Go Back   SR20 Forum > Vendor Customer Support > CalumSult > Traditional ROM board support
Old 04-08-2008, 08:56 PM   #1 (permalink)
Rear O2 sensor help
My Ecu was done by Calum and it was supposed to cancel the O2 rear sensor, but every time i disconnect the sensor the 07 07 code appears!
Is there any way I can jump the connector with or something to prevent this happening? thanks!
gsus is offline   Reply With Quote
Old 05-26-2008, 10:11 PM   #2 (permalink)
I'm Big Cheddar
Trader Rating: 27 (100%)
The rear o2 sensor delete sometimes works, and sometimes doesn't. Because it's a resistor mod, there's no GUARANTEE that it will work. I have the rear o2 delete and it's working, but initially didn't. I would at least leave the rear o2 connected. Mine is connected but not correctly, as I have a 98 SE-R and a 95~97 ECU.
SR20DEEP MD
05 Armada - Tow Truck
98 SE-R - bitch boost
'84 910 Deluxe - Project
Old 05-27-2008, 07:41 AM   #3 (permalink)
HATER
i think on the order form it says to leave the rear o2 connected, you need to get some type of voltage to lie and say that it's still working right?
mine is currently zip tied above my "cat" because i broke the threads off of it and wasn't about to buy another i should relocate to under the carpet under drivers seat if that's safe
live fast die young
cause4alarm is offline   Reply With Quote
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
