Old 06-27-2006, 10:59 AM   #41 (permalink)
The smooth funky classic
brokeser's Avatar
brokeser is offline   Reply With Quote
Old 06-27-2006, 12:32 PM   #42 (permalink)
STP Motorsports
Ok guys hope this helps I found the belt for the water pump pullie with out p/s the number is ko40252 and your gonna have to have two people to do this. One has to turn the crank pully while the other try's to put belt on with a flat head screw driver. I got it on pretty easy and it fits just right. Good luck.
95 240sx SE with 1jz POWER!!!!
Has Arrived!!!!!
sr20starlet is offline   Reply With Quote
Old 07-16-2006, 09:29 PM   #43 (permalink)
G20 Newbie ;)
Originally Posted by ZoliElo
Double checking for a friend's install.
Belts for the 2 pulley set are they same for the 4 pulley set (both with AC)?
That should be true as the PS and Alt. are OEM sized. If not I my mind has gone.
Thanks for the help.
Yes the belts for the 2 pulley set work fine with the 4 pulley set.
Zoli
99 G20t mainly
ZoliElo is offline   Reply With Quote
Old 07-16-2006, 09:34 PM   #44 (permalink)
G20 Newbie ;)
FYI when installing the alt pulley (011030702) you might need a washer as a stem [for] the OEM pulley is a bit longer than the UR pulley [stem wise]. Without that washer the alt might lock up.
Old 09-29-2006, 11:09 PM   #45 (permalink)
the original 4-door SR20
Originally Posted by 1F@$t9d7
I got this belt from Napa and it was too long. It was 855mm instead of 805mm.
Ok, I have the same problem, I am bypassing my A/C. It is way to big with the UR Crank pulley.
Now, my question is the Gates K040310 is only has 4 ribs compared to the stock 6 ribbed belt. Would it be an issue running a 4 ribbed belt to the alternator.
96 G20 Turbo:Sold
93 NX2000: SOLD
91 SE-R: SOLD
99 GXE DD
jamse-r is offline   Reply With Quote
Old 10-01-2006, 01:56 AM   #46 (permalink)
Broke Ass
jer_760's Avatar
I ran that belt for six months with zero problems.
95 200sx
sr20ve
Old 10-12-2006, 05:00 PM   #47 (permalink)
Kicking it over @ g20.net
i read somwere that the 00+ g's cant use the crank pulley due to the harmonicly balanced crank or ****** ????? *** know what im talking aboiut??
enohand is offline   Reply With Quote
Old 11-16-2006, 06:41 PM   #48 (permalink)
Im Not A Chick
im running the 4r peice set. got a automatic tranny.94 g20 motor. no AC for now. what belts do i use!
can i get the part number for AC and without AC thanks !
jen36 is offline   Reply With Quote
Old 11-16-2006, 10:39 PM   #49 (permalink)
G20 Newbie ;)
I have an auto P11 and it should be the same as an auto P10?
CarQest Micro-V K060390 21mm x 1000mm and K040340 1.4mm x 880mm should work for an auto with AC. From what I read in this thread 805mm is used when there is no AC.
Please someone double check the above!
Old 11-17-2006, 04:17 PM   #50 (permalink)
zolielo~ u got a 00+??? if so can anyu one else confirm/deconfirm tht the pulleys wont harm the rolller rocker version of th sr20 in ANY WAY????....i headr tons of things fomr main seal leaking to wear on the bearingss.....ayone?
Old 11-17-2006, 04:25 PM   #51 (permalink)
G20 Newbie ;)
My P11 is a 99 with a 4 pulley set. More or less so far so good. But the alternator pulley might have killed my alternator...
I have a 01 B15 as well and do not use underdrive or lighter weight pulleys on it for the risk of wear.
Old 11-21-2006, 01:51 AM   #52 (permalink)
Im Not A Chick
is this right... but with no AC... i need to ***
Old 11-24-2006, 05:16 PM   #53 (permalink)
Im Not A Chick
ok the 3 pieace pulley set for 91 to 01 SER or G20.. the power stearing and water pump the size belt from napa was part # 25040340......34 5/8 which makes it 881mm workes perfect.
as far as the crank to altinator with no AC im still trying diffrent belts. i dont want to try the 4 rib (which i can get) when it needs a 6 rib belt. i *** the lengh has to be between 805mm to 820mm but no one seems to have that in six rib or maybe they to lazy to look...
my last try will be tomorrow since napa cant get the last belt i want to try in time today. Im sure that belt will work since its about 2 inches longer and the last one i tired was to short. we will see how it goes tomorrow.
Old 12-07-2006, 01:41 AM   #54 (permalink)
Free Hugs
sounds like everyone is not running a/c. is there a problem having it on with UR pullies? can i use the 4pc set with a/c?
1993 Nissan Sentra SE-R turbo
See's HPDE events regularly
prodrifter is offline   Reply With Quote
Old 12-07-2006, 01:44 AM   #55 (permalink)
Broke Ass
jer_760's Avatar
Of course you can.
Old 12-29-2006, 11:40 PM   #56 (permalink)
Im Not A Chick
well the last belt did not work. im going to take jer_760 word for it and run the 4 ribbed belt....
Old 12-30-2006, 09:45 PM   #57 (permalink)
Broke Ass
jer_760's Avatar
It will be fine. I'm still using it.
Old 02-20-2007, 11:53 AM   #58 (permalink)
JDM BOOST WHORE
SR20 91 SE-R's Avatar
i just installed the 4pc pullies w/ac i noticed how people remove the passanger side mount to get the wp pullie off. all you have to to is just remove the crank pulley and you can remove the pullie from the bottom. just make sure you break the 4 bolts loose before removing the belts. and for the ps just dissconnected the ps lines and droped the pullie and hit it with the impact. then just bolts the ps pump back up.
SR20 91 SE-R is offline   Reply With Quote
Old 03-05-2008, 03:29 PM   #59 (permalink)
nx-less
Trader Rating: 15 (100%)
back from the dead...
need help figuring out what belt sizes i would need for the following combo:
UR Crank Pulley
Stanza WP
Stock PS Pump
Stock Alternator
i would use the string method and just bring it to an autoparts store but the problem is that the powersteering and alternator are still on the car and not on the engine that will be getting the stanza wp and UR crank...
TIA!
- jason
damn you eKool
junknstuff is offline   Reply With Quote
Old 03-06-2008, 12:49 AM   #60 (permalink)
nx-less
bump?
HTML code is On
