I'm traveling tomorrow and working away from the office, so I won't be able to respond until late tomorrow or Wednesday. I'll bring mine to the convention also.
Looks good Eric. Couple of suggestions though. You used 1/16 thick aluminum. I like the thicker 1/8 inch. If you look at some of the longer pieces at the hardware store, some of the 1/16 inch pieces have already been bent accidently. You want to ensure that the stock you are using is flat AND stays flat (i.e. gets bent in storage, dropped, etc)
Take the plastic ends off the swanson bubble level. I found that it is only level on the bottom of the unit and the plastic is uneven.
I also went back made a correction to my post earlier about subracting the metal piece of the unit, I thought you meant the wheel lip.
'97 200SX SE-R GT28RS Powered
'06 Mitsubishi Lancer Evolution IX
'09 BMW 335i E90
Looks good. I don't think that metal is 1/8 thick if not then my previous post about your corrected camber would be off a little. How thick is it? Then we can actually know your camber.
So .581-.054=.527 and .324-.054=.270. So thats 2.3 camber in the front and 1.2 in the back using the 13 inch scale. Right where I would expect the back of a B14 to be.
I had thought of building one a couple years back but couldn't find that digital inclinometer cheap enough for my idea. As soon as I saw these came out at Sears I literally ran out and bought one to build it.
You can ALSO use it to level the car!! I did. Here's how: I drove the car on the exact spot I wanted to take my measurements for alignment. I marked the floor, and found the center by crossing the four corners. I grabbed my camera tripod and screwed the level onto it. Then I leveled it to 0.0deg and pointed it to my big T square(as seen above) at each of the four corners finding the highest corner and raising the other three to match with 1/8" vinyl floor tiles. Done. 20 minutes tops.
You can hit the calibrate button while holding the level exactly 90deg so that when you measure camber it will show the actual value, i.e. 1.0deg, 1.3deg, 2.1deg and so on instead of subtracting the value you read from 90. It's not worth it to me, I just turn it on, throw it up there straight up and down (eyeball it), and subtract from 90.
White '92 NX2000 All Stock.
Since I'm always jacking around with my alignment now, I needed something quick and easy to measure toe without the help from another person. Instead of coughing up 60 bucks for the Longacre plates, I decided to make my own for 10 bucks. Please excuse my dump of a garage.
Here I was showing about a 1/4" toe out with my camber plates slammed all the way inward.
