just figure out which way the picture is situated as opposed to your harness connector.
Well that would work if the obd-I and obd-II ecu connectors were the same, but unfortunately they are not. i dont even see a diagram that comes close to resembling the obd-II connector in the pages of connectors that apex-i sent with the unit. I don't think japan uses the obd-II.
ok this has nothing to do with a safc but i was wondering if charlie you have the full pinout on a 91-94 ser ecu. i need it becuase i am running a bb ecu and i got the HKS speed defencer to get ride of the 109mph cut off.
Rocco
sr20ser1997 u r awesome..................and is this wroking for you? The diagram u made...................i mean one could figure most of it out but like u mentioned before the ECU has some many grounds adn it sucks that Apex doesn't give us the specific one to use........well actually they didn't give the B14'er sh*t to work with. Also what in and out settings r u using since they dont list the B14 as an application although I know B14'ers use SAFC's.
Yep, It works with no problems. I have it tuned to accept my z32 maf and 555cc injectors since my jwt ecu is programmed fro 370cc injectors and a stock mafs.
I was using 6in and 6 out for the stock mafs. when i got the z32 mafs im now set at 2in 6out
sr20ser1997............sweet............now could you post a pic of the ECU pin-out for a B14 ECU and are they all the same 95-98? Thanks in advance if can.
Apparently they took down my pictures.. I didnt have a saved copy of the diagram i made so hopefully someone else does..Here is the b14 pinout though..
But when you put power to the SAFC does it light up and say APEXi, or just light up the buttons?? Just need to know if one I am looking to buy is a bust or not.
The wire diagram labeled on the first page for a B13 will work with the gti-r motor, correct??
