1995 Pearl White Nissan 240sx- I/H/E, Flywheel, Tein springs/kyb struts, z32 brakes (F+R)
98% of teenagers do or has tried smoking pot. If you're one of the 2% who hasn't, copy & paste this into your sig.
Oh cool. I want to run a tmic on my nx2k and put a hood scoop on it. I'm interested in doing this, I dont want to run a resonator though (I'm lazy lol). I don't expect to pass emissions like that lol, but will this effect my performance?
You don't have to run a resonator, but the more you remove from your exhaust system the louder it will be. If you are lazy you probably shouldn't be modifying your car! It won't affect your performance but unless you run a muffler from the God's themselves your car is going to be loud and you WILL get tired of it if its a daily.
I don't suggest running a TMIC unless you can run some ducting from the scoop or at least tilt the IC so its in direct path of the scoop. If you do run a top mount see if you can upgrade your radiator as well because the nx's run a bit hotter because they are a little more confined.
Ok. Thanks for the input. I think i will run a resonator then if it will really make that much of a difference in daily driveability. BTW when you ran TMIC, what mods did you have and what was your 1/4 mile time? I just need an estimate. When I get my manifold I plan on wrapping it to help prevent heat from radiating also, but an upgraded radiator wouldn't hurt either I don't guess
totally stock bluebird and stock everything aside from a 3" dp and this exhaust i ran a 13.7 @ 107mph w/ a 2.3 60'. I was using hankook all seasons at around 20psi. Nothing major. this was on 12.5lbs w/ a t25. My car was fairly light.
Wow that sounds great. You had a pretty quick car for stock turbo. Im plannin gt28rs, bc stage 3 cams, and this exhaust with falken azenis. Thanks for all your help and input =)
how would this exhaust sound on a sr20ve with n1 cams?
do you thinkg i would lose any back pressure since its a n/a or might i gain a few ponies from it?
Current exhaust is old and crappy, i really like what you did in this write up and im considering doing this.
I don't know but if you want to buy my exhaust complete its for sale... let me know.
the code use to be EBAYROCKS
you have to look up the parts or READ the thread to get them....
I will me making yet another side exit exhaust using parts from the site again but this one will be for my 4wd sentra wagon!! hehe
94-XE 4D.... boost in the near future...stay tuned.... THE WEBSITE for all your synthetic oil and filter needs...AMSOIL First in Synthetics
Just a little fyi. If any of you guys like me read this, and thought about doing it n/a, here's a quick tip. If you are on a n/a setup, along with the resonator, you will also have to run a cat or a muffler because of the lack of backpressure, which equals to lost horsepower. Just in case anybody was wonderin
an n/a car will be loud....you can run a longer single magnaflow resonator from the cat to the 90 degree bend it will greatly help the sound and tone. I had a resonator on the last section of mine think it was 18"...ask those that heard it from the chicago convention...its sounded awesome! but you do have a nice clean install.
