0
Nx2000 0
0
B13 10
0
Body ,j/c
Engine ,j/sr20de
Emission,fed
Trim Lvl,se
Trans ,j/mt.f5
1 2 11044 111 1 1104479e13 0 0gasket-cylinder Head 01 0 1
2 3 B13 14036m 140 1 1403653j00 0000000 0gasket-exhaust Manifold,a 01 0000000 1
3 4 B13 12279 110 1 1227918v00 1227930p00 20 0seal-oil,crankshaft Rear 01 0 1
4 5 B13 12207s 120 1 1220860j00 0000000 0bearing Set-crankshaft 01 0000000 1
5 6 B13 12033 120 1 1203353j00 1203353j01 20 0ring Set-piston 01 0 1
6 7 B13 12111 120 1 1211160j00 121111n500 20 0bearing-connecting Rod ** 0 1
7 8 B13 14035p 140 1 1403253j10 0 0gasket-intake Manifold 01 0 1
8 9 B13 16293m 140 1 1617553j00 0 0gasket-throttle Chamber 01 0 1
9 10 B13 14035 140 1 1403553j10 0 0gasket-manifold 01 0 1
10 11 B13 11826 118 1 1182653j14 0000000 0hose-blow By,a 01 0000000 1
11 12 B13 11810 118 1 1181079e00 1181079e01 20000000 0valve Assy-control 01 0000000 1
12 13 B13 15200f 150 2 1506677a00 150664j600 20 0seal-o Ring 02 0 1
13 14 B13 15053m 150 1 15059v5001 0000000 0seal-o Ring,oil Strainer 01 0000000 1
14 15 B13 23785n 148 1 2378553j00 0000000 0iacv-aac Valve Gasket 01 0000000 1
15 16 B13 13042 135 1 1351040f00 1351053j10 20000000 0seal-oil,crankshaft Front 01 0000000 1
16 17 B13 13520z 135 1 Kp51000150 Kp71000150 20000000 0gasket-liquid *** 0000000 1
17 18 B13 13035h 135 1 1506677a00 150664j600 20000000 0seal-o Ring 01 0000000 1
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by abelsgotspeed
Originally Posted by chriscar
