HOW TO: Wire up your Apex Super AFC - Page 5 - SR20 Forum
Old 08-10-2007, 05:20 PM   #81 (permalink)
the fo do
it is the same. I hooked up an AFC Neo on my 99 SE-L and it was exactly the same.
99 SE-L
91 intake cam/bluebird t25/Calum ecu/370cc injectors/walbro 190/3inch dp/Greddy Catback/JWT PP w/ SE Disc/Prothane mounts
se-riousclassic is offline   Reply With Quote
Old 08-31-2007, 12:57 AM   #82 (permalink)
Auto Enthusiast
Feedback Score: 4 reviews
I just dont see how anyone can understand this. I just acquired an apexi safcII and now im considering getting rid of it because this looks like a wiring nightmare. I have a 1993 nx2000. Can someone please help me????? The instructions seem a bit vague
"Grey wire (Throttle Signal)*to***White wire (not same)
Brown wire (Ground 1)*** to***White wire (same)
Black wire (Ground 2)**** to***White wire (same) 1 cm apart Blue wire = Not used"
"White wire(same) and white wire(not same)" WHAT????
has anyone done this on their NX2000?????
johnnym is offline   Reply With Quote
Old 09-06-2007, 05:00 AM   #83 (permalink)
SR20DETERMINED
Feedback Score: 17 reviews
just look at the pinout for the ecu and follow that, that just means there are more than one white wires on the ecu, that is all, it is easiest to just follow the pinout.
92 Nissan Sentra SE-R
Fully built SR20DET, JWT S4 cams, 720cc injectors, Calum Basic ECU, Fidanza Flywheel, ACT extreem clutch, mezier electric water pump, Garrett t3t04 60 trim turbo w/ a .82 turbine housing, ebay tubular manifold, tial 38mm wastegate, All work done by me
ashtonsnissannx is offline   Reply With Quote
Old 10-08-2007, 04:10 PM   #84 (permalink)
Feedback Score: 20 reviews
Originally Posted by daveracer View Post
Since the picture keeps getting lost...
Originally Posted by MY95SER View Post
THANK YOU! but is this for 95-97? or 98..
That drawing is amazing, esp compared to the text based explanations
I'm thinking about getting a SAFC II or AFC NEO... any suggestions?
"Vadim" @ Dash
Old 10-08-2007, 10:05 PM   #85 (permalink)
The SE-R Sitter
Feedback Score: 12 reviews
Dude, It's pretty straight foward. The NX will be the same as any other sr20de car.
I just never understood why it's double grounded.The only scary part is cutting the Maf wire. But it's all easy. If you need help just hit me up and I can take Real pictures for u.
SE R Madness is offline   Reply With Quote
Old 10-08-2007, 11:29 PM   #86 (permalink)
the ONLY nx in PALATINE!!
what are the possiblities of this an a n/a sr20 with minor bolt ons???any good numbers from it?
http://i149.photobucket.com/albums/s...0405071813.jpg
http://i149.photobucket.com/albums/s...17071403-1.jpg
[Today 07:05 PM] Shawn B: Ten bucks is ten bucks. Signing your name "fu*k you"....priceless.
pedronx2k is offline   Reply With Quote
Old 10-09-2007, 12:05 AM   #87 (permalink)
The SE-R Sitter
That's like getting a Boost Gauge for a VE.
Old 10-09-2007, 08:50 AM   #88 (permalink)
I know a person who is pushing 180WHP on NA. One of the key things that he mentions that got him that high is a SAFC II and proper tuning.
Old 10-09-2007, 11:59 PM   #89 (permalink)
The SE-R Sitter
What Bolt ons?
NOn VE?
Old 10-10-2007, 08:52 AM   #90 (permalink)
What Bolt ons?
NOn VE?
De, just about every single bolt on you can get...
EDIT: Oh yeah proper tuning is also needed. Getting the right amount of fuel and air at the right RPM will help quite a bit.... I mean a lot!
Old 10-27-2007, 08:55 PM   #91 (permalink)
know hope.
redb13se-r's Avatar
Feedback Score: 22 reviews
on the N3-a.... can anyone tell me which wire is the o2 signal wire? i have been trying to find this out for a while? if you know it, please PM me, thank you.
Aztec Red 91' SE-R
Radiant Silver 07' Fronty. Blasting 145 dB at 120psi baby.
Killface for president.
redb13se-r is offline   Reply With Quote
Old 11-01-2007, 08:51 PM   #92 (permalink)
SE-ROLGIST
Feedback Score: 14 reviews
=Thank goodness this thred was made.
topdog781 is offline   Reply With Quote
Old 11-28-2007, 05:44 AM   #93 (permalink)
The ELITE NX2k Bredren!
Feedback Score: 26 reviews
That first N3a Diagram in the first post is a phony! For B13 you want to use that second one.
1993 Nissan NX2000
w/ 1998 SR20DET Avenir motor w/ so many mods it would be stupid to list them all and more coming!!!!!
Johnny wangwang is offline   Reply With Quote
Old 11-28-2007, 07:36 PM   #94 (permalink)
Don't stage if ya scurred
or...........
You can get lucky like me and find one already wired in a harness you can just plug in to the factory harness and ecu.Hooray for me!
nissannut is offline   Reply With Quote
Old 12-18-2007, 07:24 PM   #95 (permalink)
mad about SER:P
Feedback Score: 11 reviews
BUMP!!!
in the sacf II thres only one red wire taht goes connected to de ig power, but in the neo i has two red wire, can any one help me out w this?
i just connect both reds to IG power?
thanks
beto_dc is offline   Reply With Quote
Old 01-16-2008, 10:40 PM   #96 (permalink)
P10 and NX love
Does anyone have or know how to install this into a G20 OBD2. For some reason I'm not getting any power to my NEO. Both ignition wires are on as well as the grounds. I'm sure all the wires are hooked up properly except for the RPM wire? On my diagram it says the wire is light blue L/B is actually what it says but the wire they said is not light blue. In the area where the one they mentioned, that is black and blue, but I dont think thats the RPM signal. Can anyone help me out here?
siberian21 is offline   Reply With Quote
Old 01-18-2008, 03:04 PM   #97 (permalink)
P10 and NX love
okay I have the neo turning on just dont have an RPM signal. I have it hooked up to pin#3 but nothing is coming up. I have RPM's on my gauge cluster working but not on the neo is there anyone out there that can help me with this?
Old 03-03-2008, 07:30 PM   #98 (permalink)
skysen
does someone here know how to SET the power fc NEO , like the KARMA and the IN and OUT , the CORRECTON% etc!!!
skysen racing is offline   Reply With Quote
HTML code is On
