How To: Paint things using a paint gun - SR20 Forum
Old 10-27-2007, 05:21 PM   #1 (permalink)
i smell that whore.
Feedback Score: 33 reviews
In this case I painted my driver's side fender.
List of materials:
1. Paint Gun (I used a $15 gravity feed gun from Harbor Freight, as far as I'm concerned it worked flawlessly, but I haven't used it again, so I don't know about durability)
2. Paint (I went to my local body shop supply place and had them match a quart of acrylic paint to the color of my car, it cost about $29 plus tax)
3. Clear coat (I used a aerosol clear coat, because it was cheap ($20) and I wasn't sure if I was going to mess it up or not. You can also get a can of clear coat and run it through the gun, which is more expensive, but probably better if you are painting a whole car. If you get the aerosol stuff, make sure it has a variable fan tip, not a round tip.)
4. 320-400 grit sandpaper (I used a 320 grit sanding sponge from autozone, it costs about $6.)
5. Denatured alcohol (I don't know how much this costs, I found some in my folks garage.)
6. Tack wipes ( I think this is what they are called, they are wipes you buy at the paint store, $2.50, and they pick up all the particles that may have been left behind by the denatured alcohol.)
First, you need to take whatever part you are trying to paint, and depending on the condition of the clear coat, sand it down suitably. From what I've read/been told, if the clear coat is in good condition, you can simply "scuff" the clear coat with 320-400 grit sandpaper, which is what I ended up doing. If the clear coat (or the paint itself) is in bad shape, you will probably need to sand it down to create a smooth surface for the paint, and possibly apply some primer, and sand the primer.
My clear coat was in good shape, so I ran over it with a 320 grit sanding sponge, no water, but you can wet sand if you so desire. I really don't know the benefits of wet sanding, anyone with insight feel free to chime in.
This is what my fender ended up looking like after I sanded it.
Make sure you get into all the crevices, and pay special attention to the edges of whatever you are sanding, as the edges will chip more easily than the flat surfaces.
Next, you will need to wipe down the surface to remove all the dust and anything else that would be detrimental to your paint. I used this denatured alcohol and a paper towel.
After that I used the tack wipes, which I neglected to take a picture of, to remove anything else that may be left behind.
After that, you need to secure your item for painting. Some people use a paint booth, but I just took some string and hung the fender from some trees. Make sure that you cover up anything you don't want paint on, because overspray is necessary for you to do this right.
Here is a picture of the paint gun I used:
Photo Sharing and Video Hosting at Photobucket
This is a picture after the first coat of paint.
When you are painting, there are a couple of things to take into consideration:
First, you want to make sure that you don't "fan" the gun. By that, I mean that you have to hold the gun the same distance from the surface all the way across, usually 6-8 inches. I had trouble with this, as I was wanting to kind of arc my arm, causing it to be farther away from the surface at the edges, and closer in the middle, if that makes sense.
Second, you want to make sure you start applying paint before you get to the first edge, and "follow through" on the other side. If you painting from left to right, start spraying paint before the edge on the left, and continue after you get past the edge on the right.
Third, overlap 1/3 or 1/2 of what you previously sprayed. If you are painting from top to bottom, you'll want to go over about 1/2 - 1/3 of what you painted first.
I allowed about 15-20 minutes between coats, but the guy at the paint store said "Alot of people come in here talking about coats. It's more about coverage." So basically you want to make uniform, even coverage, let it dry a bit so that it's not tacky/sticky to the touch, and then apply another coat. A good trick for determining when it's not sticky is to place a piece of tape on some part of what you're painting, in this case I used one of the mounting brackets on the fender, because no one will be able to see it.
Here's the second coat:
and the third:
Once you allow those to dry, it's time to do the clear coat. This is the aerosol clear coat I used. Like I said, it may be better to buy a can and run it through the gun, but once you open it and it comes in contact with oxygen you have to use it in a day or so. So if you only need to paint a little bit, the aerosol can works well.
And here's the finished product:
Take my word for it when I say wait atleast a day before you try to install whatever you've painted. My impatient dumbass tryed to put the fender on after letting it dry about 2 hours, it was dry to the touch, but when i was putting it on the car my thumb sat in the same place while I was tightening some bolts, and it left a thumbprint in the clear coat. I was super pissed, but I guess you could call it a super-custom job.
Anyway, if someone has anything to add or refute, feel free to post up. All and all I'm happy with the outcome. Price wise, I had a shop quote me $110 to paint the fender, which would have come out to a total of $140 including the fender itself. I could have driven a few hours and picked up a fender that was the same color for $65, + about $30 in gas = $95.
The grand total of this project ended up being around $100, and I picked up some knowledge, so I'm happy.
jeffinbham is offline   Reply With Quote
Old 10-27-2007, 08:09 PM   #2 (permalink)
Parting out my car
Feedback Score: 25 reviews
Nice write-up and I really really like the title!!!
Slow is the new fast
Old 10-28-2007, 09:48 PM   #3 (permalink)
i smell that whore.
Thanks dude.
Old 03-18-2008, 07:25 PM   #4 (permalink)
but young at heart
Feedback Score: 9 reviews
Hey Jeff, what type/size air compressor did you use?
"I am the gatekeeper of my own destiny and I will have my glory day in the hot sun." - who said that?
oldman is offline   Reply With Quote
Old 03-18-2008, 09:39 PM   #5 (permalink)
I liked that write-up alot,good job!What did you mean when you said,run the clear coat through the gun.?I thought that was just a spray can???
Ser-iouS413 is offline   Reply With Quote
Old 03-18-2008, 10:06 PM   #6 (permalink)
Unlimited Slip
It is from what I gather. He used a can but you can buy it for the gun also. You can get a handle from any auto store. You stick the spray can in this handle gun thing. It helps the hands from getting sore real quick trust me.
To add to this thread. All I can say is, if you spray paint anything make SURE that you give it plenty of time to dry. Dont try and get impatient and try to touch it to see if its dry and get finger prints all over it. Take your time and let it dry completely. I havnt read his article but im sure its really good. I just wanted to comment back on the question.
Travis J. Burrell
1999 Sentra SE-L
Some old pics of my SE-L
www.OhioNissans.com
Originally Posted by 2dr_sentra View Post
A rough night at taco bell makes better noise then honda makes.
1999SEL2.0 is offline   Reply With Quote
Old 03-18-2008, 10:16 PM   #7 (permalink)
Unlimited Slip
Oh and you would want to wet sand if you didnt want to get paint dust all over your garage and car. I know this from experience.
Old 03-18-2008, 10:19 PM   #8 (permalink)
Feedback Score: 55 reviews
what pressure did you use 30-40 psi, did you thin the paint alot
93 sentra xe dd (gas saver)
91 sentra se-r project car
97 200sx se-r new baby [/U]
99 sel
93 se -r
99sel-r is offline   Reply With Quote
Old 03-19-2008, 12:01 AM   #9 (permalink)
i smell that whore.
It's a craftsman 30 gallon, I believe. It's not mine, it's my dad's.
Old 03-20-2008, 11:46 AM   #10 (permalink)
but young at heart
Sweet, I was hoping I really wouldn't need too high-end of equipment. I'm not going for show quality, just a dang good looking car from 5-10 feet.
Craftsman air compressor and Harbor Freight spray gun!!! Now I just need to figure out what air mask to wear. I don't want to fry my lungs.
Old 04-29-2009, 02:51 AM   #11 (permalink)
n e color sanding or buffing after...?? didu get orange peel??
mipo510 is offline   Reply With Quote
Old 05-24-2009, 08:50 AM   #12 (permalink)
Im all about the 4x4
Feedback Score: 35 reviews
that spray can clear coat is usually for spoting in and does not have proper UVA Protection, this is ok on lip spolyers or wheels or brakes but a fender or hood or door i would keep away from doing that unless its a crap car.
places like autozone, pepboys, napa, carquest should have a cleaner that is good for preping a surface for paint. that stuff you have can leave a residue behind that will show in the paint. Best thing to do if your doing this route is to get from your local paint store single stage paint where the base coat and clear coat are as one and its a 2 coat process. Harbor Freight gun is not a bad gun and there are a few guys who use it in a few of the shops ive worked in. Alot of Helpers buy it to use to cut in with because they do not need a $500 Sata. The only thing i would do with the Harbor Freight gun is get a smaller tip and they do sell it.
Here is a List of Items I have for Sale and the Photo and Prices are in this Link Below:
http://www.sr20forum.com/florida/268...ml#post2554270
For Sale:
B14 Wheels
SAFC II - Silver
B14 Welded Transmission
SR20DET Motor
N60 MAF
specalk is offline   Reply With Quote
Old 12-11-2009, 07:14 PM   #13 (permalink)
i smell that whore.
I've been out of the loop for a while, but as noted above, the aerosol clear coat is sh*t. I've got some wicked orange peel, its going to have to be redone.
HTML code is On
