Old 12-18-2006, 03:31 PM   #21 (permalink)
build completed...
Trader Rating: 26 (100%)
What wattage of LED would you guys recommend? I'm pretty sure a .5w or a 1w LED is probably overkill, but I haven't tried it so whaddya think?
SR20DEEP in TX
Old 04-04-2007, 02:27 PM   #22 (permalink)
"The Chubby Panda"
Trader Rating: 19 (100%)
I really wouldn't bother with wattage, and just order a pre-made 12v set from superbrightleds.com, came to like $11 with shipping. Chump change!
My other NX....is an NX.
Canx2k is offline   Reply With Quote
Old 04-04-2007, 04:55 PM   #23 (permalink)
SR20DE Kid
How man LED's are needed to convert the dash lights?
VogtlandAccord is offline   Reply With Quote
Old 04-05-2007, 12:56 PM   #24 (permalink)
"The Chubby Panda"
see page 1 for some pictures
Old 04-05-2007, 10:18 PM   #25 (permalink)
Pursuit of happiness
Well,
read everything 3 & 4 times
ordered 12 v, 194 wedge blues for the instrument panel.
I have a 91 sentra ser I hope the hell I did not screw up.
Ed
pathfinder7 is offline   Reply With Quote
Old 04-16-2007, 05:56 PM   #26 (permalink)
"The Chubby Panda"
you didn't. 194 is the right ones, just keep your original twist-off harnesses and you're golden.
Old 04-17-2007, 06:21 PM   #27 (permalink)
Thank you Canx2k,
Your helping my confidence, gotta lot going on, with 2 cars and all....
Ed
Old 04-19-2007, 05:23 AM   #28 (permalink)
Ruby Red SE-R
Originally Posted by Canx2k View Post
For anyone who's interested:
If you take out all of the screws in the instrument panel, then hold it with one hand, and feel around with your other on the other side of it, you will find a U clip that goes around the speedometer harness on the back of it, just push that U clip away from the cable (it spins, so you can turn it to wher eyou like it) and pull the speedo cable right off. No removing it from the tranny needed. The speedo cable is roughly equiv to a 6 gauge wire in width, and is all black. If you look up from your floor in the driver's side, you can see it.
Also for the record, I tried Red, green, and blue. Our dash lights come factory blue (even though it shines white), so blue was the only color that came through true. Red looked almost pink, and green...dont even get me started.
Go blue. I went with the WLED 5 LED wedge bulbs from www.superbrightleds.com
This is absolutely perfect. Wish I had seen this before I orderd my reverse glow setup, because this would match the autometer cobalt guages I plan on getting perfectly. Oh well I'm still happy that I ordered them. Can't wait till it gets here.
Once you go turbo you'll never go back!!!
1993 Ruby Red SE-R SR20DE+T RIP junked 3/06
1995 Infiniti G20
1994 Aztec Red SE-R W10DET powered
Originally Posted by capecodbuysell View Post
whats a 2 step and how does it build boost at the line
Originally Posted by GateCrasher_VI View Post
anyone have a spare muffler bearing or two? 'reason to suspect thats where my coffee can sound is coming from
scrildo is offline   Reply With Quote
Old 04-29-2007, 09:40 PM   #29 (permalink)
bitemyshinymetalass
SuperblackZ's Avatar
Originally Posted by webninja View Post
hope this can help someone, not sure how different the classics/NX/G20s are, but here is the bulb list for the 200sx:
Instrument panel 194, 158, 70BB, 70
I just did my '91 SE-R today, there were both 194's and 158's in the panel. The ones burnt out were for the tach, speedo, fuel, and temp - 3 of 4 total.
As described in post #1, I had to extract the bulbs and rewire the sockets, but I used 158's because that was what I found printed on the sockets (and in my cheesy Chilton consumer manual). I soldered them in like the ones I took out, no way did I want those coming loose after doing the speedo cable and the dash lights today. I can see why they charge so much for this...at least the bulbs were cheap.
B13 Photo Albums
SuperblackZ is offline   Reply With Quote
Old 05-01-2007, 01:58 AM   #30 (permalink)
Project Achilles
This is what I did to my Aztec Red '93 SE-R a long while back. I'm going to pull everything back out to paint the bezel again. It bubbled on me, and I'm no longer going to paint the car Bayside Blue. Gonna save that color scheme for a NX2K.
It's gravy to do. Only takes a few minutes to pull out the cluster.
Originally Posted by Shawn B
Go get laid. Seriously. Cheap, casual, one-night stand, primal porno, monkey humping. Sympathy sex. Excellent for your ego, good for the soul.
Originally Posted by JDM Freak
"yeah.. first gear is regular, second gear is vtec, third gear is JDM, and fourth gear is GSR"
Originally Posted by 95p10
by this i mean go ShawnB on his ass and make him bleed out his eyes.
lukamccloud is offline   Reply With Quote
Old 05-01-2007, 08:34 AM   #31 (permalink)
build completed...
Where do you see this set? I'm still at a loss as to what you're referring to. I see a few different part numbers for the 5mm LEDs, but none of them are 12V LED's. They're all 5V LED's and the wavelengths and focal areas are different, that's all.
EDIT: Holy crap I'm blind. I found what I was looking for.
Old 05-01-2007, 08:40 AM   #32 (permalink)
build completed...
NVM.
So, I just ordered 5 each of the WLED-B5 Blue Wedge bulbs. Should be yet another project for me when I get the hell out of here
Old 05-01-2007, 06:59 PM   #33 (permalink)
"The Chubby Panda"
yah man, i've got a stockpile of stuff to go into my car when it's nice should make for a nice saturday project
Old 05-04-2007, 05:09 PM   #34 (permalink)
natural81
what bulbs did you use to make yours look like this?
Jose is offline   Reply With Quote
Old 05-05-2007, 09:36 PM   #35 (permalink)
yeah i'm a trendy ricer
b14 superbrightlights.com
dash 4 wled 1-led-blue
hvac 2 74 wedge base led bulb -blue
T.S.O.L.
cause4alarm is offline   Reply With Quote
Old 05-06-2007, 12:26 AM   #36 (permalink)
build completed...
That's hot. I don't care what anyone says. There's absolutely NOTHING wrong with changing the color of the light on a stock cluster
Old 05-09-2007, 10:21 AM   #37 (permalink)
SR20's since '97
Guys whats the size of this bulb in the blue fixture in the guys hand?
And is this the bulb that runs the clock? I changed all my cluster bulbs
but the clock is still dim on my 92 B13 SE-R
Also will 93/94 194 Sockets work so I can install the new bulbs.
They are rigged in the current sockets but i dont trust that setup and one already rattle loose and is off.
Thanks in Advance
Daryl G.
00 Jetta GLX VR6
02 Jetta 1.8t ( hers )
92 Sentra SE-R
98 Sentra SE ( RIP ) 14.2 NA
94 Sentra SE-R ( sold )
90 CRX SI w/GSR + bolt ons ( sold ) 12sec all motor
QUiKSR20 is offline   Reply With Quote
Old 05-15-2007, 04:26 PM   #38 (permalink)
mad about SER:P
just dont use blueish regular 194 bulbs *** w the time the color will fade out like this always use led's
look the diferencee
1996 TEAL 200sx SER
my old b14 on the strip
my H2 makin donuts
beto_dc is offline   Reply With Quote
Old 05-15-2007, 05:12 PM   #39 (permalink)
"The Chubby Panda"
my 194 super bright led's are so bright they turn the redline into a blueline. it sucks.
Old 05-17-2007, 07:00 AM   #40 (permalink)
build completed...
BS! The USPS states that my package was delievered on the 5th with delivery confirmation. I never received confirmation, and never received the damn package. I'm pissed. Now I have to send them a nasty gram to fix it.
