HOW TO: Reground your MAF - SR20 Forum
Old 06-19-2004, 11:33 AM   #1 (permalink)
1998ccs of fury
Feedback Score: 19 reviews
First, you'll need a digital voltmeter and a small flat blade screwdriver.
The MAF sensor is located just past the air intake. You'll need to pull back the rubber cover to expose three wires. On mine, the outer two were orange, the middle one is white. The middle pin is where we need to get a voltage reading from (with the engine idling). Take the positive lead of the voltmeter and make contact with the middle wire. The negative lead should be pressed to one of the ground connectors on the engine block, near the firewall, right behind the fuel injectors. You might have to look hard to see them, just look for a bolt with several black wires running to it. Took me a while to spot it myself, several vacuum hoses in the way...
The voltage read should be less than 9mv (.009v), if it is above this value, the sensor needs to be regrounded. To do this, a wire needs to be run from the middle pin to the ground lug. You'll need to remove the connector from the MAF to get a good angle on it. On either side of the connector is a small opening for a small flat blade screwdriver. There is a wire that runs around the connector to hold it in place, you need to pry this wire outwards, then move the connector back a bit. Do one side, then the other, and it should pop right off. I'd never seen this type of fastener before, once you have it off you'll see what I mean.
You'll want to solder a new wire to the middle pin, make sure you get a good connection. Then, run the other end to the ground lug. If you want to do the job right, you'll want to get a connector from Radio Shack or other electronics store that has a ring that you can crimp the wire to. I don't remember the size of the bolt, so I'm no help there. I just looped my wire around the bolt twice and put it back on. I may go back and fix it up nice some other time.
Once the sensor is regrounded, the voltage should drop significantly. Mine was at around 11mv, after the fix it went down to less than 2mv.
Source: Jim Wright
Old 10-29-2004, 03:39 AM   #2 (permalink)
Why need reground MAF?
Gora is offline   Reply With Quote
Old 10-29-2004, 07:01 AM   #3 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Feedback Score: 93 reviews
Please read.
Old 10-30-2004, 06:41 PM   #4 (permalink)
iNGEN's Avatar
Good job making an ass out of the newbie, but you seemed to miss the point of Gora's question.
Matthew "iNGEN" Woods
SweetPea has to go. 61k and clean as a whistle. Lots of extra parts including rebuilt turbo thrown in. PM me for details.
iNGEN is offline   Reply With Quote
Old 10-14-2005, 11:09 AM   #5 (permalink)
Retired.
Feedback Score: 10 reviews
regrounding your MAF can help stop hesitation/bogging in the rpm band and increase gas mileage, also helps performance in most cases.
-Chris
1992 Mitsubishi Galant VR4
#760/1000
the rebuilt, boosted dd
2/10/2011 - Now
1993 NX2K
11/10/2007 - 3/15/2011
(parting out)
1991 SE-R
02/2005-09/2007
*SOLD*
Pr0nSt4r is offline   Reply With Quote
Old 10-19-2005, 11:39 AM   #6 (permalink)
Chasing after the vette
So after you solder the new one and connect it to the grounding bolt. What do you do with the white wire that was there? Do you put it back?
2001 Nissan Sentra with a GTiR (finally)
Color Radium 18" Konig Trouble's w/ Falkon 451's 215/40/18 tires
ICE: 3 12" JL Audio W3, 2 amps 300 watt mono and 500 watt 4 channel and a Pioneer receiver.
Project: 1995 200sx se. GA to SR
snkyjester1 is offline   Reply With Quote
Old 10-19-2005, 11:58 AM   #7 (permalink)
daveracer's Avatar
You don't do anything with it. Just cut it.
Old 10-19-2005, 07:10 PM   #8 (permalink)
Feedback Score: 6 reviews
sweet does this help out on stock and slightly modded sr20de b13 se-r's if so what should i expect ...the same as aforementioned
Mrstaff...Bham PTAC Tech.
94 sentra se-r sapphire blue..Jdm swap completed next stop Boost ..
83 chevy caprice classic a 327 with a cam and head work r.i.p.
1992 sentra E 4speed manual 2dr(true beater)
New daily driver beater....94 mazda 626 my import hooptie
1.8L 2000 b15 engine for sale... OBO still have the car it came out of.
mrstaff00 is offline   Reply With Quote
Old 10-20-2005, 02:59 AM   #9 (permalink)
SE-R GREEK
Feedback Score: 8 reviews
Are you sure about that Dave?
My "better-safe-than-sorry" self tends to think that we should leave the original cable on and solder the new one on the same connector...
HTML code is On
