First you need to order new studs. B13 part number: 43222-70T00
Remove your wheel:
Remove caliper. You will need the space circled on this picture to put the new stud.
Turn the steering wheel to whichever way it will give you more space.
(if your working on the passenger side, have the steering wheel rotated all the way to the right.
If your working on the driver side, have the steering wheel rotated all the way to the left.)
Hammer out the old stud or broken stud.
wheel stud out
Place the new stud
Hammer in the new stud from the back, make sure it is straight going in!
I find using an extension to hammer it in gives me a leverage to get it in straight.
All four completed!
All you need to do now is bolt back your caliper and wheels, then your set to go.
