HOW TO: Remove upper timing chain guide - SR20 Forum
Old 08-28-2004, 02:02 AM   #1 (permalink)
Coropate greed hater
Feedback Score: 3 reviews
Some SE-R owners have had an issue with a metallic rattling noise at idle when the motor is hot. Usually, this rattle is attributed to two things: either the timing chain tensioner, or the upper timing chain guide.
This write-up is catered to showing you how to remove the upper timing chain guide in case this noise comes up.
To begin, start removing the valve cover bolts. Also remove the bracket that holds the cruise control cable and the crankcase ventilator.
This is the timing chain guide. Over time, the timing chain starts hitting this guide, therefore causing the rattle at idle.
Start removing the two bolts that hold the timing chain guide.
Remove the timing chain guide.
Make sure this is what you take out.
No more timing chain guide!
After having removed the timing chain guide, I noticed that there were deep grooves that were made on the underside of the guide. This most likely happened due to the timing chain hitting the guide for a long, long time.
Now that the timing chain guide has been removed, start closing up the motor. Make sure you don’t have any extra bolts sitting around! Also remember to torque down the valve cover bolts to the correct specifications as outlined by the Factory Service Manual.
Have fun driving your car rattle-free!
-The Usual Suspects
Old 08-31-2004, 11:16 PM   #2 (permalink)
BOOSTIN PROTECH STYLE
Re: How to remove upper timing chain guide
So, there are no repercussion for removing this item? Interesting, thanks for the detailed write up Harris.
Mike Collins
PROTECH FABRICATION
Myspace
"Protech - Making the highest quality products the right way, the first time every time."
PSSSHHHGOESMYSR20 is offline   Reply With Quote
Old 08-31-2004, 11:51 PM   #3 (permalink)
jet black se-r
I just did this to my car last week ,It was making a loud rattle removed the chain guide which had grooves from the chain hitting and put on a new powdercoated valve cover while I was in there . Looks perfect and sound quiet and perfect as well no bad side effects. Thanks Rick
frank is offline   Reply With Quote
Old 09-01-2004, 08:10 AM   #4 (permalink)
Born to boost
Feedback Score: 14 reviews
Good tip on this, be careful and pay attention when taking the bolts of guide out. I dropped one down into the timing chain itself, and was a pain getting out. I had to use a magnetic tip thing to fish it out. Wasnt really easy, and hard to find. So I would stuff a rag or something in that area next time I ever do this again.
96 200sx SE-R the new daily
92 Black Classic 12.164 @ 112.85mph -290whp/340wtq - **RIP**
blckse-r is offline   Reply With Quote
Old 09-13-2004, 12:15 AM   #5 (permalink)
No repercussions at all. I have been told that Nissan stopped putting them on the SRs in '98.
Old 09-20-2004, 02:30 AM   #6 (permalink)
0-60 Sub 5 Seconds
mine doesnt have one - mine is a 98 uk sr20
Living the Dream in the GTI-R
Whooooooomp Tiiissshhh Chatter Chatter
GrayGTi is offline   Reply With Quote
Old 09-23-2004, 10:06 PM   #7 (permalink)
RepnE.N.Y.Brklyn
would it be a good idea to put the bolts back in after removing the guide, instead of leaving to holes for oil to collect in? or does it not really matter??
'91 se-r,
BB sr20det, T25 turbo, Jwt ecu, jun flywheel, carbon/kevlar springload 6 puck clutch, blitz b.o.v, apexi avc-r, Apexi Turbo timer, Msd sci, Msd blast coil, Vrs 2.5 turbo back exhaust, Apexi n1 turbo muffler, Nismo shift knob, Nismo steering wheel, B&M short shift, autometer gauges, ground control/kyb suspension
http://img.photobucket.com/albums/v3...nismowheel.jpg
brklyn is offline   Reply With Quote
Old 09-27-2004, 03:21 PM   #8 (permalink)
SR20DE to 4G63T
anyone know the torque numbers for the bolts on the valve cover?
Boo Radley is offline   Reply With Quote
Old 09-28-2004, 01:41 PM   #9 (permalink)
Its 36-in. lbs., IIRC.
Old 01-10-2006, 09:02 PM   #10 (permalink)
Im a GA16DE guy with a 94 Sentra, just out of curiousity, do you know if the case of the guide rattling is the same in my engine? i have an annoying rattle up to about 3k rpms unless i am more than about 25% throttle. Over 25% or 3k and it stops. Just curious guys.
Bullitt is offline   Reply With Quote
Old 02-07-2006, 12:35 PM   #11 (permalink)
nice informational writeup, but no more pics.
yeah, my car is a 98 SE and I don't have one. but I have other issues like a crap ECU and open diff trans
as for the GA16, there could be a bunch of things that cause that, first of all the GA16 is a mechanical lash valvetrain, you may need to have that adjusted, hopefully you won' t have to get new rockers or cams, but ususally you hear lash the most when the car is cold and through all RPMs.
another thing is that the GA uses TWO timing chains (which means even more chain tensioners) and has a VTC (variable timing cam) solenoid on the intake cam.
to troubleshoot the source, first figure where the sound comes from (under the valve cover, or on the front of the engine where the timing chain is ).
I believe that servicing the timing chain requires an engine pull and is not cheap. valve lash services are relatively inexpensive.
Finally, this is SR20FORUM.com not GA16DEforum.com. jk. But really relatively few of us know anything about the GA, don't ask me where else you could go to ask this question ***. perhaps nissanforums.com
check this out... http://nissanforums.com/showthread.php?t=60760
98 SE with a B15/P11 trans and hydraulic clutch... SOLD =..(
98SE(-R) is offline   Reply With Quote
Old 02-12-2006, 09:02 PM   #12 (permalink)
Originally Posted by 98SE(-R)
but no more pics.
Fixed.
Old 02-23-2006, 02:36 PM   #13 (permalink)
JDM BOOST WHORE
SR20 91 SE-R's Avatar
Feedback Score: 12 reviews
dose anyone know if the avenier's have them? i dont wanna take off my vc if it dosent have the guide.
SR20 91 SE-R is offline   Reply With Quote
Old 02-25-2006, 02:15 PM   #14 (permalink)
Jah Rastafari
Feedback Score: 61 reviews
This is not to be done to an older SER with the old school tensioner.
If you do the mod please get a 98-01 SR20DE tensioner.
If you do not get the new style tensioner you can and will skip a tooth on the cam gears.
Old 02-25-2006, 10:58 PM   #15 (permalink)
Feedback Score: 4 reviews
not sure about the 93-94 low port motor, but the 95 and up sr20 brings the tensioner you are looking for.
THE VE-T IS ALIVE.
-92 sentra vvl-t 470whp...385tq. 24lbs.
-98 sentra SE/ sr2ve powered.
-2005 c230 kompressor.
-2006 Lancer Evolution 9 MR.
http://images.cardomain.com/member_i...66_28_full.jpg
your local asshole.
LanceSR20 is offline   Reply With Quote
Old 02-25-2006, 11:40 PM   #16 (permalink)
Jah Rastafari
I listed 98-01 because I am 100% sure these cars came with the updated tensioner. *** wanted to be clear that everyone got the right part.
There is even a better tensioner and it comes on the N1 SR16VE I will talk to Greg at Mossy and see if he can get them
Old 03-08-2006, 11:15 PM   #17 (permalink)
I don't see how it will skip a tooth based on removing the top timing chain guide. If I'm correct, the guide has nothing to do with keeping tension or ensuring proper cam gear alignment.
I know that the older tensioners were a problem with keeping the right tension on the timing chain as and when it gets older, but I don't see exactly how the older tensioner would make the situation worse by removing the top timing chain guide.
Would you please care to explain, Andreas?
I will be posting a picture of what has happened to a timing chain guide that was never removed from the engine and what the guide did in terms of damage. I'm sure some people will be surprised to see what heavy damages that guide can likely cause if not removed.
Old 03-09-2006, 05:32 PM   #18 (permalink)
Travieso Racing
Feedback Score: 6 reviews
it can skip a tooth if the old stock tensioner is there think about it.. you said it was rubbing if it were rubbing at idle that sh*t would have the nastiest groove dam near break the thing off soo it must be hittin the guide at a higher rpm without the guide the chain can go up high enough with old school tensioner that it will skip a tooth... probably the intake cam most likely or both exhaust an intake... since nissan did decide to remove it in 98+ cars theyre tensioner must be alot stonger hence no guide... just cautionary measure to insure nothing goes bad. anyways new tensioner never hurt nobody
Danny GDM (HKS)
1993 PRiMERA GT
Old 03-09-2006, 05:33 PM   #19 (permalink)
Travieso Racing
also the gasket on the tensioner is usually a sneaky oil leak waiting to happen if its stock ....soo i concur on changing tensioner
Old 03-11-2006, 10:16 AM   #20 (permalink)
I had a headache reading one long sentence like that.
So, let me say it in my own words. You're saying that because the old tensioner doesn't have the capability to give the timing chain the correct tension it needs, the only thing holding the chain onto the cams in the correct position is the cams. Well, I don't see how the guide would give the chain any tension. If the tensioner has gone beyond its point of keeping acceptable tension, then the guide giving it any tension at that point is useless, as the function of the guide is not to complement the tensioner.
Like I said, I have a picture of a destroyed guide that'll show you that it's worse to keep it than take it out.
I don't question the use of the new tensioner, as I installed one myself back when I had my '94. Now I just recommend taking the guide out anyway without even getting the tensioner due to the fact that the guide can become one scary object in the valvetrain.
HTML code is On
