HOW TO: Nissan part numbers for suspension nuts and bolts
To add my ES bushing kit, I had to replace alot of my suspension nuts and bolts due to the car spending most of its life in Ohio. It took 2 phone conversations, a few e-mails, and 3 shipments to finally get all the nuts and bolts that I was looking for. So… I have decided to list all the Nissan part numbers AND where each nut and bolt is located to make it easier for anyone else to repeat what I just did.
A note, I did not list the swaybars nuts or bolts mainly because I added the Progress piece and it had all the appropriate nuts and bolts that I needed.
FRONT
Lower Control Arm to Body
(2) 54368-50Y212 bolt
(2) 08912-9441A self-locking nut
(4) 01121-05511 bolt with lock-washer
Strut to Knuckle of Hub
(4) 40056-71L00 strut bolt
(4) 01225-00072 strut nut
Torque Member to Hub
(4) 41250-01A00 bolt
REAR
Body to parallel links
(2) 55226-50Y00 toe adjustment bolt
(2) 08024-4651A bolt
(4) 08912-9441A self-locking nut
Parallel links to Hub
(2) 55166-50A01 bolt
Lateral link to Hub
(2) 08024-4651a bolt
