HOWTO: 1.6 GA16DE to 2.0 SR20DE/T Swap - Page 3 - SR20 Forum
Old 01-04-2006, 10:54 PM   #41 (permalink)
Revolutionary
interior harness is the same, if you run turbo you have to run a det ecu, or it will run like crap, believe me I know, but the easiest thing to do is get a bb ecu and make an ecu adapter or get coalationse-l to make you one, with ecu and adapter you'd pay around $350 and hardly no waiting and if you go with a re-programed ecu you're going to pay around $500 to $600 and all the waiting.
bottles are for babies, real men get blown
Josht34237 is offline   Reply With Quote
Old 01-26-2006, 08:14 PM   #42 (permalink)
still working on it...
my bad. let me just move this for you guys...
afrobandito22 is offline   Reply With Quote
Old 02-20-2006, 02:25 AM   #43 (permalink)
good thread.
franky is offline   Reply With Quote
Old 02-20-2006, 11:27 AM   #44 (permalink)
98 SE
Feedback Score: 9 reviews
Originally Posted by se_nismo
the motor mounts between the b13 & b14 sr20 are the same but since you are going from a 1.6 to 2.0 you will need the tranny mount, rear mount (might be the same dont remember), pass. side and the front dog bone is the same hope this helps
This is correct for the mounts ex. the rear one. I just used my stock one.
The axles though you will need to get 2.0l axles to work with the new tranny, the GA16DE ones are different.
Old 02-20-2006, 12:40 PM   #45 (permalink)
Retired for now...
Feedback Score: 21 reviews
Anyone run into problems with the clutch cable??? I got a 1.6 and a 2.0 cable both in good condition and pedal is falling to the floor.
Another thing anyone have a problem with the jpipe hitting the dogbone on the u13 with frontmount?
were a community not a ad site.
U12BBDreamer06 is offline   Reply With Quote
Old 02-20-2006, 12:45 PM   #46 (permalink)
Whut?That Ain't No Hondah
Feedback Score: 5 reviews
The dogbone mount is a well known issue, search on the forum for how to fix that.
Alot of the SR20 guys switch to the 1.6 clutch cable to get more adjustment and I run the 2.0L clutch cable. Both should work fine. Are you sure its hooked up properly to the back of the clutch pedal?
1990 2+2 TwinTurbo 300zx
1.6 to DET Swap
Engine Removal Writeup
Crim is offline   Reply With Quote
Old 03-05-2006, 03:46 PM   #47 (permalink)
98 SE
Originally Posted by grizz00
ok i dont understand how to connect the harness that is near the battery....it(2.0) has 3 connections meanwhile the 1.6 has 2 connectors, can the big connector be pluged into the matching connector on the 1.6 harness???? i know that one of the connectors is for the starter, no problemo, but the other two i need some help on.
I want to know why no one answered this guys question. Since I happen to have the same dilemna at the moment.
The large connector hooks right up, the 2 smaller ones (2.0) don't match up. Although one has two black/white wires which I'm guessing I meld together hook into the connector off the old 1.6 harness. That leaves an open connector that is part of the power system, not just sensors left open.
Old 03-05-2006, 06:25 PM   #48 (permalink)
Retired for now...
pics would probably help ...im doing my swap and i hard wired one wire on the power harness....and others plugged in...i think i got a couple sensors hanging out but i dont htink there required at least not for my setup...
Old 03-05-2006, 10:42 PM   #49 (permalink)
98 SE
I put both wires together as I said and it turned over, but backfired only backfired once.
I did take pics for others to see though so it'll help a little bit.
This is the one I pilfered from my GA harness so it was easier to work with than hardwiring.
Old 03-05-2006, 10:53 PM   #50 (permalink)
Revolutionary
there should be just one black and white wire in the one and then a black and white wire and another wire in the other. connect the two black and white's and it should be fine, I think the only thing it does is reverse lights or some sh*t anyways.
Old 03-06-2006, 02:52 AM   #51 (permalink)
When I had plugs left over, I just used some common sense to splice stuff together. If the colors on the wires matched, they got spliced together. If two plugs had all thicker black ground wires, I just clip'd the plugs and spliced em. Other then that, I left everything else dangling.
Old 03-06-2006, 03:16 PM   #52 (permalink)
Retired for now...
man my car wont turn over....what should i start checking all the harness and connectors...i got lights and interior lights....dreaded beeping noise when door is open....fuel pump comes on.....dead in the bay though!!!???
Old 03-06-2006, 03:22 PM   #53 (permalink)
98 SE
did you swap those plugs that I took pictures of? Mine did what you are describing before doing that...
Old 03-06-2006, 07:29 PM   #54 (permalink)
Retired for now...
hmmm....it wasnt a thick black wire with a white stripe down it was it...i hard wired that one in.....let me study your pics...
Old 03-08-2006, 12:57 PM   #55 (permalink)
Retired for now...
i have that one hooked up.....so its not that....
Old 05-08-2006, 10:38 PM   #56 (permalink)
slave to the grind
TOOQIKK's Avatar
Feedback Score: 33 reviews
i have a 91 xe that im going to swap everything from a 93 nx2000 into and i want to swap the dash....what is envolved to get it to work?
94-XE 4D.... boost in the near future...stay tuned....
THE WEBSITE for all your synthetic oil and filter needs...AMSOIL First in Synthetics
Old 05-10-2006, 05:34 PM   #57 (permalink)
Revolutionary
Just unbolt it and swap them out, make sure the vents get hooked up when you do it though.
Old 05-10-2006, 05:40 PM   #58 (permalink)
Weekend Warrior
Feedback Score: 60 reviews
^What he said......and a little help wouldn't hurt to speed up the process unless you picky.....
Bend But Don't Break
Old 05-10-2006, 05:40 PM   #59 (permalink)
Retired for now...
if its just the cluster youll be fine but if its the dash prepare for some work. I just did mine, You need a T50H bit from (napa) to take off the air bag to get the dash out. Other than that happy plugging.
Edit : I suck at typing
Old 05-10-2006, 07:28 PM   #60 (permalink)
Revolutionary
B13's don't have passenger side airbags, DUMB ASS!!!!!!!
HTML code is On
