HOW TO: Radiator fan manual override - SR20 Forum
Old 10-08-2004, 11:22 AM   #1 (permalink)
Master Cunnilingust
Feedback Score: 37 reviews
I copied this from the NPM article I did awhile back, thought it would be more accessible and usefull if it was here as well.
Many people like to be able to run their radiator fans all the time while at the track or drag strip. Fortunately this is a lot easier than it might seem and can be accomplished very inexpensively and doesn’t require running wiring to the engine compartment or connecting new circuits to the battery. These instructions include wiring colors that apply to all trim levels of ’93 Sentra and NX’s and has info for both automatic and manual transmission cars. If you have installed aftermarket fans that use a separate controller, depending on how you installed the controller would determine how you would need to override that controller to operate the fans at your whim. Please feel free to e-mail me if you’d like me to help you override your aftermarket fans. Also provided are instructions on how to determine how to do this to any other year B or P series car if you have access to wiring diagrams, a Factory Service Manual, or are generally handy with a multi-meter. As a general safety precaution please remove your negative battery cable while doing any electrical work on your car.
The B13 Sentra/NX has different fan configurations. Manual transmission SR20DE and GA16DE cars came with single coil fans which operate at only one speed, and only one relay is used to operate these fans through a single circuit. Automatic transmission SR20DE powered cars came with 3 coil fans which operate at two speeds and three relays are used, using two circuits, while GA16DE powered automatics have 2 relays utilizing two circuits. I would guess that this is due to a transmission cooler coil that is either incorporated into the radiator or as an independent coil that is placed up against the radiator. In both cases, we want the fans to operate at their highest speed on demand via a dash operated switch as well as when the ECU calls for it.
Things you’ll need are:
1 – SPST (single pole, single throw) switch. You can use an illuminated one if you like, and you can wire it so that the switch is always lit, only when the switch is thrown or only when the fans are running, be it by ECU trigger or the switch. You can also power the switch light by using the interior lighting circuit. See diagrams and info below.
~ 15’ of 18 gauge wire.
3 – 22-18 gauge (red) ¼” fully insulated female quick disconnects.
2 – 22-18 gauge (red) ¼” fully insulated male quick disconnects.
1 – 22-18 gauge (red) ring terminal (you’ll have to decide what size the ring needs to be depending on where you’re going to ground it).
~ 10 – 6”-8” cable ties.
3 – 22-18 gauge (red) 3M wire tap.
1 – 10-12 gauge (yellow) 3M wire tap.
1 - IN4XXX series diode (Any one of these will do: IN4001, IN4002, IN4003, IN4004, IN4005)
Wire stripper.
Wiring crimp tool.
Notes: You could get two different colors of wire if it makes wiring things up easier, or use different colored electrical tape to wrap the ends of the wires to keep them straight. A third option, which is a good habit to get into when doing wiring projects in your car, is to buy some numbered bands that you put on the end of wires, then you can write up a legend as to what each wire does. 18 gauge wire is small but sufficient since the current draw you’re dealing with will be marginal, around 1.5 amps. I rarely use wire this small, except when operating small load, short time use circuits like relays.
Normally I would recommend soldering the wiring tap splices, however since the wires you will be tapping into are so small and current is so low, the 3M taps will work fine and will be much easier to uninstall at a later date if needed.
You can refer to the diagrams while reading the following so that things make sense. The GA16DE ECU is the same as the SR20DE ECU in regards to the fan relay trigger wires that we are looking for.
First you should get to your ECU wire harness behind the center console on the floor under the dash. If you refer to the ECU diagram you can get an idea where the wire you’re looking for is located. The wire you want to tap for a manual transmission car is the solid blue wire in terminal position #9. If you have an automatic, then you want the solid blue at #9 as well as the blue with a black stripe wire in terminal position #10. Make sure you get the wires at the correct terminal, there's more than one wire of the same color in the harness, and getting the wrong one could damage your ECU among other things. Use red 3M wire taps to tap into these wires. Then connect these wires to your switch.
If you’re doing this to a car other than a ’93 Sentra/NX, then you’ll want to get wiring diagrams or a factory service manual to verify which wire from the ECU goes to the fan relay(s) in your car. This is the wire that the computer grounds to operate the fan relays, and is the wire you want to tap into to ground through your switch. This wire can be found by looking at the ECU foldout in the back of the FSM. If you opted for an illuminated switch, you’ll need to tap into a keyed power source so that the switch light only operates when the ignition switch is on. Although I would ordinarily suggest that you run a wire to the positive battery terminal to do this, since the light only draws a very small amount of current and will only be operating when the switch is thrown, tapping into an existing wire in the car should be relatively safe. The best wire I’ve found to do this is the white wire with a blue strip that goes through your ignition switch. Rather than tap into the wire near your ignition switch, I would do so behind the fuse block under the dash. There’s a clear/black two wire connector that you can release from the back of the fuse block on the bottom outside edge of the fuse block that has the white wire with a blue strip and a brown wire with a red stripe. It’s harness E46 if you want to find it in a factory service manual. Again, these colors are only certain for a ’93 Sentra/NX. Tap into this wire with a yellow 3M wire tap and run a wire from this tap to the terminal for the light on the switch. Then ground a wire to connect to the switch and you’re done. Use the cable ties to hold all your wires in place.
If you want to do this to another year B or P series car, then you need to determine how many fan relays it has and what those relays do. You want to trip the fan relays that will provide the most airflow. Since these relays are tripped by the ECU, you can use the wire color on the fan relay(s) and a meter to find out what wire at the ECU does this. Then by sending a ground to that wire, you can trip the relays in the same fashion that the ECU would, without drilling holes, hacking into engine bay wiring where it can corrode, or running unnecessary wiring. Relays always have at least 3 terminals, although most have 4 or more. There will always be and ground wire for the relay coil and power wire for the relay coil. The other two or more terminals will be where circuits are opened or closed. The coil is what makes the switch inside the relay operate. So knowing this you can pull a relay out and figure out which two terminals go to the relay coil, in most cases the terminals have number designations and a small diagram on the relay showing you the normally open and closed positions, as well as what number terminals are where. Switching the ground on things is the preferred method, hence why the ECU grounds the fan relays, rather than send them power.
This is a picture of the bottom edge of the fuse block. Circled in red is the two wire connector that I mentioned and you can barely see the white/blue wire on the right side of the connector. You can see the clear plastic on the right, which is what you need to depress to remove the connector. Again, make sure the negative battery cable is removed before taking this connector out.
This is a fuse block cut from a car and you can see the connector better as well as the white/blue wire and the tab you depress to remove the connector.
Here's the possible wiring configurations you can use and how that will affect an illuminated switch. The black thing with the gray band at one end is the diode you'll need for that configuration. You can also tap into your Illumination wire instead of the white/blue wire, in which case the light will still behave as mentioned in the drawings, but only when the dash lights are on. You'd use a red wire tap instead of a yellow one, and you'd tap the Red/blue wire at your dimmer switch. The switch light will not dim along with the rest of your gauge/switch lighting. The reason it will not is because the dimmer regulates the ground for the lighting system, which causes it to dim. Since illuminated switches ground through the circuit they are controlling they don't have a seperate ground for the bulb. Since we are using this switch to open and close a ground circuit, we cannot use this circuit to power the bulb and ground the bulb through the proper wire at the dimmer.
The reason two wires are shown tapped is just to depict how you'd tap into both fan triggers for an automatic.
As a courtesy to fellow enthusiasts, PM or E-mail me if you’d like me to put together a kit for you which will include a hard copy of these instructions. I can also help you figure out how to do this for any car you own.
- Rob
Old 01-28-2005, 12:32 PM   #2 (permalink)
Master Cunnilingust
Update
I realized I made a mistake when I originally wrote this. The fan relays only have power when the ignition is in the On or Start positions, so there's no risk of the fans running when the ignition is off. So you don't need a relay at all, you just need a switch. So at the track, you'll just have to keep the ignition switch to the On position, and not only will the fans run as they normally would when the ECU calls for it, but you can use the switch to override as well.
Old 06-25-2005, 10:07 PM   #3 (permalink)
Rob
Feedback Score: 6 reviews
i need this upgrade..why are the pics down?
2K2 SE 6spd Maxima
Old 06-25-2005, 10:46 PM   #4 (permalink)
Master Cunnilingust
Pics restored.
Old 06-28-2005, 07:58 PM   #5 (permalink)
Rob
thx! chriscar hooked this up for me and wow! finally the car can run cool! great writeup and pics! thx again! and chris..next time i see you i got a surprise for your father day gift!
Originally Posted by Toolapcfan
Pics restored.
Old 08-13-2005, 05:54 PM   #6 (permalink)
OMFG WTF BBQ
walrusx4's Avatar
Feedback Score: 5 reviews
Just finished my install today, and I declare my independence from mild overheating in traffic.
What a great writeup, this is an easy mod even for those without a lot of electrical experience.
NAPA has a great switch (Valmar model 31302 part no. 751-1089) that is illuminated, and almost fits PERFECTLY in one of the blank switch holes (next to the cluster dimmer switch or next to the power mirror controls).
ONE MORE IMPORTANT NOTE, when reading the ECU Pinout diagram, make sure to pay close attention to the orientation of the diagram. the way my ECU was situated, I had to rotate the diagram 180 degrees. YMMV, just be extra careful to get the right wire.
~Dan @ LA
Old 02-08-2006, 07:32 AM   #7 (permalink)
There is a very simple way to accomplish this same thing.
If you don't have AC you can run a single wire from the AC harness (I'll find out which plug and wire) to power. Then you engage the "non-existent" AC via the lighted button on the AC controls and the fan runs. I will take another look at it tonight an post up.
'91 SE-R SR20DET
Rev1 is offline   Reply With Quote
Old 02-08-2006, 03:49 PM   #8 (permalink)
starting over
Feedback Score: 3 reviews
REV1, Im all over that. See what you can find I need to jerry rig my fans and this would be perfect fix.
SoloSol is offline   Reply With Quote
Old 02-11-2006, 06:37 PM   #9 (permalink)
You're Ugly!
Feedback Score: 18 reviews
this works awesome! just did it today, i thought about that A/C switch but meh a regular lighted switch works awesome. now i dont have to worry about being stuck in traffic .
SR20DEEP CA
shingouki1 is offline   Reply With Quote
Old 04-01-2006, 01:11 AM   #10 (permalink)
just a G thang
i need the pics....can you please upload them?
vince
G20/Primera
D2 damper kit, hotshot cold air intake, topspeed header, nismo radiator cap, front superpro bushings, octocat rear strut bar, obx b10 axle back exhaust, Apexi SAFC-ll, P11 mesh rims, Primera phase 1 grille, Primera amber corners, NGK iridium plugs, 300zx tt fuel filter, Primera sidemakers and striped interior
GUAM'S G20 is offline   Reply With Quote
Old 04-15-2006, 01:05 PM   #11 (permalink)
Master Cunnilingust
vince
Pics are there.
Old 06-02-2006, 01:29 PM   #12 (permalink)
Empire-CAT Machinery Tech
so all i have to do is connect wires 9 and 10 from the ecu to a switch and thats it?? or more.
if theres any pictures of this process it would help. *** reading and reading confuzes me alot. im more of a show and learn type. thanks!!
2010 Chrysler 300c
1994 Sentra SE-R
[B]91 Mint SE-R (third owner)
Mods: Black, Very Clean, Turbo. -weekend warrior-
SE-Riouse_93 is offline   Reply With Quote
Old 06-02-2006, 08:20 PM   #13 (permalink)
Master Cunnilingust
Yes, connect those wires to a switch and the other side of the switch to ground.
Old 06-05-2006, 03:08 PM   #14 (permalink)
ok cool. lets see how it goes
Old 07-10-2006, 03:11 PM   #15 (permalink)
technics professional
Avshi750's Avatar
question about this setup... i might have a bad switch.
i have my switch and wires hooked up exactly like this, but the light does not come on when i flip the switch or when the ecu starts the fans.
if i switch the power and ground wires then the light comes on when i flip the switch but the fans do not turn on.
any ideas?
Avshi750 is offline   Reply With Quote
Old 07-10-2006, 07:31 PM   #16 (permalink)
Master Cunnilingust
It depends on how the switch you're using operates. You need to use a multimeter to figure out which two terminals the bulb is across and which terminal is the open side of the switch.
Old 07-15-2006, 10:57 PM   #17 (permalink)
DBA/IT
Feedback Score: 22 reviews
ok lol, I dunno what the hell was up with my wiring, but I wired my illuminated switch (has power, acc, and ground terminals on it) according to the "switch is lit when the fans are on" diagram, but doing so keeps the fans on all the time, even if I flip the switch either way. I tried reversing the acc/power wires, but that made the fans stay on with the switch on, but if I turn the switch off, and try to turn it on again, the fans won't turn back on, and I don't think the switch lit up either... weird crap.
So finally I just used the Non-illuminated switch diagram, and that seems to work--the switch illuminates when I flip the switch to the on position. I ditched the wiring on the ACC terminal of my switch. Not sure if the switch illuminates when the ECU kicks the fans on, though. I'll post later if it does
http://www.rollyourcar.com
Old 07-15-2006, 11:31 PM   #18 (permalink)
Avshi750's Avatar
i had to go back to Radio Shack to double check the packaging.
the switch is setup just like the one in the diagram...
1-power / 2-signal / 3-ground
i'm thinking i should double check that the switch is getting power.
Old 07-16-2006, 02:03 AM   #19 (permalink)
Master Cunnilingust
Right, but if that "X", which represents the bulb, is between 2 and 3 or 1 and 3, then that changes how the switch works.
Old 07-16-2006, 02:07 AM   #20 (permalink)
Master Cunnilingust
I apologize for having not figured out how your switch worked prior to sending it to you. I can figure it out though. I'm going to go get another identical switch to take a look at and I'll get back to you.
HTML code is On
