Here are a few steps on how to change the manual transmission oil. This is not that hard of a task, but if you have never changed the manual transmission oil it's hard to know where to even start from.
Most people would suggest Redline MT90, the choice is up to you. You can get it fairly cheap at GoFastDepot.com
If you don't want to use Redline MT90, check the FSM (Factory Service Manual) for the specifications of the oil that can be used for the transmission.
Wrenches
For drain plug:
For fill plug:
Sealant
FSM has these listed: Genuine anaerobic liquid, Three Bond TB1215, or equivalent
Funnel and a hose or little Fluid Oil Pump
I highly suggest a Fluid Oil Pump that can be found in Advance Auto Part for about $6. Using the pump will help you get the oil in a much shorter time, it took me about 10 to pump all the transmission oil.
Oil Drip Pan to pour the old oil into
I used the normal oil drip pan that is used for engine oil.
Down to the Business
1. Take a drive in your car to warm up the transmission fluid. This will help it exit the transmission quicker.
2. Take off the fill oil plug, it is found facing the front of the car. This way if the fill plug gets stuck you can still drive the car, instructions on doing that are in Step 3. Thanks NismoSER for the tip
You will have to use this wrench:
3. Loosen the Transmission oil drain plug and let the oil empty out into the oil drip pan. It might have a pretty bad odor. While the oil is draining cleanup the plug and remove and dirt or debris from it.
Use this wrench to loosen the drain plug:
4. After all of the oil has been drained, apply some sealant (as listed in the Equipment Needed section above) to the drain plug and tighten the bolt according to the FSM torque numbers. FSM Torque Numbers: 25 - 34 N-m (2.5 - 3.5 kg-m, 18 - 25 ft-lb)
5. Plug the hose from the funnel pump to the fill plug and add about 3.6-3.8 liters (7-5/8 - 8 US pt). The way you can check if you have enough is by putting your finger in the hole and if you feel the oil right up top, then you have enough. (Note - if your front is jacked up, the oil levels are not going to be even)
The finger method of checking if the oil is full. Thanks Mike for the pic
For the pump to better fit the MT90 bottle you can cut bottle tip at about 4 ribs. You can see this indicated below with a yellow pointer. Thank You for the tip BBYE V8
6. Add some sealant around the thread of the fill plug, then tighten the plug. Thats it!
Big thanks goes to Sentrixx and AztekSE-R for telling me how to do this. Also big thanks to Serban and the GoFastDepot.com for the great prices!
i have Redline MTL sitting for months... i do alot if driving, about 300-400mi a week... will MTL be good for my tranny, or get rid of it and use Mt90....
2010 Chrysler 300c
1994 Sentra SE-R
[B]91 Mint SE-R (third owner)
Mods: Black, Very Clean, Turbo. -weekend warrior-
How many miles is MT90 good for before one should think of swapping it?
Let's say for, 1)mellow daily driving miles, 2)harder driving miles, and 3)racing miles?
Nice write-up. I personally take off the fill plug first, so that I know I can get the new oil in there.
You never know, for some strange reason, your fill plug might be seized, get stripped out, etc. etc., so I just want to be sure that I don't render the car un-driveable.
Chris '91 VVL-powered SE-R SOLD
VE! Koni/GC's, Apexi, Progress, Crown, Carbotech, ACT, GSpec, Fidanza, VDO, Nismo, and other goodies '04 G35 6MT
I wish I could answer but I'm not too familiar with this area, I was told MT90 is the best choice by couple friends, so that was good enough
D
I hope as much as the normal Tranny oil, but I heard every 60k might do...
Originally Posted by Mike
The finger method
Mike
Hahhahahaha
I'm gonna add that writeup
Thanks , thats a actually a good idea, I will mention that in the writeup
Even if you can't get the fill plug out, you can fill it through the speedo hole. The fill plug was stripped on my car when i bought it, so that's what i had to do.
that's one reason why I NEVER overtighten the tranny bolts. they really do NOT need to be tight at all. Slightly tightening with a 1/2" ratchet is good enough
