 2 differant types of chissels. one normal style and a wedged shape chissel.
take the normal style chissel and place it between the mount and the metal ring and pound away
now take the wedged chissel and go to town. this will releave the tension holding the metal sleeve and rubber mount in.
it will look like this when down with both steps
my method takes less than 5 minutes per mount. burning the mount out does nothing but make the mount to hot to handel....and you still need to remove that metal sleeve after. after your done with the wedged chissel you can literaly tap the rubber and sleeve out with the handel of a screw driver.
now i cant say i have ever installed the prothain inserts without useing a hydro press. but id imagine that putting some grease inside the mount then lowering a car on top of it will do the same thing as a press.
edit: adding terms to aid in searching. prothain how to, install prothains, replace engine mounts. install prothane, prothane, replace prothane.
Old 09-02-2007, 10:14 PM   #2 (permalink)
Pursuit of happiness
Feedback Score: 5 reviews
I concur, I have done the exact same method, with my own. Great post with no smokey fumes.
Ed
pathfinder7 is offline   Reply With Quote
Old 09-02-2007, 10:15 PM   #3 (permalink)
vvl se-r
Feedback Score: 9 reviews
Great write-up!
All motor sr20ve
nos91 is offline   Reply With Quote
Old 09-02-2007, 10:17 PM   #4 (permalink)
GNet Vet/B13 Noob.
Fantastic!
My CAI Install
My Feedback
60% of t3h time it works everytime...
davew7 is offline   Reply With Quote
Old 09-02-2007, 10:21 PM   #5 (permalink)
working on it
swiss's Avatar
Feedback Score: 27 reviews
Wow, I never realized you could do that with the rubber intact.
Old 09-02-2007, 10:24 PM   #6 (permalink)
i need to get a picture of the hydro press room.............it looks like sr20 mount death yard. there are remains of engine mounts all over the place lol
Old 09-02-2007, 10:56 PM   #7 (permalink)
AWD owns me
Jaketips42's Avatar
Feedback Score: 12 reviews
I do the same thing but with an air hammer. Easy stuff man.
Sporting the GC awaiting EJ20T
____________________________________GC Pilot
Subaru stole me from Nissan
Old 09-02-2007, 11:36 PM   #8 (permalink)
Turd Furgeson
Benito Malito's Avatar
Feedback Score: 41 reviews
You also don't have to let off toxic fumes into the atmosphere. Nice.
1992 SuperBlack VVL SE-R
1994 P10 KL0
2004 Forester XT SGM
Old 09-03-2007, 06:30 AM   #9 (permalink)
YOUR F0RUM SUX
Feedback Score: 14 reviews
Just note to be careful on the passenger side mount. The metal is different and can crack easily. I had done this on 2 mounts before they cracked. Its was cut out on the 3rd.
None the less a good idea. Surprised someone didn't do a write up on this before.
Sentrixx is offline   Reply With Quote
Old 09-03-2007, 06:34 AM   #10 (permalink)
L337 VVL
I've installed a few sets! a simple bench vice can press the mounts in easily if you grease them! A tip is to remove the brass sleve in them! then put the sleve back in.
The removal method is what i did but i also used a bench vice to hold the mount!
Neo forums wants you!:thumbsup:
www.neovvl.org
turbofied is offline   Reply With Quote
Old 09-03-2007, 06:36 AM   #11 (permalink)
YOUR F0RUM SUX
Originally Posted by turbofied View Post
I've installed a few sets! a simple bench vice can press the mounts in easily if you grease them! The removal method is what i did but i also used a bench vice to hold the mount!
Yeah... actually all you need is some WD40, hand soap...etc. Coat and press. Works well...
And the crazy thing is... when you think that mount is pressed in sideways.. and POP. It's straight. WOOP WOOP!
Old 09-03-2007, 12:41 PM   #12 (permalink)
funny, i did the same method with my mounts and a buddy's too. although it did take us a bit longer, but all was the same. great write up, easy understanding.
rycer is offline   Reply With Quote
Old 09-03-2007, 09:50 PM   #13 (permalink)
31Dodge
I think this would be a good addition to the tech library.
darthgearhead is offline   Reply With Quote
Old 09-03-2007, 10:31 PM   #14 (permalink)
thats what i was thinking. but i didnt just want to take it apon myself to just post it in there.
once jensen gets prothains for his new nx ill add that to the write up.......mybe try my hand at installing a prothain not useing a hydro press lol.
Old 09-03-2007, 10:40 PM   #15 (permalink)
Keo
huh??
Keo's Avatar
Feedback Score: 47 reviews
no press needed, I did it with a nib clamp and alot of lube.
Old 09-03-2007, 10:41 PM   #16 (permalink)
Keo
huh??
Keo's Avatar
also, on the top one, on the timing cover. make sure you do not scratch the mount with the screwdriver. I've seen it crack with a small scratch
Old 09-04-2007, 10:50 PM   #17 (permalink)
L337 VVL
Yeah don't even need anything hydrolic clamp or vice is fine!
Another tip is to make sure you have somthing like flat timber/metal to even out the pressure otherwise the mount will go in cocked and it will pop back out.
Old 09-11-2007, 10:05 PM   #18 (permalink)
Im Not A Chick
thoes are my tools !! lol
B13 XE with sr20 swap(5 speed swapped)
B13 LE parts car
NX2K RIP (Aug 13 2007) parts car
NX2k soon to be parts car
NX2k my new baby!
NX PART OUT CHECK IT OUT!
http://www.sr20forum.com/mechanical-...-nx-parts.html
We are a community!
jen36 is offline   Reply With Quote
Old 09-12-2007, 12:49 AM   #19 (permalink)
808 SE-R Mafia: KUKI-MSTR
i beg your pardon, i could be wrong, but i've seen it spelled prothane...i'm guessing the original post was a typo or i don't know what i'm talking about.
otherwise very helpful thread. bookMARK!!!
Chuck Norris once raced a VE. After winning he was so dissapointed he roundhouse kicked the VVL badge into a VTEC badge and called it a honda.
Since then Chuck only rolls turbo.
I have neither...but it still makes me smile
lazyieg is offline   Reply With Quote
Old 09-12-2007, 04:42 AM   #20 (permalink)
postersarelame.com
you are joking right?
BMW 325is
Aprilia SR50 R Factory
Honda CB350
[B][COLOR="Red"]FOR SALE: Engine Part-out - GTI-R grill, E30 spoiler, U13 skirts
stealthaltima is offline   Reply With Quote
HTML code is On
