HOWTO: 1.6 GA16DE to 2.0 SR20DE/T Swap - Page 9 - SR20 Forum
Old 10-28-2007, 08:51 PM   #161 (permalink)
Built not bought
Feedback Score: 8 reviews
does that one plug over the gearbox plug into any plugs from the 3 and also u might need 92 g20 interior harness not too sure add information that could help me help u, if i can.
^^ BUILT BY BOLT^^^
Nyc Home of the greatest !!!!!!!!!!!!!
Nissanwulf is offline   Reply With Quote
Old 10-29-2007, 07:11 AM   #162 (permalink)
Yes, one of them fits but the wires isn't the same. Wrong colors and one wire that goes to the starter is placed wrong in the sticker.
I'll try to look at a 92 G20 and see how it looks there.
I have the interior harness form the NX200 but I'm afraid it wouldn't fit in my P10.
Thanks for the answer.
Bullit_90 is offline   Reply With Quote
Old 01-28-2008, 04:43 AM   #163 (permalink)
Nissan Bluebird U13
Hi,
I have a 1995 model U-13 Nissan Bluebird which has a SR18DE engine. I want to interchange this engine with a SR20DET. Can you kindly advice if this is possibble? Are the ECU harness compatible?
Thanks,
Harry
Harry Thuku is offline   Reply With Quote
Old 01-28-2008, 11:39 PM   #164 (permalink)
Smoke-son
Tranny wiring for the Ser!
Need help, I have a 97' 200sx se. And I started swapping in my Pulsar Gtir motor from my front clip. I'm using everything from the jdm clip, except the awd transmission. I got just about everything from the usdm Ser. From tranny to motor mounts.The problem I'm having is the jdm transmission harness is different the usdm harness. Does anyone know how to wire this up?
smoke153 is offline   Reply With Quote
Old 03-05-2008, 03:51 AM   #165 (permalink)
So I have a 96 200sx se-r engine, it has a sr20de engine in it, 5 speed. I want to swap in a bluebird sr20det engine. My question is how easy will it mount up, what problems may I face, was it a JDM or JGY engine used?
p2005_16 is offline   Reply With Quote
Old 03-05-2008, 03:58 AM   #166 (permalink)
I am thinking about doing the sr20det swap into my 200sx se-r. Does anyone know of a good site to purchase an engine from?
Old 07-15-2008, 02:38 PM   #167 (permalink)
Weekend Warrior
Feedback Score: 60 reviews
Bend But Don't Break
Old 09-15-2008, 02:48 PM   #168 (permalink)
sr20det inquirer
Feedback Score: 21 reviews
does anybody knows if i can use the ga compressor on the sr?? maybe with a sr bracket?
Do not go where the path may lead, go instead where there is no path and leave a trail.
92_sEnAtRa is offline   Reply With Quote
Old 09-15-2008, 04:19 PM   #169 (permalink)
Weekend Warrior
^No. It won't work.
Old 05-04-2009, 12:06 PM   #170 (permalink)
sr20det inquirer
bringing this from the dead. sorry
Ok, i have a 92 e model and im going straight to VE a lil more work but i understand, now from what i've been reading...can you use the GA harness on the SR?
i got access to a p10 sr20 harness,but its an auto, will it work??? extra plugs?
Old 05-05-2009, 12:23 PM   #171 (permalink)
[QUOTE=1999SEL2.0;1199604]You are correct. The b13s and only the 95 SER(B14) are OBD I and the 96-98 SERs/98-99 SE(L)s are OBD II.
This thread is an awsome one though. Im gonna put this in my favorites. One project of mine is to create what we like to call here in Ohio, the XE-R.
A four door Sentra XE b13, and throw a SR into it. Bamm... XE-R lol. It will be the sex for a winter beater.[/QUO
Hey man, I have a '96 200sx se doing the sr20de swap from a '95 se-r. I don't know much about the OBDI and II. Am I going to run into differences? I have everything for the swap from the '95 (except radiator and maybe one axle from a wreck front motor mount was bad, the car shook while driving). I also have read this how-to and the threads up to here. Response would be appreciated.
P.S. I always thought an XE-R would make anybody that knows about nissans scratch their heads when "that cheap thing flies!"
boothsinva is offline   Reply With Quote
Old 06-10-2009, 05:09 PM   #172 (permalink)
#TranceFamily
Feedback Score: 4 reviews
since its rare finding sr20 powered B13/NX2000/B14's in my local pick your part. I have more luck with finding p10's. Would I be able to use the axles from a p10?
http://i6.photobucket.com/albums/y20...0/P11SR20B.jpg
99 G20 5-Spd SoCalG20
MODS: Injen CAI, OBX Header, Stillen Sport rotors, Custom FSTB, Octotat RSTB, Tein SS, 02 Sport Headlights, 2.25" Exhaust, Remus Muffler, B&M SS, Carbing Lower Arm Bar, Greddy GR-3, Mautai916 Grounding Kit, Brian Crower Stg. 2 Cams, Greddy Cam Gears, Greddy RAS, and more to come...
818_99G20 is offline   Reply With Quote
Old 12-07-2009, 02:33 PM   #173 (permalink)
i also used my ga16 harness *** i swapped my sr20 my sr harness actually didnt work so i had to use the ga16 harness
srb13 is offline   Reply With Quote
Old 01-06-2010, 12:08 AM   #174 (permalink)
Hello im in the midle of my proyect XE-R i'let you guys know.
B12NISMO is offline   Reply With Quote
Old 02-09-2010, 01:10 AM   #175 (permalink)
Don't deny Jesus Christ
Feedback Score: 12 reviews
If I have a 93/94 b13 4door 1.6 and I plan on doing the sr swap, how would I go about using a 91/92 b13 Ser harness as far as the guage cluster goes?
My HUGE FOR SALE THREAD with parts screaming, "Buy me!" Hahaha
http://www.sr20forum.com/cali/272387...isc-parts.html
One day for God is a thousand years for us.
Mr. Sleeper is offline   Reply With Quote
Old 12-20-2010, 11:49 PM   #176 (permalink)
#TranceFamily
So my list of collecting parts for the swap is getting bigger little by little lol.
Since Courtesy Nissan parts has the best parts diagrams that I can use as a refrence and compare to which part I need or re-use for the swap. I have been hunting my parts from the junkyards and been getting lucky so far.
I have a manual 4-speed m/t GA by the way.
Did anyone use the same transmission mount? I see no difference in both GA & SR mounts.... I have both mounts next to each other to compare and look the same. Courtesy Nissan gives a different part number and listed specificly to that certain year/model.
I also have a spare P10 Passenger side motor mount. Can I use it? Looks like it will fit for the SR swap.
Old 12-29-2010, 03:51 AM   #177 (permalink)
Whut?That Ain't No Hondah
Feedback Score: 5 reviews
Fixed the broken image links here: http://www.sr20-forum.com/forced-ind...0det-swap.html
I tried to edit my post but it stripped all of the links and highlighting... fail.
1990 2+2 TwinTurbo 300zx
1.6 to DET Swap
Engine Removal Writeup
Crim is offline   Reply With Quote
Old 12-29-2010, 08:41 AM   #178 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
That's funny. I look at the saved version, and all it shows is that you removed the links. I'm sure you did your best.
The community is here.
Old 12-29-2010, 02:16 PM   #179 (permalink)
I copied and pasted in my updated post which had all of the links fixed. Does this forum use different VBB codes for links then other vb forums? Basically it threw away all my links when I hit save. I'll go thru and manually re-add them again sometime soon, its a pain in the butt.
Also this forum is balls slow these days
Old 12-29-2010, 03:56 PM   #180 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 109 reviews
All the links in your original post go to dead sites - http://sr20.darksci.net & http://www.atl-sr20.com
Next time the forum is slow, take a look at the status bar, and tell me what it's waiting on, and I'll work with support to get it worked out.
HTML code is On
