HOW TO: Make a new spare tire cover - SR20 Forum
Old 10-16-2004, 04:11 PM   #1 (permalink)
Master Cunnilingust
Feedback Score: 37 reviews
Tools/Supplies needed:
Pencil
Jigsaw
wood blade for jigsaw
Drill
3/16" drill bit
Pop rivet gun
3/16" diameter 1/4" grip range aluminum rivets
Single sided foam tape
4'x8' sheet of 1/4" thick tempered masonite (sometimes a half sheet costs more than a full, so you might want to buy a full sheet. If you're driving your car, have them cut it in half for free and then either toss the other half or save it for something else.
Assembly time:
15-20 minutes
Assembly:
Lay the old crappy spare tire cover over the sheet of masonite. I layed mine out so that the rough side will be up, which will keep the carpet from sliding around when you have things setting on it. Using the drill and drill bit, drill out the rivets holding the plastic tabs onto the cover and remove the tabs. If your tabs are broken off or missing, you could buy a couple PVC plumbing caps and screw those on instead. Trace the outline of the cover onto the masonite and transfer the holes for the plastic tabs. Tracing the grab hole is optional, I didn't because I can easily remove the board without it. Use the jigsaw to cutout the outline of the board. Use the drill and drill bit to drill two through holes for the plastic tabs. Drill 1/8" deep holes side by side for the little bump on the plastic tabs that keeps them oriented. Use the pop rivets and rivet gun to attach the tabs to the masonite. Place 2" strips of the foam tape on the outside corners and around the center in the spots where they were on the OEM board. I didn't have any so I skipped this step. Install in car, replace carpet and enjoy! This board is twice as thick as the OEM one so it will work much better. Hooray!
- Rob
Old 12-08-2004, 09:30 PM   #2 (permalink)
where do you buy the material from Home Depot?
Hotshot CAI, Hotshot headers, Custom 2" mandrel bent Cat-back exhaust, ACT clutch kit, Fidanza Flywheel, Progress sport springs, KYB AGX struts, Advanced timing. 17" Exel shu-4 wrapped in the new BFGoodrich G Force Sport, Unorthodox Racing Underdrive Pulley.
Hotboy is offline   Reply With Quote
Old 12-09-2004, 12:19 PM   #3 (permalink)
Tired!
coach's Avatar
Feedback Score: 43 reviews
Very cool Tool!
Brent
1999 SE-L -- back to NA form
Old 12-09-2004, 02:21 PM   #4 (permalink)
Se-riously???
Feedback Score: 8 reviews
Hmm, but what about trying to save weight? Those of us that don't run with a spare or jack don't need that, or the carpeting!
j/k but nice detailed writeup
Edit: That cover looks just like mine, bent out of shape and moldy.
I've always wanted a RWD SE-R, maybe after I win the Lotto.
Nismoguy is offline   Reply With Quote
Old 12-09-2004, 10:53 PM   #5 (permalink)
Master Cunnilingust
I already had some masonite in my garage. But yeah, Home Depot, Lowe's and lumber yard will have it. I prefer to patronzie Lowe's, they're a much better store. When I buy thousands of dollars worth of materials for jobs that I do, I always go to Lowe's.
Old 12-15-2004, 09:20 PM   #6 (permalink)
SR20-less
Has anyone tried to make it out of something stronger? Maybe something that wouldn't warp or bend over time.
Aluminuim
Carbon Fiber
Fiberglass
dbrier is offline   Reply With Quote
Old 12-17-2004, 12:44 PM   #7 (permalink)
JDM BOOST WHORE
SR20 91 SE-R's Avatar
Feedback Score: 12 reviews
Do You Have Measurements? I Dont Have The Old Cover But I Would Like To Make One Myself.
SR20 91 SE-R is offline   Reply With Quote
Old 12-17-2004, 01:51 PM   #8 (permalink)
Master Cunnilingust
I used 1/4" masonite, that's twice as thick as the OEM one and is plenty strong and probably won't warp. Making it out of anything else would just be time consuming and expensive. I'll get measurements for you SR20 91 SE-R.
Old 12-17-2004, 03:28 PM   #9 (permalink)
JDM BOOST WHORE
cool thanks.
HTML code is On
