Old 02-28-2005, 12:04 AM   #21 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
It's not hard at all, but I assure you, a 10 minute job would not be done right.
- Rob
Old 02-28-2005, 03:09 AM   #22 (permalink)
SE-R Protection League
I have trouble finding that extension-cord box.
Where did you get it?? Home Depot??
JCCT is offline   Reply With Quote
Old 02-28-2005, 06:44 PM   #23 (permalink)
Master Cunnilingust
Harbor Freight Tools for $3.
Old 09-24-2005, 10:22 PM   #24 (permalink)
www.myspace.com/djmanila
i just wanted to ask.
what's the name/specs of the tool needed to remove the kickplate?
i'm referring to the screw on the kickplate that looks similar to a hex head.
crispmofo is offline   Reply With Quote
Old 09-25-2005, 12:11 AM   #25 (permalink)
Master Cunnilingust
I'm pretty sure they're just held in with phillips head plastic screws.
Old 09-25-2005, 05:03 AM   #26 (permalink)
i'm talkin' 'bout the long kick panel along the door jamb which the seat belt lines up with. it's the kick panel that you hide the amp wire under and the one that stretches along side your seat.
i swear mine has a hex looking head that looks like this: * *
is it just my car?
i went to try to remove it thinkin' it would just be phillips like my 240, but no.
Old 09-25-2005, 06:01 AM   #27 (permalink)
is it just my car?
Your answer is Torx.
Enjoying the Ride since 1993
Two Classic SE-Rs, Twice the money-pit
Old 09-25-2005, 08:26 PM   #28 (permalink)
thanks buddy..
i went out and bought a torx set and the size i needed was a T-40.
Old 10-23-2005, 03:47 AM   #30 (permalink)
stuff
that's a clean ass install dude. u think u can let me get the routines for the tray and the bracket? i want to make my own now.
www.b16sentra.net
MyNutzOnYurChin is offline   Reply With Quote
Old 10-23-2005, 01:05 PM   #32 (permalink)
stuff
ah i thought u made em yourself..
Old 10-23-2005, 01:38 PM   #33 (permalink)
Trader Rating: 70 (99%)
You need that heavy wire because you are going to lose voltage stretching it that far.
FarmBoss is offline   Reply With Quote
Old 10-23-2005, 02:31 PM   #35 (permalink)
Originally Posted by Ninety-Nine SE-L
Wire choice IMO is very important. As you can see, I have the battery grounded 4X. For the main wire, 4AWG is not sufficient, you will lose voltage and most likely power b/c the alternator has to work harder. 2AWG is good for our cars. 1/O like I have might seem like much, but I know I have no voltage loss across the band. The battery charges more efficiently, the alternator doesn't work as hard, the electrical systems perform better.
You are very correct. Running 12DC on braided wire that far is definitely going to require the 1/0
Old 10-23-2005, 07:12 PM   #36 (permalink)
ECU Geek
tall1's Avatar
The battery tray can be found at speedway motors.
http://www.speedwaymotors.com/xq/asp...qx/product.htm
tall1 is offline   Reply With Quote
Old 10-23-2005, 09:59 PM   #37 (permalink)
Very nice write up!!
Home of the low (Original) Mileage B13
1992 B13 SE-R - Original Owner. 66K
2004 Avante XD2 GT - DD
2000 Miata LS - Top Down Fun!
MY SIG PIC ------------> http://i34.photobucket.com/albums/d1...31/SE-REGT.jpg
Originally Posted by Octave236 View Post
Uh i believe your contridicting yourself. B13's are highport motors unless a lowport was swapped in.
CleanSE-R is offline   Reply With Quote
HTML code is On
