Old 07-31-2005, 01:17 PM   #21 (permalink)
Too busy to post
Originally Posted by B14 Se-Rious
for this part W/P P/S- Gates k040340, use the k040350, the 340 didnt fit over, it was impossible we pulled hard, the 350 fit nicely and was adjusted with ease.
HHHmmmm..... I used the 340, no problem. did you loosen the power steering adjuster?
On my 5th SR20 Powered car ... I am an addict .
91 VE-R - Never ending Project
02 Path LE - VQ Powered
NeedMore$4SE-R is offline   Reply With Quote
Old 08-01-2005, 09:39 PM   #22 (permalink)
EECS Nerd.
NeedMore$4SE-R, is that a VE I see? (judging by your post in the VE section).
I read that having the UR pulleys is bad for the 20V VE? Something about motor going out of balance because of no counterweights on the UR pulley. (given that the 20V has um.. 4 counterweights only on the crank, I think?)
Old 08-01-2005, 10:26 PM   #23 (permalink)
Too busy to post
Yes it is the VE , not the 20v VE though.
I have seen a couple VE owners run the 4 pulley set up with no problems. I haven't started mine in a couple months.... still building the car to go around it. I guess we will see if it works; hopefully by the end of this week.
Old 09-06-2005, 02:50 PM   #24 (permalink)
i love b13's !
Trader Rating: 22 (100%)
not to dredge up a dead thread. but i cant open that file. so i just want to ask the same question agian just to be sure.
i have ur crank pulley and ur wp pulley and no ac. what belts do i need ??
stratton.
im back.......
Old 09-07-2005, 02:47 PM   #25 (permalink)
Rob
we are in the same boat, i found this..
I have this saved on my computer from an old thread:
"The belt # for the belt for SE-Rs without A/C is on the instructions that come with the UR pulleys
It is: Gates K040310 (31 5/8 or 805MM)."
Also have this saved from an old thread:
"The Nissan part # is 11920-77A00TM. This belt is for running just the alternator, no AC, it is 1 rib skinner than the stock belt."
I recently bought a belt from Checker for my '93 SR20DE without A/C with UR 2 piece set = crank & water pump.
Gave them the Gates K040310 number and they cross-referenced it to the brand they carry. It is a 4 rib belt, installed fine, but haven't run the engine yet - waiting for more parts.
stratton.
Old 09-07-2005, 10:53 PM   #26 (permalink)
The SE-R Sitter
I no longer have my AC so I can goto Autozone and ask for the Gates K040310 belt and that will work for me?
http://www.s r 2 0-f o r u m.com/
For those looking for a new home.
SE R Madness is offline   Reply With Quote
Old 09-08-2005, 05:08 PM   #27 (permalink)
Rob
it should....
Old 09-11-2005, 03:57 AM   #28 (permalink)
GUNT SMASHER
Trader Rating: 4 (83%)
Would it be worth getting just the water pump pulley for better cooling reliability? If so, what belt would be needed for that setup?
Built, not bought.
Aero Deck is offline   Reply With Quote
Old 09-15-2005, 12:02 PM   #29 (permalink)
TRU-SleeperProject
What size belts are used for the 2 pc. UR Water Pump and Crank pullies without Power Steering, but it has A/C?
Thanks,
Alvin
I know that I have to search, but does slow a$$ dial-up count for a search disability? =] Later.
Alvin Cabigting
TRU SPORT/George&Sons-GU/671
92 Sentra GXE (4DR) SR20DE - SLEEPER PROJECT
91 Sentra XE (2DR) 1.6L - Daily Driver/Gas $aver
USPS classifies Guam with the rest of the USA as far as shipping rates go...
alvincabigting is offline   Reply With Quote
Old 01-22-2006, 04:42 PM   #30 (permalink)
G20 Newbie ;)
Any tips for an auto 99 G20?
Zoli
99 G20t mainly
ZoliElo is offline   Reply With Quote
Old 01-22-2006, 05:38 PM   #31 (permalink)
G20 Newbie ;)
Found an answer for an auto Z:
Get your friend to get inside the car, make shure the transmission is in REVERSE, parking brake fully up, and step firmly on the brake while you take a 1/2" drive ratchet with a 3 to 4 inch extention, and a 27mm socket and try your hardest to break loose the crank bolt. The reason for the transmission being in reverse, parking brake full up, and the depressing on the brake is because the torquing of the crank bolt removal will turn the engine instead of the bolt if left in neutral, or sending the car pushing itself off the jackstands and on top of you ruining you whole day!
Sounds right but does anyone know for sure?
Old 01-22-2006, 09:03 PM   #32 (permalink)
Tryin' To Be Like You
can someone tell me the tools i need and what the factory service manual procedure for a auto (99 se-l) are? please if you have done this (2 piece) let me know thank you..
Originally Posted by Shawn B
Purple monkey Fritos elbow dishwasher cigarette can-opener!
Acorn lug-wrench carpet vibrator Gatorade?!?
i am about to make that my sig shawn if you will allow it?
hell i did it so if you want me to i can get rid of it but i thought it was hella funny
skeeter149 is offline   Reply With Quote
Old 02-05-2006, 02:40 AM   #33 (permalink)
MajorMods.com Owner
Trader Rating: 40 (100%)
i have the 2pc crank and w/p but i have an 00SE RR sr20 and i DO have a/c. any idea which belts i need?
Email: sales@MajorMods.com
AIM: MajorMods4U
Paypal: paypal@majormods.com
Phone: 754-581-4374
website: www.majormods.com
black2kse is offline   Reply With Quote
Old 02-05-2006, 02:43 AM   #34 (permalink)
G20 Newbie ;)
That will work. But so will leaving it in park and using an imact wrench.
Old 02-06-2006, 02:54 PM   #35 (permalink)
i will do the park with impact wrench method and i thank you all for looking into this for me.
Old 03-15-2006, 08:35 AM   #36 (permalink)
works best in fifth, that is the least torque going to the wheels...
praedet is offline   Reply With Quote
Old 03-15-2006, 02:47 PM   #37 (permalink)
G20 Newbie ;)
The last few posts were about a pulley install on automatics. But thanks for the information.
Some other information that people might find useful is that on my auto 99 G20 with AC (2 pulley set) the belts that I used and that [work] well are CarQest Micro-V K060390 21mm x 1000mm and K040340 1.4mm x 880mm .
Old 06-16-2006, 03:07 AM   #38 (permalink)
G20 Newbie ;)
Double checking for a friend's install.
Belts for the 2 pulley set are they same for the 4 pulley set (both with AC)?
That should be true as the PS and Alt. are OEM sized. If not I my mind has gone.
Thanks for the help.
Old 06-20-2006, 02:31 AM   #39 (permalink)
R.I.P. Danilo
good question I was wondering that too...
-Matt
97se-rblown is offline   Reply With Quote
Old 06-26-2006, 11:11 AM   #40 (permalink)
STP Motorsports
Allright I have the crank pully and water pump pully only and I dont have ac or power stearing what belt do I use then?
95 240sx SE with 1jz POWER!!!!
Has Arrived!!!!!
sr20starlet is offline   Reply With Quote
