HOW TO: Replace your speedometer cable - SR20 Forum
Old 06-21-2004, 05:48 PM   #1 (permalink)
1998ccs of fury
Feedback Score: 19 reviews
The cable cost about $16.00 from my dealer. I could have gotten it for a little less from Brown & Brown. As for installing it, it wasn't very difficult. Here are some steps:
1) Disconnect the cable from transmission. A pair of standard pliers would be useful.
2) Remove lower dash trim on driver's side.
3) Remove/loosen the center trim panel.
4) Now, you have to remove the trim which covers the instrument cluster. This was the only "difficult" part. You need to disconnect all wire harnesses, and then remove all switches from the trim piece. A small jewler's flat blade screwdriver, and patience, will be useful in getting everything removed. Some switches required using the screwdriver to press a tab on the housing to release the wiring harness connector.
5) Now, slide the trim piece out over the steering wheel, which you should lower all the way. You may need to gently "compress" the piece to get it out.
6) Next, remove the instrument cluster, disconnect the cable, and pull it out from within the engine bay.
7) Slide the new cable in, and then connect it to the instrument cluster, and the transmission. Close everything up.
Source: Jim Wright/Larry Weeks
Old 11-08-2005, 12:31 AM   #2 (permalink)
not fast or furious
Feedback Score: 9 reviews
Just to update folks on this, I bought a new one from a local nissan dealer for $40 USD for my b13. It looks like the price more than doubled since this thread started.
FuelCutOff is offline   Reply With Quote
Old 07-21-2006, 08:31 PM   #3 (permalink)
13.90@104
ya its 32 here in va
2006 mazda tribute
2000 chevy cavalier Z24
92 nissan sentra SE-R (JDM) SR20DET
GTIR turbo kit @ 10psi TMIC13.90@104 on a t25
92SR20DE is offline   Reply With Quote
Old 07-21-2006, 11:13 PM   #4 (permalink)
The little 2.0 that could
Feedback Score: 16 reviews
try 75.00 dollars for a b14
az-ser is offline   Reply With Quote
HTML code is On
