Old 04-04-2007, 07:17 PM   #81 (permalink)
98sr20ve
Originally Posted by Taiden View Post
Alright. So basically it doesn't matter because you're in effect making a mold for the entire bottom tip of the strut out of JB weld. I imagined it resting on the brim, but using jb weld on the sides just to absorb some of the movement from standard suspension movement.
When you JBWeld around the top and the bottom and bolt it in there will be no movement.
How do you go about getting the JB weld in there? Do you load up the section between the brim I had circled in the previous post and the tip and slide it in? Crank it down, let the excess pour out the hole, clean it up and bolt it down?
All you do is use a Popsicle stick to smear some around that weld area at the bottom and around the top just below the point it transitions from the koni to the tube. The JBWeld will flow around the bottom pretty well.
Also, the cheapest I've found the Spec V front inserts for is $420 shipped. Anyone got any other leads?
I sell them for 145 shipped. Buy them from me because I helped you do all this stuff.
Steve
06 G35 6MT
Old 04-04-2007, 09:41 PM   #82 (permalink)
pathfinder7
Pursuit of happiness
pathfinder7's Avatar
Buy them from 98sr20ve,
You cannot go wrong Taiden.
Ed
pathfinder7 is offline   Reply With Quote
Old 04-11-2007, 09:47 AM   #83 (permalink)
98sr20ve
I am hearing that the Spec V inserts now require you to install the GC collar BEFORE you put the Koni in place. Maybe Koni changed the top part of the strut but better get your threaded sleeve on first now it seems. Or at least check your to make sure it will go over the inserts top hat/nut.
Old 04-11-2007, 10:11 AM   #84 (permalink)
Taiden
Luke Pighetti
Taiden's Avatar
Good to know. Thanks Steve.
Old 04-11-2007, 10:18 AM   #85 (permalink)
eric96ser I am a moderator
eric96ser's Avatar
Trader Rating: 15 (100%)
I was the one who told Steve about this. I finally got around to cutting the housings enough for the inserts to fit, and when I went to check and see if the collars were too tall, I noticed the top washer on the insert, was too big for the collar to slide over. My inserts had 8610 on the bottom of the nub, if that makes a difference.
1991 Sentra SE-R
The community is here.
Old 04-11-2007, 10:47 AM   #86 (permalink)
veilside180sx
98 SE
The Maxima inserts are the same way. They require that the GC sleeve is installed before the insert as well.
Koni www.koni-na.com
www.nissanroadracing.com
Old 04-12-2007, 12:06 PM   #87 (permalink)
98sr20ve
The maxima insert is a lot bigger. For the life of me I don't remember this issue with other Spec V inserts. Maybe I just don't remember. I always check these things out of habit anyway.
Old 04-16-2007, 06:06 PM   #88 (permalink)
pathfinder7
98sr20ve,
I have a question?
I have the oem/koni combo complete on my b13 ser. Front and back.
The ride is great, BUT.. there is a rattle in the rear, and it is only when I go into a corner and as far as I can tell, it is coming frome the rear upper mounts, strut mounting insulator and/or upper seat. what do you think. Do I need new ones,
which I have for the NX, or do you think I made a mistake on reassembly.
Ed
Old 04-18-2007, 05:10 PM   #89 (permalink)
98sr20ve
f you are certain that Koni is not loose in it's housing then it's possble that the nut is not tightening down on the top mount OR the top mount is worn.
Old 04-18-2007, 06:22 PM   #90 (permalink)
pathfinder7
I retightened the top bolts after I drove a few miles to let everything settle in. I will pull the wheels off, and inspect everything. I used your suggestion on the JB weld, so I do not think it is that. I will let you know what I find out. I am baffled
Ed
Old 04-18-2007, 11:40 PM   #91 (permalink)
98sr20ve
Its possible that you need to add another washer under the nut. Did you use the nuts supplied by KONI? Do you have the OEM swaybar?
Old 04-19-2007, 01:34 PM   #92 (permalink)
pathfinder7
Yes and yes, Thanks for the follow up, Let me make sure on all your questions, I will pull the wheels and triple check the nut on top and sway bar.
Thanks a bunch.
Ed
Old 04-24-2007, 02:58 PM   #93 (permalink)
eric96ser's Avatar
Ok, guys, here are my struts:
This is how much I cut off the bottom of the nub:
The bolt:
How they fit in the housings:
Whole deal:
Since I didn't cut as much of the nub off as most people, and the inserts fit in just below the 2nd set of nubs, do I need the JB Weld? I also wrapped the top of the inserts with duct tape to keep the GC collars from moving around.
Old 04-24-2007, 07:51 PM   #94 (permalink)
98sr20ve
I would do the JB Weld. You have still removed over 1/2 the bolt AND are not fastening the bottom as securely with the larger hole. JB Weld flows around the bottom nub and prevents side to side movement.
Old 04-28-2007, 07:42 PM   #95 (permalink)
pathfinder7
98sr20ve, I apologize.
I said I had a OEM sway bar. I do not, It is a ST sway bar, The slight rattle is still there but I have not been able to pull it apart, I am sure it is something I did not do correctly, as soon as I figure it out, I will post it, I am not scared by my ignorance. just worried......
Ed
Old 05-01-2007, 12:00 AM   #96 (permalink)
98sr20ve
Originally Posted by eric96ser View Post
Is that picture after you used the bolt the suck the koni into the housing? If so then its perfect. Just does not seem to jibe with how long it is in the first picture. Seems from looking at the above pictures in previous post that your nub is long. Bolt is hard to tell. This is one reason to cut the housing shorter then the nubs and JB weld the top tight. That way you can slide the Koni in and not have to fight the tension the nubs create. Then you know for certian the nub is not to long and going to stick out too far.
Old 05-02-2007, 01:15 PM   #97 (permalink)
Matty Moto
Auto Pilot
Matty Moto's Avatar
Trader Rating: 13 (93%)
I'll take a set, Steve...
Nice write-up.
Matty Moto is offline   Reply With Quote
Old 05-02-2007, 09:07 PM   #98 (permalink)
98sr20ve
Ground Control Suspension Systems
You buy the inserts from a Koni supplier, GC may be a supplier. As are many others.
Old 05-03-2007, 03:38 AM   #99 (permalink)
veilside180sx
98 SE
GC is a Koni supplier..
Old 08-17-2008, 11:25 AM   #100 (
