Old 03-03-2007, 10:06 PM   #41 (permalink)
98sr20ve
Originally Posted by silvia1320 View Post
hey steve, i just cut out the oem strut innards from my b13 front housings yesterday and i tried to put the specv konis in and it looks like the extrusions/nubs towards the top of the strut insert(like in pic 2) interfere with the insert going into the housing so i was wondering if you have to pull those nubs into the housing with the screw at the bottom(like a lug nut and wheel stud type of thing)? or do you cut the actual housing shorter to accomadate the nubs. i looked at the insert in the housing and it doesnt look like the threaded part at the bottom is even close to touching the bottom especially if i cut the half an inch or so off of it.
Those nubs are the tension to keep the strut tight up top. Read the instructions. This install is just a slight variation of the standard Koni install.
Steve
06 G35 6MT
Old 03-03-2007, 10:07 PM   #42 (permalink)
98sr20ve
Originally Posted by pathfinder7 View Post
Are these the struts you guys are using?
Brand: Koni
Product Line: Koni 8611 Series Double Adjustable Race Strut Inserts
Internal Design: Twin-tube
Adjustable: Yes
Gas Charged: No
Boot Included: No
Extended Length (in): 19.690 in.
Collapsed Length (in): 14.060 in.
Body Diameter (in): 1.713 in.
Upper Mount: Stud
Quantity: Sold individually.
Notes: 5.63 in. stroke, 11.42 in. body length, and is designed to fit through a 5/8 in. bearing camber plate assembly.
Race Strut, Insert, Double Adjustable, Twin-Tube, 19.69 in. Extended/14.06 in. Collapsed Lengths, Front, Each
If They are, I am testing the waters for a group buy.
This is only a test.
Ed
No I am using the Spec V, B13 and 92 Maxima Inserts.
Old 03-03-2007, 10:08 PM   #43 (permalink)
98sr20ve
http://www.sr20forum.com/showthread.php?t=185484
Here is another great thread about the Koni options.
Old 03-03-2007, 10:11 PM   #44 (permalink)
98sr20ve
Very important I edited post 41
Old 03-03-2007, 10:33 PM   #45 (permalink)
silvia1320
VVL Here I Come
silvia1320's Avatar
i dont have the fronts installed yet but the rears are a huge improvement over the ksports for ride quality on rough streets
B13 SE-R
silvia1320 is offline   Reply With Quote
Old 03-04-2007, 12:13 AM   #46 (permalink)
veilside180sx
98 SE
^You'll be much happier once you get the fronts on too. Which did you use? maxima's? also what spring rates did you wind up with?
Koni www.koni-na.com
www.nissanroadracing.com
Old 03-04-2007, 12:20 AM   #47 (permalink)
pathfinder7
Pursuit of happiness
pathfinder7's Avatar
for ride quality on rough streets.
There is what I want to hear, Thanks guys keep posting.
Ed
pathfinder7 is offline   Reply With Quote
Old 03-04-2007, 03:40 PM   #48 (permalink)
silvia1320
VVL Here I Come
silvia1320's Avatar
i am using the spec-v fronts with the b13 housings. i cant put them on yet though because the one housing i got is an aftermarket strut and the wall of the tube are thicker than the oem one so i have to go to pull n save and try to find another oem one. it felt really weird when i put the rears on though like the car was raked up in the rear like an old muscle car because i had the ksports set so low before. i dont remember the rm spring rates off the top of my head but i think they are 325f/250r?
Old 03-04-2007, 03:58 PM   #49 (permalink)
pathfinder7
I have the same problem with my new Tokico kit I have installed on the ser
I gotta check the spring rates see how they will match up. Not sure what to do.
Hopefully keep the springs and use them in conjunction with the OEM struts w/ Koni inserts.
By the way have you heard of a spring spacer, I would like to raise the front .50", just a thought.
Ksport 336f/392r with options
Ed
Old 03-04-2007, 07:02 PM   #50 (permalink)
Keo
huh??
Trader Rating: 39 (100%)
By the way have you heard of a spring spacer, I would like to raise the front .50", just a thought. 325f/250rYou are right
Ed
for the spaceer search "hyperco Gen1" or "lifted B13" use the donut
Old 03-04-2007, 07:20 PM   #51 (permalink)
kioh
Trader Rating: 15 (100%)
Forgive my ignorance but what are the nubs doing in the second pic? They are not near the top of the cut so are they superfluous? They don't seem to have a function there, unless I'm missing something.
kioh is offline   Reply With Quote
Old 03-04-2007, 07:30 PM   #52 (permalink)
Keo
huh??
there's a spacer, washer and a bolt, I don't see a nub. unless your talking about the bolt. it's black with a allen key slot
Old 03-04-2007, 08:28 PM   #53 (permalink)
pathfinder7
Thanks Keo, I made a mistake RM=325f/250, ksport=336f/392r
i,m still a newb and show it every day.
Ed
Old 03-04-2007, 08:36 PM   #54 (permalink)
Keo
huh??
Ed
it's all good, we are all here to help each other
you got the k sport back ward it's 392 f/ 336r
Old 03-04-2007, 08:39 PM   #55 (permalink)
pathfinder7
Thanks,
By the way, re read all the threads, my answers were there all along,
eeven if I had to read it twice okay three....times 8610-1409
98srve,keo,silvia 1320
Thanks
Old 03-04-2007, 09:26 PM   #56 (permalink)
kioh
I'm talking about the yellow insert, right above the JBweld.
Old 03-04-2007, 09:47 PM   #57 (permalink)
Keo
huh??
aaahh, i see
Old 03-04-2007, 10:28 PM   #58 (permalink)
98sr20ve
YOu can normally take some paint off to make the units work any most housings.
Old 03-04-2007, 10:31 PM   #59 (permalink)
98sr20ve
The Spec V inserts have two sets of nubs. They are also bigger then many of the housings. I sometimes ingnore the nubs if the inserts are already really tight in the housings and JB Weld them around the top before I insert them in the housing. That set probably has another set of nubs just below the top that you can't see.
Old 03-04-2007, 11:30 PM   #60 (permalink)
kioh
