HOW TO: Find your engine bearing numbers - SR20 Forum
Old 08-24-2004, 08:31 PM   #1 (permalink)
I dont know yet but i hope someone will post, I was told its on the crank or rods. But im not sure please post where to find these numbers
sccaITSsentra is offline   Reply With Quote
Old 08-26-2004, 01:02 PM   #2 (permalink)
Nitelife's Avatar
Feedback Score: 46 reviews
Re: Find your engine bearing numbers
I just replaced mine. Apparently the main and rod bearing grades are marked on one of the counter-weights on the crank. I rotated my crank and could not see the markings, so I guess the crank would need to be removed.
I replaced the bearings by pulling the old ones and replacing them with the same part number (Grade 0 in my case). The part number is marked on each bearing half by the "tang"; the last number in the part number designates the grade (0, 1, or 2).
Old 08-26-2004, 01:06 PM   #3 (permalink)
Veritas
SERprise In WV's Avatar
Feedback Score: 17 reviews
The main bearing numbers are engraved/stamped into a pad on the bottom of the engine block. It is only viewable with the upper oil pan off, IIRC.
The rod bearing numbers/main numbers are also (in *some* SR20s) engraved/stamped on the crankshaft counterweight that is for the #4 cylinder, the one nearest the passenger side.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: '93 SE-R with a VE
Old 09-01-2004, 02:26 PM   #4 (permalink)
easy 400WHP
Feedback Score: 36 reviews
To calculate which Main Bearings you need do the following:
Crank Numbers(1st row, 5 #s) + Block(upper oil pan mating surface) Numbers
Example: Crank Reads 11111
Block Reads 12222
you need grades: 23333
Rod bearings are the 4 numbers below the crank main bearing numbers (2nd row)and require no addition just straight up
example: 2121
you need grades : 2121
From what I know the Crank is stamped on the last big counterweight on the rear main seal. The numbers are close to the top of the large lobe of the crank on the side facing the rear main seal. The block ones are tough to find cause they are very little and in the corner. They are on one of the 2 corners that flare out from the block where the upper oil pan(bottom end cover) would go. Hope this helps
~jRod
Old 05-22-2005, 07:18 PM   #5 (permalink)
Missing my SR
On my GTi-R motor, they where stamped on the first counterweight.
Mat
1993 NX2000, 54C, sold.
2003 Mazda Protegé5
Shift_2 is offline   Reply With Quote
Old 09-23-2005, 06:28 PM   #6 (permalink)
bla bla bla
Just an fyi, that is incorrect, all of the bearings are stamped with the same part number, the only way to find out the size of the bearing is to look at the color on the side, have it still in the original Nissan box, or look at the color on the side of the bearing if it is still there.
2003 VW gti 1.8t
72 Datsun 510-sold
Old 09-23-2005, 08:45 PM   #7 (permalink)
Feedback Score: 47 reviews
Here are the numbers in question....
Crank Numbers
Block Numbers
Now the rods are also numbered, on one side is the cylinder # they came from, on the other side of the rod is the grade...
Cylinder numbers (1 & 2)
Grade, in this case 0
Personally Ive never seen a rod with anything other than grade zero, but that doesnt mean other grades arent out there.
Old 09-23-2005, 10:44 PM   #8 (permalink)
easy 400WHP
sh*t I had all 1's homes.. it all depends on the crank...all 4 rods from a given crank should all be the same
Maybe its just coincidence(probably) but all of the older (b13 )sr blocks Ive had seemed pretty linear--as in mostly the same grade all the way accross. I used a B14 SR block and it was all over the place from grade 0 thru 4 or 5 or some sh*t.. dont remember exactly.. dont care anymore its assembled
Old 09-26-2005, 10:45 AM   #9 (permalink)
What im saying is that you have to do the same addition practice on the rod bearings as you do on the main bearings...as with the above photos...
01110 - crank
22021 - block
23131 < main bearings
0000 - crank
0000 - rods
0000 < rod bearings
Old 10-02-2005, 10:32 PM   #10 (permalink)
On Vacation
Feedback Score: 10 reviews
32323 SR16VE Block
12221 DET Crank
44544 Main Bearings
***This is what I got
Manny E.
523 whp & 409 wtq ---RETIRED
SE-Rawkus is offline   Reply With Quote
Old 12-29-2005, 09:52 PM   #11 (permalink)
Wait i have a question. So a brand new motor and a used motor are going to require the same grade rod bearing?? There's some kind of test described in the FSM. I thought that was to determine if you needed some new kind of grade because of wear on the motor. Someone clear this up.
Old 12-30-2005, 08:50 AM   #12 (permalink)
Feedback Score: 4 reviews
Crank Numbers
Block Numbers
So the side on the rod big end with only one number is the bearing grade . Just to clarify Thanks for the detailed clear pics and the math lesson. We are putting an 8 CWT crank in a VE and this helps immensely...no guess work. We do plan to double check with plastigauge though.
Milburn
93' White SE-R. B14 wheels, sunny turn signals, tsuru taillights, NX2000 brake upgrade, Axxiss ultimates...
coolblackser is offline   Reply With Quote
Old 01-01-2006, 04:46 PM   #13 (permalink)
SR's are a fad
always at least measure with plastigauge. too bad bore calipers are so much $$$
rage is offline   Reply With Quote
Old 05-04-2008, 02:51 PM   #14 (permalink)
learning sr20
Feedback Score: 11 reviews
quick ? so if the grade is 0 then all i have to do is order the part number and give them for exaple the grade 0? i dont have to add anything? all im looking to do is replace the rod bearing itself
thanks
1993 SE-R Boosting
BNB squadd ^
Dre240sx is offline   Reply With Quote
Old 08-22-2008, 04:25 PM   #15 (permalink)
Feedback Score: 3 reviews
i got this off my engine......
Block numbers....01111
crank numbers....23222
second row....1121
third row....01070
and on the other side of the crank i saw this number 60J40
here are pics...
Straight1.8 is offline   Reply With Quote
HTML code is On
