HOW TO: Adjust your idle - Page 2 - SR20 Forum
Old 02-22-2005, 02:16 AM   #21 (permalink)
just a G thang
nice thanx for the info guys....
vince
GUAM'S G20 is offline   Reply With Quote
Old 03-14-2005, 05:22 PM   #22 (permalink)
hybrid SR20
the most i can get is 840rpm. I'm trying to set at 850-950rpm thanks.
Have you ever chased a sentra lately?
redclassic is offline   Reply With Quote
Old 04-20-2005, 12:00 AM   #23 (permalink)
reckless imprudent
this won't affect my timing right?
pazuso is offline   Reply With Quote
Old 03-04-2007, 11:39 AM   #24 (permalink)
i got the same prlb i put a jdm and me idel stay at 2.100 i trad every thing i just dont know want to do .
juny is offline   Reply With Quote
Old 03-20-2007, 07:52 AM   #25 (permalink)
i faund the prob it was me intake gasket know is idle fin know thank you.
Old 03-11-2008, 04:31 PM   #26 (permalink)
Enjoying the Ride
happynole's Avatar
Feedback Score: 85 reviews
Isn't searching wonderfull!!!!
Vail White 93 SE-R......................what's a Sunny?
Pearl White 95 Primera.................the Yin to Sunny's Yang
Life is a Journey, Enjoy the Ride
SR20DeepSouth
http://www.datsun.org/roadster/liter.../dream_grg.mov
happynole is offline   Reply With Quote
Old 08-11-2008, 05:48 AM   #27 (permalink)
NXR Turbo User
How the hell do I get an 800rpm idle??
I've tried to adjust my idle, but all the screws are all the way in and it still idles around 1400rpm. It is a basically stock SR20 in a FWD Pulsar, but I have put a GTiR Quad throttle body manifold that I fully polished on the inside.
SR20pulsar is offline   Reply With Quote
Old 10-23-2008, 03:34 PM   #28 (permalink)
Weekend Warrior
Feedback Score: 60 reviews
Originally Posted by Yahnozha View Post
one more note...dont even attempt this unless you have a timing light that will give you an accurate RPM readout. The stock RPM gauge should not be trusted for this.
^Hmmmm......
Originally Posted by sr20boston View Post
Start car and let idle until engine is warm.
Hold throttle at 2000 RPM for two minutes.
Turn off engine and disconnect throttle sensor.
Start engine, rev twice to 2000 RPM.
Adjust the idle speed to ~750rp using the idle adjust screw, located near the oil filter.
Shut down the engine, connect the throttle sensor, and start the engine.
The engine should now idle at out 800RPM.
Source: Jim Wright
^I'm going to go back and adjust my idle again. My car has been going up to 1500RPM's lately when I first get in it to drive. Then after about 20 minutes or so, it want be that high when I come to a red light and it stays around 800-750. Is it that my idle is really that off and the ECU is correcting it?
^Could this be part of my idle problem?
http://www.gspec.com/p-7298-idle-air...e-20-iacv.aspx
^You can get it here.
Bend But Don't Break
HTML code is On
