HOW TO: Unorthodox Pulley Install & Belt Sizes - Page 4 - SR20 Forum
Old 06-28-2008, 05:23 PM   #61 (permalink)
3 NX2000's
NX2KTPR's Avatar
Feedback Score: 5 reviews
Install the pulleys.
Measure with string how long the belt should be.
Go down to the auto parts store with the old belt and say "I need a belt like this but with a length of X".
If they can't figure it out, go to a parts store that knows what they are doing.
Tim Rogers
'91 NX2K- Black, parts car
And yes, I've broken it...
NX2KTPR is offline   Reply With Quote
Old 08-28-2008, 11:18 AM   #62 (permalink)
Weekend Warrior
Feedback Score: 60 reviews
The links in post # 1 are DEAD. 404
Originally Posted by ZoliElo View Post
Double checking for a friend's install.
Belts for the 2 pulley set are they same for the 4 pulley set (both with AC)?
That should be true as the PS and Alt. are OEM sized. If not I my mind has gone.
Thanks for the help.
So they are the same if you run A/C?
FYI when installing the alt pulley (011030702) you might need a washer as a stem [for] the OEM pulley is a bit longer than the UR pulley [stem wise]. Without that washer the alt might lock up.
^What is the deal on this washer you speak of? Anybody else know about this?
Originally Posted by SR20 91 SE-R View Post
i just installed the 4pc pullies w/ac i noticed how people remove the passanger side mount to get the wp pullie off. all you have to to is just remove the crank pulley and you can remove the pullie from the bottom. just make sure you break the 4 bolts loose before removing the belts. and for the ps just dissconnected the ps lines and droped the pullie and hit it with the impact. then just bolts the ps pump back up.
I will be running all 4 UR pulleys with A/C like you. What belts do I need sr20 91-SE-R?
^LOL
Bend But Don't Break
Old 08-28-2008, 03:41 PM   #63 (permalink)
bitemyshinymetalass
SuperblackZ's Avatar
Feedback Score: 8 reviews
^LOL
I have full UR pulleys on my '91 B13, belts may still be readable for the part # since they were new last year. I had to replace my alt (not related to UD pulleys, just old) and with a lot of adjustment the same belt works with the stock pulley - I still can't get the UR pulley OFF the old Alt, it's welded on there with age.
If you're stuck on belts still drop me a PM and I'll check. This thread is very dead.
SCC Project SE-R
'91 B13 Black, 10:1 JDM, O.E.M. CAI Intake/ JWTPopC, SSAC Header, UR Pulleys, JWT Stage 2 Clutch/ECU, Progress CO's 450F/350R, Progress F&R SWB, GC Plates, FSTB/Firewall brace, Progress LCAB, ES bushings/MM's, Wilwoods, Traklites 15x7" Kuhmo XS/Kosei K1's/NT01's, Chuck's RSTB, KOYO rad, R32 Wheel/Horn, R32 Shift knob
Team Progress, Track Vids,My 2nd '91 B13
SuperblackZ is offline   Reply With Quote
Old 08-28-2008, 04:17 PM   #64 (permalink)
Weekend Warrior
^Back Alive
^PM sent..........Others were copied on it as well. The links in the first post are dead. I need to order my belts. Soon as I get a cherry picker, I'll be ready to roll. Google links lead me back here. I'll see what I have stored in my hotmail account.
Old 08-28-2008, 04:55 PM   #65 (permalink)
bitemyshinymetalass
Ok, the PM just sticks an e-mail where I'll remember to do it
I'm sure I have the alt gates belt number because I bought a spare before driving the car from CA to CT, and Dave C put new belts on Jan 2007, I have A/C, and Crank UD pulley for sure.
Old 08-28-2008, 07:32 PM   #66 (permalink)
bitemyshinymetalass
Lower belt (wider 6 groove serp belt) has a series of numbers across the belt:
4060390 6PK990 Goodyear Poly-V
Which is alt, A/C, crank pulley, all UR pulleys
Upper smaller belt (inner crank, PS, WP) is Goodyear Poly-V , here's the numbers:
4040342 then 4PK870
There's a decent Xref here for Gates and others :
http://www.tufautoparts.com/files/TU...01-22-2008.htm
HTH & good luck!
Old 08-29-2008, 07:10 AM   #67 (permalink)
Big Bossman
Doug_O's Avatar
First post updated with proper links.
Doug
Money Shot
12.5@110
Doug_O is offline   Reply With Quote
Old 08-29-2008, 09:42 AM   #68 (permalink)
Weekend Warrior
4040342 then 4PK870
HTH & good luck!
Thanks for the reply. I couldn't get the link to work in the PM, but it popped right up from the thread.
Doug
^Thanks
Old 08-30-2008, 01:13 AM   #69 (permalink)
Broke Ass
jer_760's Avatar
Feedback Score: 12 reviews
I got a PM from a couple of you, It has been too long, I dont remember the belts I used. Just use the old string trick to measure
95 200sx
sr20ve
Old 09-03-2008, 02:25 PM   #70 (permalink)
Weekend Warrior
https://www.rockauto.com/catalog/catalog.php?ckout=1
^I found these belts from a google search, they should work find. Can someone double confirm for me? The Gates Belt part # K060390 from the RockAuto site says 39-3/4" instead of 39-5/8". Will it still be ok?
Old 09-05-2008, 09:55 AM   #71 (permalink)
Weekend Warrior
K060390 and
Old 12-19-2008, 08:35 PM   #72 (permalink)
okay i know this thread been dead for a little but i was just wanting to know since i have a 1993 sentra with the upgraded pulleys on my sr20det with AC -
I need the goodyear poly V 4060390 and 4040342 - I thought we needed 3 belts on the sr20det with AC,, or do i have to get one belt twice,.,.,. ?
Thanks,,.,
8046joel is offline   Reply With Quote
Old 12-19-2008, 09:19 PM   #73 (permalink)
bitemyshinymetalass
1x Serp Belt
Which is alt, A/C, crank pulley, all UR UD pulleys except A/C in my case:
GATES
K060390
DAYCO
5060390
GOODYEAR
4060390
METRIC
6PK990
The Upper smaller belt (inner crank, PS, WP) is Goodyear Poly-V on my car, here's the numbers:
4040342 then 4PK870
2 belts total, those numbers should help.
Old 01-30-2010, 02:27 AM   #74 (permalink)
Always a Newbie
The last few posts were about a pulley install on automatics. But thanks for the information.
Some other information that people might find useful is that on my auto 99 G20 with AC (2 pulley set) the belts that I used and that [work] well are CarQest Micro-V K060390 21mm x 1000mm and K040340 1.4mm x 880mm .
what's the website for that belt?
burubuduy is offline   Reply With Quote
Old 01-30-2010, 12:32 PM   #75 (permalink)
bitemyshinymetalass
TUF TF040340
Type Serpentine Belt
Gates K040340
Dayco 5040340
Goodyear 4040340
Cadna 340K4
Metric 4PK865
The second one is a Gates Belt, you should be able to find that multiple places, e.g. RockAuto, etc. like here:
http://www.autopartswarehouse.com/sk...%26+Drivetrain
UR recommends the Gates belts for some reason unknown to me, it's in their install instructions. I have a Goodyear for the serp and a Gates for the other so clearly both work (but pls note I'm not using this size, see my earlier posts).
Old 01-30-2010, 01:21 PM   #76 (permalink)
G20 Newbie ;)
Seems like the carquest site is down. Try getting similar directly for UR
http://www.unorthodoxracing.com/Item...ke=20&Model=65
Zoli
99 G20t mainly
ZoliElo is offline   Reply With Quote
Old 01-30-2010, 07:43 PM   #77 (permalink)
Always a Newbie
thanks for the links guys. now I can buy my belt
Old 02-04-2010, 02:57 PM   #78 (permalink)
Always a Newbie
just installed my belts on my Gspec crank pulley and used Goodyear Gatorback 6PK0990 in my alternator and 4PK0850 in my P/S and it all fit good.
Old 10-11-2011, 05:48 PM   #79 (permalink)
OEM Crankshaft Pulley
I am replacing my Crankshaft Pulley for my 1997 200SX SE-R.
Is there any tools I need before I take off the pulley? Anything I need to know to keep it timed right? I am afraid to take it off and screw up the timing of the engine. Please help.
MrBojangles is offline   Reply With Quote
Old 10-11-2011, 11:07 PM   #80 (permalink)
3 NX2000's
NX2KTPR's Avatar
You can't put the new one on wrong since the pulleys are "keyed" to line up in the right orientation.
HTML code is On
