HOWTO: 1.6 GA16DE to 2.0 SR20DE/T Swap - Page 7 - SR20 Forum
Old 05-10-2007, 01:54 AM   #121 (permalink)
Calum Supporter
Feedback Score: 23 reviews
so do i get this right the 2.0 harness plugs right into the 1.6 harness
NewEnglandSR20's / Noise-O Fabrication
Originally Posted by Jackson Diamond View Post
You have no idea what you are spouting here. The welds in the picture are amazing. It aluminum, its not gonna weld like stainless.
fu*k it, I am waisting my time replying to you. You are a idiot and thats that.
G-Unit91 is offline   Reply With Quote
Old 05-14-2007, 10:53 PM   #122 (permalink)
Rockin' the GA
This is a great thread btw . Im interested in doing the swap but my nx is my daily driver so taking the time to do it is a big commitment. I assume it might take a week if everything goes without a hitch. Can any one make a list of the parts needed for the swap?
Nx1600man is offline   Reply With Quote
Old 05-17-2007, 10:27 PM   #123 (permalink)
from what i got ...
Radiator
Rad fans
Axles
shift linkage
only thing im uncertain about is the mounts. Can someone clarify ?
swigger is offline   Reply With Quote
Old 05-18-2007, 09:22 AM   #124 (permalink)
Looking for anoter SR
Feedback Score: 14 reviews
Yes you need the sr20 motor mounts the ga16 ones will not work.
1992 240SX SE Fastback - Sold
1998 200SX 'XE-R' - Totaled
1987 RX-7 Turbo II - Sold
2000 Impreza 2.5 RS Sedan - Sold
2004 Impreza WRX STi
maximumyin is offline   Reply With Quote
Old 05-18-2007, 09:22 AM   #125 (permalink)
Also... I don't see sr transmission on your list, lol.
Old 05-27-2007, 10:38 PM   #126 (permalink)
Boost is fun!
so the ga16 shift linkages wont work with the sr20 tranny?
AznFreakyGuy is offline   Reply With Quote
Old 05-28-2007, 12:51 AM   #127 (permalink)
It'll work, but it's really ghetto, the throws are extra long and the shifter is pushed back like 3-4 inches too far.
Old 05-28-2007, 06:53 AM   #128 (permalink)
The DET is in!
Feedback Score: 17 reviews
Mine works fine... No different then when I had the SE-R up an running.
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 05-28-2007, 02:31 PM   #129 (permalink)
Retired for now...
Feedback Score: 21 reviews
x2 same here...
were a community not a ad site.
U12BBDreamer06 is offline   Reply With Quote
Old 05-28-2007, 08:04 PM   #130 (permalink)
Boost is fun!
another quick question lol, just want to make sure, do any sr20 mounts work? or do you need the mounts from the same chassis, like b13 mounts in a b14, are they the same? also *** about teh shift linkage, chassis specific or all the same?
Old 05-31-2007, 10:31 AM   #131 (permalink)
Retired for now...
I have nx2000 and b13 sr20 motor mounts in mine...but i had pthanes pressed into them, and they stick out a lil bit...so its a lil more work but worth it.
If you have a 1.6 manual you can use the tranny and rear...some say you cant but i did and it works just fine...
Old 05-31-2007, 09:00 PM   #132 (permalink)
Built not bought
Feedback Score: 8 reviews
i just got a 94 xe auto olready put 2.0 in
with shift linkage
and harnest
and pedales it has 49005 on the odometer im trying to figure out a few thing about the interior harness i am trying to put in a 92 se-r interior harnest into the 94 xe any type of info about the 92 se-r harness going into the 94xe body would be appreciated only thing i am stumped on for the moment cant sceem teh get skimatics for both harness's
^^ BUILT BY BOLT^^^
Nyc Home of the greatest !!!!!!!!!!!!!
Nissanwulf is offline   Reply With Quote
Old 06-01-2007, 12:50 AM   #133 (permalink)
1.6 3/25/06 VE 7/11/06
Feedback Score: 25 reviews
dont worry about the interior harness, you dont need to change that. plus you dont even need to get a sr20 ecu harness, the ga16 harness works just fine.
bj200sx is offline   Reply With Quote
Old 06-01-2007, 01:28 AM   #134 (permalink)
Built not bought
well thier is also another ssue with the cluster it is being changed for the se-r cluster b/c the xe was auto everything has been switched over from and se-r but to switch over the tack the 94 has electrical clusted and s-er clusted is a manual talking abou the speed and conectors, me and splicing done get along very well along with frustration just trying to find the best way to get situation worked out
Old 06-01-2007, 01:34 AM   #135 (permalink)
ok so yeah it might be easier for you to get it all. good luck
Old 06-01-2007, 11:42 AM   #136 (permalink)
Retired for now...
you really used your ga16 harness?? no problems at all??
did you use sr20 sensors and ga16de cluster???
Brian
Old 06-01-2007, 05:32 PM   #137 (permalink)
yeah i used my ga16 harness. no problems at all. yes i used my ga16 cluster tell like weaks ago i upgraded to an sr20 cluster just because i kept pegging out the ga16 speedo.
Old 06-01-2007, 05:35 PM   #138 (permalink)
Brian
Yep, I did too for a few months, worked 100%...
Old 06-07-2007, 11:55 AM   #139 (permalink)
Retired for now...
What speedo sensor you using...if ur using a 1.6 with 2.0 cluster it wont read right. or vise versa.
Old 06-07-2007, 11:58 AM   #140 (permalink)
Retired for now...
Also i think i found out why people are having a hard time with the shifting linkage...
i used 1.6 tranny mount and rear mount with the linkage...im thinking when you switch to the sr20 rear mount the hole that bolts up to the bracket is positioned differently. therefor having problems getting in and out of gear...
HTML code is On
