Old 07-02-2006, 11:53 AM   #41 (permalink)
SR20DEbT
Trader Rating: 53 (100%)
Someone has to post the marks correctly. Many of my people with SR20's have 6 timing marks. I hope the correct order is -5, 0, 5, 10, 15, 20 because I am going to do it right now to 19*.
-Bes
92 Sentra GTi-R
Small Snail Crew
----BNB----
Old 07-03-2006, 07:26 AM   #42 (permalink)
stock4now
you need to use higher octane gas with advanced timing correct?
'97 Nissan SE-R - I,H,T,S,U - Blown and sold.
SHIFT_2.0
still4punk is offline   Reply With Quote
Old 07-03-2006, 07:35 AM   #43 (permalink)
3.5 and loving it
Trader Rating: 16 (100%)
ill try this again...check post 37
johnbrooks302 is offline   Reply With Quote
Old 07-03-2006, 11:27 AM   #44 (permalink)
If you have a dial back timing light you can easily check each mark to see what it's true timing # is.
510n is offline   Reply With Quote
Old 07-03-2006, 12:01 PM   #45 (permalink)
SR20DEbT
I have an old Sears timing light so all I can go by is the timing marks on the pulley. Works though!
Old 07-06-2006, 03:36 PM   #46 (permalink)
Simian Rex
It's necessary to note that not all SR20 crank snouts are marked the same. The pulley on my '94 G20 doesn't even match the marks in the FSM.
-=|JP|=-
CowboyDren is offline   Reply With Quote
Old 08-05-2006, 01:48 AM   #47 (permalink)
The DET is in!
Trader Rating: 17 (100%)
So 19 should be the max I would run on 91 octane? Will have all basic boltons except for header.
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 08-10-2006, 10:17 AM   #48 (permalink)
Simian Rex
Well, you can run up to 22 or 24° without fear of knock, but you won't make any more power than with 19°. You'll actually make less.
And get a header.
Old 08-11-2006, 12:25 AM   #49 (permalink)
SR20DEbT
I have 19* timing with a full WAI and 2.5'' exhaust piping and it really woke the car up. It seems like the car never stops pulling.
Old 08-15-2006, 03:45 AM   #50 (permalink)
out with neck injury :-(
HJBarker's Avatar
too bad I'm having idle issues... maybe I should get the car tuned first, then worry about the timing eh?
This whole "idle at 750-1500 whenever the hell I feel like it, with no rhyme or reason" thing is starting to get really old.
Old 08-21-2006, 03:49 AM   #51 (permalink)
Boosted SE-R
what does adavancing your timing do for performance?
92nissanse-r is offline   Reply With Quote
Old 08-29-2006, 04:02 PM   #52 (permalink)
i'd imagine it would give the air/fuel mixture longer burn time, thus creating more power
sr20wop is offline   Reply With Quote
Old 08-29-2006, 04:38 PM   #53 (permalink)
SHIFT_e
pyrocrickett's Avatar
Yup: earlier BANG = more POW!! Cheapest way to wring out a few more horses from your 4 (if you don't mind runnin' premium, that is)! Could theoretically improve efficiency as well by allowing more time for the fuel to burn more completely, though the more "spirited" driving that is traditionally associated w/more power should offset that a bit
Proud GA16DE Driver No More
Now I'm driving something a little different...
It's more fun to drive a slow car fast than a fast car slow.
pyrocrickett is offline   Reply With Quote
Old 09-02-2006, 12:43 PM   #54 (permalink)
where is the idle adjust screw i cant find it in the manual i got help me plzzzzzz.
nx2000pretuner is offline   Reply With Quote
Old 09-02-2006, 12:44 PM   #55 (permalink)
Honda Employee...
its right by the oil filter, just a flat head screw
-Zack
-'91 SE-R, Aztec Red: JWT Pop-Charger, Fidanza Flywheel, JWT PP w/01 SE disc. AGXs w/GC coilovers (300/279) & C/C plates. NX2K Brakes w/Carbotech pads & Crown SS lines. Progress rear sway bar. Active Tuning RSTB, ES Bushings & motor mounts.
gottabfast is offline   Reply With Quote
Old 10-25-2006, 10:08 PM   #56 (permalink)
fu*k you auto*****s
Trader Rating: 5 (86%)
so. is this the same process for the GA?
fu*k you autoforums.
NismoB14SX is offline   Reply With Quote
Old 11-08-2006, 04:44 PM   #57 (permalink)
ice
Nochnoi Dozor
i changed my idle the other day to 1k flat and after i turned the car off it went back to normal...is there a trink to make it stay there forever?
and if you retard your timing do you get any benefits?
Sleeper: Its what made the Trojan Horse so popular back in the day.
92 Se-r
ice is offline   Reply With Quote
Old 11-09-2006, 06:36 PM   #58 (permalink)
Simian Rex
You can't set the idle that high, I don't think. The computer is only supposed to let it idle in a 100 RPM window (±50 RPM) around a target speed (750-800, depending on model, year, and transmission).
There are three advantages to retarded timing; lower NOx emissions (good in a SMOG state for passing the sniffer test), better idle, and compensation for poor gasoline. But if you're not driving around in Jaurez, the rest of your emissions system is clean (EGR, BPT), and your timing is set to 15° (or even 17° in most cases), there's no reason to worry about knock.
Old 11-10-2006, 03:25 AM   #59 (permalink)
ice
Nochnoi Dozor
im in florida (no emissions! but expensive gas) so i guess ill just advance it since i hear the gas gets more life
Old 12-14-2006, 03:54 AM   #60 (permalink)
The little 2.0 that could
Trader Rating: 16 (95%)
edited=nevamind i downloaded the fsm for my car
b14 5sd= vrs 2.5 catback.exhaust/exedy clutch/5th gen hotshot header/jwt ecu/jwt pop/hot shot intake/es motor mounts/fidenza flywheel 9lb/and soon to come 91 cam and pulley!!
SOME TIMES ITS A PAIN IN DA @SS WONDERING IF THAT'S WHAT CAUSING IT!!
az-ser is offline   Reply With Quote
HTML code is On
