Old 06-28-2008, 06:23 PM   #61 (permalink)
3 NX2000's
NX2KTPR's Avatar
Install the pulleys.
Measure with string how long the belt should be.
Go down to the auto parts store with the old belt and say "I need a belt like this but with a length of X".
If they can't figure it out, go to a parts store that knows what they are doing.
Tim Rogers
'91 NX2K- Black, parts car
And yes, I've broken it...
NX2KTPR is offline   Reply With Quote
Old 08-28-2008, 12:18 PM   #62 (permalink)
Weekend Warrior
MR-4Door-SR20DE's Avatar
Trader Rating: 34 (100%)
The links in post # 1 are DEAD. 404
Originally Posted by ZoliElo View Post
Double checking for a friend's install.
Belts for the 2 pulley set are they same for the 4 pulley set (both with AC)?
That should be true as the PS and Alt. are OEM sized. If not I my mind has gone.
Thanks for the help.
So they are the same if you run A/C?
FYI when installing the alt pulley (011030702) you might need a washer as a stem [for] the OEM pulley is a bit longer than the UR pulley [stem wise]. Without that washer the alt might lock up.
^What is the deal on this washer you speak of? Anybody else know about this?
Originally Posted by SR20 91 SE-R View Post
i just installed the 4pc pullies w/ac i noticed how people remove the passanger side mount to get the wp pullie off. all you have to to is just remove the crank pulley and you can remove the pullie from the bottom. just make sure you break the 4 bolts loose before removing the belts. and for the ps just dissconnected the ps lines and droped the pullie and hit it with the impact. then just bolts the ps pump back up.
I will be running all 4 UR pulleys with A/C like you. What belts do I need sr20 91-SE-R?
^LOL
BEND BUT DON'T BREAK
93 SE-R
Project-4Door-B13 "Building it one paycheck at a time"
FB1 - FB2 - SR20 storage building part-out LINK
MR-4Door-SR20DE is offline   Reply With Quote
Old 08-28-2008, 04:41 PM   #63 (permalink)
bitemyshinymetalass
SuperblackZ's Avatar
^LOL
I have full UR pulleys on my '91 B13, belts may still be readable for the part # since they were new last year. I had to replace my alt (not related to UD pulleys, just old) and with a lot of adjustment the same belt works with the stock pulley - I still can't get the UR pulley OFF the old Alt, it's welded on there with age.
If you're stuck on belts still drop me a PM and I'll check. This thread is very dead.
Former SCC Project SE-R
'91 B13 Black, JDM 10:1 CR SR20DE, Custom Intake/MAF w/JWT PopChg, 2.5" SSAC Header, Progress CO's 350F/250R, 3-way adj. 30-mm Progress FSWB, 22-mm Progress Rear Sway, Ground Control Plates, FSTB + FW triang braces, Progress LCA Brace, Energy Susp. bushings, Wilwood Brakes, Motgei Traklites 15x7", Kuhmo MX, RSTB w/triang trunk braces, R32 Steering Wheel
Team Progress
SuperblackZ is offline   Reply With Quote
Old 08-28-2008, 05:17 PM   #64 (permalink)
Weekend Warrior
^Back Alive
^PM sent..........Others were copied on it as well. The links in the first post are dead. I need to order my belts. Soon as I get a cherry picker, I'll be ready to roll. Google links lead me back here. I'll see what I have stored in my hotmail account.
Old 08-28-2008, 05:55 PM   #65 (permalink)
bitemyshinymetalass
Ok, the PM just sticks an e-mail where I'll remember to do it
I'm sure I have the alt gates belt number because I bought a spare before driving the car from CA to CT, and Dave C put new belts on Jan 2007, I have A/C, and Crank UD pulley for sure.
Old 08-28-2008, 08:32 PM   #66 (permalink)
bitemyshinymetalass
Lower belt (wider 6 groove serp belt) has a series of numbers across the belt:
4060390 6PK990 Goodyear Poly-V
Which is alt, A/C, crank pulley, all UR pulleys
Upper smaller belt (inner crank, PS, WP) is Goodyear Poly-V , here's the numbers:
4040342 then 4PK870
There's a decent Xref here for Gates and others :
http://www.tufautoparts.com/files/TU...01-22-2008.htm
HTH & good luck!
Old 08-29-2008, 08:10 AM   #67 (permalink)
Big Bossman
Doug_O's Avatar
First post updated with proper links.
Doug
Money Shot
12.5@110
Doug_O is offline   Reply With Quote
Old 08-29-2008, 10:42 AM   #68 (permalink)
Weekend Warrior
4040342 then 4PK870
HTH & good luck!
Thanks for the reply. I couldn't get the link to work in the PM, but it popped right up from the thread.
Doug
^Thanks
Old 08-30-2008, 02:13 AM   #69 (permalink)
Broke Ass
jer_760's Avatar
I got a PM from a couple of you, It has been too long, I dont remember the belts I used. Just use the old string trick to measure
95 200sx
sr20ve
Old 09-03-2008, 03:25 PM   #70 (permalink)
Weekend Warrior
https://www.rockauto.com/catalog/catalog.php?ckout=1
^I found these belts from a google search, they should work find. Can someone double confirm for me? The Gates Belt part # K060390 from the RockAuto site says 39-3/4" instead of 39-5/8". Will it still be ok?
Old 09-05-2008, 10:55 AM   #71 (permalink)
Weekend Warrior
K060390 and
HTML code is On
