HOWTO: 1.6 GA16DE to 2.0 SR20DE/T Swap - Page 6 - SR20 Forum
Old 11-01-2006, 02:21 PM   #101 (permalink)
SR20DEtroit
Feedback Score: 10 reviews
Originally Posted by maximumyin
Sonny and U12BBDreamer06, big props for the ideas/help! I'll let you know what happens.
Same here 200SX base. No power windows, locks, cruise, ABS, nothing...
Nice... also, your fuel pump may need to be directly primed... that was the problem that U12BBDreamer helped me out with.
sonny is offline   Reply With Quote
Old 11-03-2006, 12:02 PM   #102 (permalink)
Looking for anoter SR
Feedback Score: 14 reviews
How did you end up fixing that issue? Do you still remember?
1992 240SX SE Fastback - Sold
1998 200SX 'XE-R' - Totaled
1987 RX-7 Turbo II - Sold
2000 Impreza 2.5 RS Sedan - Sold
2004 Impreza WRX STi
maximumyin is offline   Reply With Quote
Old 11-03-2006, 12:21 PM   #103 (permalink)
Retired for now...
Feedback Score: 21 reviews
supply direct power to the pump.....it will kick it on...becarefull cause fuel will go flying.....ask me how i know..
U12BBDreamer06 is offline   Reply With Quote
Old 11-03-2006, 09:50 PM   #104 (permalink)
Im Not A Chick
Feedback Score: 5 reviews
hey did you get to use your power stearing? cause the sr20 line will not bolt on to the hard line of the GA. the bolt is way to big!!!
jen36 is offline   Reply With Quote
Old 11-04-2006, 11:51 AM   #105 (permalink)
Retired for now...
nope i didnt....im taking it to a shop to fab it up...
Old 11-05-2006, 12:17 PM   #106 (permalink)
Im Not A Chick
never mind... it does work! i got the rubber line that goes from the strut tower to the motor from a g20 and wow its diffrent from a nissan SeR the g20 lines are hollow on both ends were the bolt goes on and the bolts are the same size on each end which are huge... and will not match up to the hard line fitting near the resavore(how eva you spell it)which takes a smaller bolt(like the GA bolt)
the Ser line has the smaller fitting in the top and and is threaded which will go on the GA braket that holds the line and will match up with the smaller bolt needed to the hardline ! the other end is the bigger bolt which will go to the motor ! YES I HAVE POWER STEARING ! lol....
Old 11-21-2006, 07:50 PM   #107 (permalink)
Well it looks like I got almost everything working. There's still a bunch of plugs hanging around... but... what are you gonna do? In any case I don't have a plug to go into my power steering. So it works... ALL the time. Kinda weird on the highway, but not undrivable in the least. However I am getting a CEL. To make matters worse the consult port is not giving me anything. I have inspection in December and a CEL in NYS is an automatic FAIL. Help anyone?
Old 12-01-2006, 02:50 PM   #108 (permalink)
The DET is in!
Feedback Score: 17 reviews
I just did this swap. My speedo, odometer, and reverse lights don't work. Did anyone else have this problem? Looking at my LE-R (LE SR20DET ) I only see 2 plugs mounted to the driver side fender (above the tranny). When I look at my donor SE-R however, I see three plugs and the harness is thicker on it too. WTF?
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 12-01-2006, 04:38 PM   #109 (permalink)
Im Not A Chick
i *** everyone does 5 speed swaps but does anybody *** if the tranny mount from a automatic GA16 will work with the automatic ser?
Old 12-06-2006, 06:58 AM   #110 (permalink)
Awsmome write-up
Blackbob is offline   Reply With Quote
Old 01-14-2007, 10:38 PM   #111 (permalink)
SR20 ENTHUSIAST
No.
Chris
B13Sentra2DR is offline   Reply With Quote
Old 01-14-2007, 10:48 PM   #112 (permalink)
Im Not A Chick
speak for yourself i made that bitch work lol....i tried the auto Ser mount and 5 speed auto mount which seems to be the same mount on the Sr tranny n e ways but none of them work.. but now that i think bout it, it prob didnt work cause its a g20 tranny. but what i dont understand is that the holes are there for both g20 and sentra mounts???
Old 03-07-2007, 02:44 PM   #113 (permalink)
Luke Pighetti
Taiden's Avatar
Feedback Score: 3 reviews
Hey Crim, what did you do for the gauge cluster? I started repinning my XE harness when I realized that there are three Yellow/Green wires and three Black wires, each one having a seperate use.
Thanks man.
Old 03-10-2007, 12:34 AM   #114 (permalink)
AWD owns me
Jaketips42's Avatar
Feedback Score: 12 reviews
Did you get that done?
Sporting the GC awaiting EJ20T
____________________________________GC Pilot
Subaru stole me from Nissan
Old 03-10-2007, 11:23 AM   #115 (permalink)
ga16*****.com
Feedback Score: 31 reviews
Not alot of people do 5speed swaps, they find a manual ga16 car and swap that, its much easier.
1997 200SX SE-R - 280whp & 264tq
"Shut the fu*k up and sit down"
Old 03-10-2007, 12:59 PM   #116 (permalink)
Luke Pighetti
Taiden's Avatar
Nope, I'm in a bit of a bind. I almost think the colors don't match, because when I have ONLY the matching colors plugged in, I have the same problem you were having.
I think it's time for me to find a member parting out a 91-92 XE to snip his gauge cluster wires and mail them to me.
Old 04-26-2007, 01:13 PM   #117 (permalink)
Hey guys, i read the posts here ... and am just looking for a straight forward question.
i plan on swapping out the GA16DE from my '92 NX 1600 .
I plan on Swapping IN the SR20DE from parts car '92 NX 2000
Everything should bolt up ? From what i've gathered, the 2.0 axles need to be swapped, the rad , rad fan also. What else ? mounts ect? And the digital dash from the 1.6 will work ? .
Sorry for being a pain in the ass, swap is going in next weekend if all goes well.
Thanks in advance.
swigger is offline   Reply With Quote
Old 04-26-2007, 03:14 PM   #118 (permalink)
fugg it
Thanks in advance.
don't forget shift linkage. but yes, everything from the nx2k will bolt up to the nk1600
94 b13 sentra - sr20 swap in the works.
Originally Posted by HkSBlueBird4u View Post
recall on ball joints... seems the water seeps into them corrodes them an after a while youll get sloppy or barely any steering... this could cause a blonde girl to die somewhere in the world
bad news is offline   Reply With Quote
Old 04-26-2007, 04:27 PM   #119 (permalink)
Throttle cable too, the GA one works, but it's about a quarter inch longer than the SR one, leaves a lot of slack.
Old 04-26-2007, 04:46 PM   #120 (permalink)
So the mounts have to be changed ?
thanks a million, couldn't have gotten a quicker response.
Last edited by swigger; 04-26-2007 at 04:49 PM. Reason: didn't want to double post.
HTML code is On
