HOWTO: 1.6 GA16DE to 2.0 SR20DE/T Swap - Page 2 - SR20 Forum
Old 09-01-2005, 04:12 PM   #21 (permalink)
Weekend Warrior
Feedback Score: 60 reviews
Hey Blaz what axles will I need B13 or B14 2.0?
Old 09-01-2005, 06:17 PM   #22 (permalink)
sr20s are leet skeet
nissanboi's Avatar
Feedback Score: 7 reviews
both same
nissanboi is offline   Reply With Quote
Old 09-01-2005, 10:15 PM   #23 (permalink)
Feedback Score: 3 reviews
yea. what he said. the 2.0-Axles are the same. so whatever you can find B13 or B14 will be fine.
blazin_injun is offline   Reply With Quote
Old 09-11-2005, 10:07 AM   #24 (permalink)
Unlimited Slip
Originally Posted by afrobandito22
some one with more knowledge varify whether or not im right on this, but i doubt if your swap is going to work how you want it becuase the wiring harnesses are different on later motors and they wont plug in. like i think that the b14 motors are obt2 and b13 s are obt 1. so all your electrical systems arent going to work how you want. like i know of someone who tried to put a 94 ser sr20 in a 97 200sx and none of the electrical stuff worked. i might be wrong ***
You are correct. The b13s and only the 95 SER(B14) are OBD I and the 96-98 SERs/98-99 SE(L)s are OBD II.
This thread is an awsome one though. Im gonna put this in my favorites. One project of mine is to create what we like to call here in Ohio, the XE-R.
A four door Sentra XE b13, and throw a SR into it. Bamm... XE-R lol. It will be the sex for a winter beater.
Travis J. Burrell
1999 Sentra SE-L
Some old pics of my SE-L
www.OhioNissans.com
Originally Posted by 2dr_sentra View Post
A rough night at taco bell makes better noise then honda makes.
1999SEL2.0 is offline   Reply With Quote
Old 09-13-2005, 10:49 PM   #25 (permalink)
Revolutionary
I have a BB in a 96 200sx se will a b13 se-r harness work or what do I need to make it work, also do I need a new under dash harness or can I wire it to work and is there anything else I need to know? Thanks - Josh
bottles are for babies, real men get blown
Josht34237 is offline   Reply With Quote
Old 09-14-2005, 08:13 AM   #26 (permalink)
Unlimited Slip
Um? The stock wiring harness should work with the BBDET? A couple buddies and I worked on throwing a BB into a 97 and I dont remmeber the talk of a different harness? Maybe im missing something? Ill let someone else answer that though...
Old 11-07-2005, 05:06 PM   #27 (permalink)
nissanboi's Avatar
what about the generator harness putting a jdm highport in a b14 ga16 equipped car
have the complete engine harness
1.what will need to be done about the alternator
2. will the dash harness need to be replaced
Old 11-07-2005, 06:17 PM   #28 (permalink)
Revolutionary
I didn't have to mess with the altenator harness on mine and if you use a b14 sr20 harness it will hook-up to the under dash connectors. I used a highprot harness and had to rewire all the under dash harnesses
Old 11-08-2005, 02:55 PM   #29 (permalink)
Weekend Warrior
I have a UK sr20de the RARE Red Top which is a Highport. It's a automatic though, I will save the shifting for another project. Called the guys at JGY and they said a STOCK B13 SE-R harness would work from the 91-94 Classics. This swap is RARE because of the auto setup. Been searching about the harness for 2weeks now.
Old 11-09-2005, 11:13 PM   #30 (permalink)
Revolutionary
Yea a regular b13 harness should work, there will be some plugs that have no place because of the lack of egr and such
Old 11-16-2005, 12:29 AM   #31 (permalink)
attesa by nismo
u guys sound like u know a lot here is the thing i know to do the mechanical part of the swap but i have no idea about wiring it where can i get wiring diagrams by the way its a 96b14 ga1.6 to a sr20det or can i get an already assemble harness
kalonji is offline   Reply With Quote
Old 11-16-2005, 08:51 PM   #32 (permalink)
Revolutionary
use the b14 sr20 harness switch over sensors from a lowport sr20 and if your going to use the det ecu make an adapter, I think its nissanforums.com that has a sticky to do so. If not you can try rewiring the under dash harnesses like I did using a b13 harness, I did it cause I didn't what to have get all the lowport sensors and make an adapter, but its a bitch!
Old 11-18-2005, 04:53 PM   #33 (permalink)
Weekend Warrior
Heads up for all people interested in doing a swap with a AUTOMATIC. If you get the HIGHPORT sr20de, the harness and ecu will be hard to find! You have to remember that they only made THREE YEARS of the HIGHPORT motor "91-93" and the "93" model is the only year they made it in a AUTOMATIC. Some people say it came in a "91" model as well, but why wouldn't they just make'em in all three????
Anyway bought to drop the UK RARE RED TOP in real soon!!! Also purchased a LOWPORT sitting in my storage building right next to my UK BEAST!!! Didn't know which one I was going to go with so i just got the BEST OF BOTH WORLDS!!!!
Old 11-19-2005, 12:19 PM   #34 (permalink)
is the shiftting link the same on the GA16DE and on the SR20DE
spoon is offline   Reply With Quote
Old 11-20-2005, 10:14 PM   #35 (permalink)
SR20 Freak
Spoon, Yes i believe the linkage on GA and SR are the same
96' 200sx SE-R (NOS)
96' 200sx GA (Avenir Project Completed)
sr24_T is offline   Reply With Quote
Old 11-25-2005, 10:56 PM   #36 (permalink)
Hi everybody
My friend have a 1995 200SX 1.6 liter and we have buy a NX2000 for the trans,
Do you think that those motor mounts are the same?
Those axle are the same ?
Thanks for your help
Fred
tryskriel@hotmail.com
tryskriel is offline   Reply With Quote
Old 11-25-2005, 11:17 PM   #37 (permalink)
**GIZMO**
the motor mounts between the b13 & b14 sr20 are the same but since you are going from a 1.6 to 2.0 you will need the tranny mount, rear mount (might be the same dont remember), pass. side and the front dog bone is the same hope this helps
99 i30- lowered on 20's, jdm evolution kit
02 sv 650s- v twin scorpion high mount full fairing candy blue
07 RX8 turbo-apexi coilovers, mazdaspeed body kit, 19x9.5 all four corners
se_nismo is offline   Reply With Quote
Old 01-04-2006, 12:34 AM   #38 (permalink)
Retired for now...
Feedback Score: 21 reviews
Okay i got a blown 98 200sx se and i just ran across a good deal on a blue bird. Ive been piecing it together, only trouble im running into is the ECU and Wiring. So do i get a 96-98 Engine Harness along with 96-98 Interior harness and Cluster and a 96-98 ECU MT since im getting a manual tranny. Or can i do b13 ecu and harnesses....??What about hooking up to my cluster with the b13 harness, is it just simply splicing?
Thanks
were a community not a ad site.
U12BBDreamer06 is offline   Reply With Quote
Old 01-04-2006, 10:04 PM   #39 (permalink)
Revolutionary
does the car not have an interior harness? it really should already have that harness in it. you need to get a b14 harness, it will hook up to all the interior plugs and will pretty much hook up to the engine with little problem, if you use the bb maf you'll need to swap the plugs on the harness and you'll also need to swap the coolant sensor. On the ecu you can either get a b14 ecu re-programed or run the bb ecu, either one helps to be manual but doesn't have to be.
Old 01-04-2006, 10:40 PM   #40 (permalink)
Retired for now...
It has 1.6 b14 interior harness in it now, Just thought i had to switch over to the 2.0 harness. As far as ecu which one is easier to run. I was thinking a US SR20DE ECU since it seems to work better...(from what ive read). But does it have to be re programming? i know that could take a month or two.
HTML code is On
