HOW TO: Replace CV boot - Page 3 - SR20 Forum
Old 01-24-2006, 11:12 AM   #41 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
Absolutely not.
Old 01-24-2006, 09:36 PM   #42 (permalink)
3 NX2000's
NX2KTPR's Avatar
Feedback Score: 5 reviews
Originally Posted by chriscar
Absolutely not.
Hey, its in the FSM for a Chevy Cavalier, so its gotta be fine for a Nissan
Tim Rogers
'91 NX2K- Black, parts car
And yes, I've broken it...
NX2KTPR is offline   Reply With Quote
Old 02-03-2006, 06:03 PM   #43 (permalink)
Okay I have a problem.
I took everything off, but the cv joint would not come off.
I have tried to hammer it out, but it would not move.
Any methods?
w3e4r is offline   Reply With Quote
Old 02-03-2006, 06:18 PM   #44 (permalink)
Actually I just found out that I have still have the c clip on.
Do I need to remove the clip in order to take the cv join off the axle?
Old 02-03-2006, 07:00 PM   #45 (permalink)
3 NX2000's
NX2KTPR's Avatar
Remove the C-Clip, then the nut behind it.
Old 02-03-2006, 08:20 PM   #46 (permalink)
which nut?
Old 02-03-2006, 11:17 PM   #47 (permalink)
The NVious 1
Feedback Score: 4 reviews
the nut that is behind the clip. I believe its a 32mm socket or 34mm socket i can't remember
TEAM NV/ Traffik Blockin NYC
02 Sentra SE-R Spec V: current car
93 Sentra SE-R : Sold
92 Sentra SE-R : 15psi... Sold
95 200sx SE-R: Project Car: Junked
94 Sentra SE-R : Boosting Again :Sold
92 Sentra SE-R : Turbo Project Totaled
91 Sentra SE-R : Tuck on 15s 1 of the first to have Ksport drop :Sold
92 Sentra SE-R : Junked Rusted to Hell
91 Sentra SE-R : Crashed :Sold
Nismo SR20DE is offline   Reply With Quote
Old 02-04-2006, 12:28 AM   #48 (permalink)
I have taken that off a long time ago.
Old 02-04-2006, 11:09 AM   #49 (permalink)
Here is my joint
Red circled part is the opening of a clip that is on between cv joint and axle.
You see the opening of that clip? Do I somehow have to take that off before attempting to take off my cv joint?
I JUST CANNOT PULL THAT DAMN CV JOINT OUT!!! I HAVE TO CLEAN IT!!!
HELP.
Are there any tools I have to use?
Old 02-04-2006, 07:26 PM   #50 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Feedback Score: 34 reviews
I just beat mine with a hammer, the joint pops off the shaft.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Old 02-05-2006, 06:36 AM   #51 (permalink)
Yep, that part's easy. Getting it back on and over the circlip can be a real PITA. The last one we did took hours of banging and rearranging of that damn circlip. If anyone has a better method, I'd love to hear it. Some rebuilds have gone smooth at this step, but the last one SUCKED!
adg016 is offline   Reply With Quote
Old 02-05-2006, 11:57 AM   #52 (permalink)
SENTRASER's Avatar
Use some grease to locate the clip in the middlie, line up the joint perfectly with the splines, give it a couple good wacks with a brass hammer!
Old 02-05-2006, 01:19 PM   #53 (permalink)
Yep, that's what we do. It's not brass, but it's a deadblow, non-marring hammer. Very solid. Still, it took hours to get this last one on. I've done it before, but this one was a beatch.
Old 05-10-2006, 04:33 PM   #54 (permalink)
Original Owner
I'd like to add 3 points to this:
1. I'd suggest getting 2 new axle nuts ahead of time because the hitting of them with the BFH could distort them and they may be very difficult (or impossible) to put back on. As me how I know and how impossible it was on a Sunday to get replacements and how long it took me to file the distorted sides down in order to "true" it so I could get the nuts back on
2. I was able to clean the outer joint without taking it apart. I took one side completly apart and had one heck of a job putting it back together. I marked the inner race and each bearing but all markings came off when I cleaned them and the ball bearings got mixed up. In fact, I must admit I felt uncomfortable that I installed the inner race incorrectly. I took it apart after assembly and had in fact put the inner race in backwards. I spent a lot of wasted time and aggravation because of this. When I got around to the other side, I cleaned out as much of the old grease as I could without disassembly, sprayed it with Gunk, hosed if out (repeat until clean), air dryed it, and then poured hot soapy water in it, and compressor air dried it again-then put the CV joint grease in it. Worked out excellant, completed it MUCH quicker than a complete disassembly and had no worry that I might have put something back incorrectly. But by doing this you won't be able to visually inspect either the bearings or where they roll. I knew mine were OK so it didn't matter to me - I just was replacing old boots. And finally.
3. It would also be a good idea to have a couple extra circleclips on hand - you will get extras in your boot kit but I busted 2 when putting the outer joint back onto the axle. It just gave me a bad a** time and they just didn't want to go back on.
'91 SE-R, Original owner, PowerSlots, Axxis MM, Magnacore, Michelins, NGK's , Stromung cat-back and 90K orig miles. Spring '06 work: GR2's and boots with orig. springs, ball joints, TR ends - inner and outer, ES front CA bushings, CV joint rebuild.
lowmileage is offline   Reply With Quote
HTML code is On
