HOW TO: Read Nissan CEL codes - SR20 Forum
Old 11-15-2004, 06:48 PM   #1 (permalink)
Feedback Score: 18 reviews
First off it is a good idea to check your ecu every once in a while to see if they are any stored cels that may have not triggered a Check engine light
11 Crank angle sensor/circuit (1988 to 1990); Crankshaft position sensor (1991 to 1996)
12 Air flow Meter/circuit open or shorted
13 Cylinder head temperature sensor(Maxima and 300ZX models); all others coolant temperature sensor circuit
14 Vehicle Speed Sensor signal circuit is open
15 Mixture ratio is too lean despite feedback control; fuel injector clogged
21 Ignition signal in the primary circuit is not being entered to the ECU during cranking or tuning
22 Fuel pump circuit (Maxima and 1987 and later 300ZX models); all others idle speed control valve or circuit
23 Idle switch (throttle valve switch) signal circuit open
24 Park/netural switch malfunctioning
25 Idle speed control valve circuit is open or shorted
26 Turbo boost
28 Cooling fan
29 Fuel system rich
31 1984 through 1986 EFI models; Problem in air conditioning system; all other models: ECU internal problem
32 1984 through 1986 EFI models; check starter system. All other models: EGR malfuntion (California models)
33 Oxygen sensor or circuit (300ZX left side) - all other models EGR malfunction
34 Detonation (Knock) sensor
35 Exhaust gas temperature sensor (California models)
36 EGR transducer
37 Closed loop control/front oxygen sensor (Maxima)
41 Maxima and 1984 through 1987 300ZX models; fuel temp sensor circuit. All other models: air temperature sensor circuit
42 1988 and later 300ZX models; fuel temperature sensor circuit; all other models: throttle sensor circuit
43 The mixture ratio is too lean despite feedback control; fuel injector clogged (1987 Sentra only): All others; Throttle position sensor circuit is open or shorted
44 No trouble codes stored in ECU
45 Injector fuel leak (California models only)
51 Fuel injector circuit open (California models only)
53 Oxygen sensor (300ZX right side)
54 Short between automatic transmission control unit(TCU) and ECU
55 Normal engine management system operation is indicated
63 Misfire detected - cylinder no. 6
64 Misfire detected - cylinder no. 5
65 Misfire detected - cylinder no. 4
66 Misfire detected - cylinder no. 3
67 Misfire detected - cylinder no. 2
68 Misfire detected - cylinder no. 1
71 Misfire detected - random
72 Catalytic converter malfunction (right side)
74 EVAP pressure sensor
75 EVAP leak
76 Fuel injection system
77 Rear oxygen sensor
81 Vacuum cut bypass valve
82 Crankshaft sensor
84 Automatic trans-to-fuel injection communication
85 VTC solenoid
87 EVAP canister purge control
91 Front oxygen sensor
95 Crankshaft sensor
98 Coolant temperature sensor
101 Camshaft sensor
103 Park/neutral switch
105 EGR and canister control valve
108 EVAP volume control
0505 No self diagnostic codes present
0101 Camshaft position sensor
0102 Mass airflow sensor/circuit
0103 Coolant temperature sensor
0104 Vehicle speed sensor
0111
EVAP purge flow monitoring system
0114 Fuel system rich
0115 Fuel system lean
0201 Ignition signal
0203 Closed throttle switch
0205 IACV/AAC valve
0208 Overheating
0213 EVAP system
0214 Purge volume control valve
0301 ECM control unit
0302 EGR function
0303
Front heated oxygen sensor malfunction
0304 Knock sensor
0305 Exhaust gas temperature sensor
0306 EGRC BPT valve
0307 Closed loop operation
0309 Vent control valve
0311 Vacuum cut valve bypass valve
0312 EVAP system purge control valve
0401 Intake air temperature sensor
0402 Fuel temperature sensor or circuit
0403 Throttle position sensor
0409 Front oxygen sensor
0410 Front oxygen sensor
0411 Front oxygen sensor
0412 Front oxygen sensor
0503 Front oxygen sensor
0510 Rear oxygen sensor
0511 Rear oxygen sensor
0512 Rear oxygen sensor
0514 EGR system
0605 Cylinder 4 misfire
0606 Cylinder 3 misfire
0607 Cylinder 2 misfire
0608 Cylinder 1 misfire
0701 Multiple cylinder misfire
0702 Catalytic converter
0704 EVAP system
0705 EVAP system
0706 Fuel injection system malfunction
0707 Rear oxygen sensor
0801 Vacuum cut valve bypass valve or circuit
0802 Crankshaft sensor
0803 Absolute pressure sensor
0804 A/T diagnosis comm line
0807 EVAP canister purge control
0901 Front oxygen sensor heater
0902 Rear oxygen sensor heater
0903 Vent control valve
0905 Crankshaft position sensor
0908 Coolant temperature sensor
1003 Park/neutral switch
1005 EGR solenoid valve circuit
1008 EVAP system
1101 Inhibitor switch
1102 A/T vehicle speed sensor
1103 A/T first signal
1104 A/T second signal
1105 A/T third signal
1106 A/T fourth signal
1107 A/T torque converter clutch
1108 Shift solenoid A
1201 Shift solenoid B
1203 Overrun clutch solenoid
1204 TCC solenoid
1205 Line pressure solenoid
1206 TPS for A/T
1207 Speed signal A/T
1208 A/T fluid temperature sensor
1302 MAP/BAR switch solenoid valve or circuit
1305 Fuel pump control module or circuit
1308 Cooling fan
this list was taken from PHATG20.net
Project Shift_Rebirth
i buy blown trannies
Nyc Sr20PowerD is offline   Reply With Quote
Old 01-09-2005, 03:57 AM   #2 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Feedback Score: 34 reviews
So might we want to elaborate on how to get these codes from the ECU?
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 01-09-2005, 02:32 PM   #3 (permalink)
easy 400WHP
Feedback Score: 36 reviews
my guess would be an OBD I scanner/reader
~jRod
Old 01-10-2005, 02:47 AM   #4 (permalink)
SENTRASER's Avatar
http://www.se-r.net/engine/ecu_codes.html
http://www.troublecodes.net/Nissan/
HTML code is On
