PLX Devices Authorized Distributor / Dealer - SR20 Forum
Go Back   SR20 Forum > Vendor Customer Support > Tuner Tools, LLC
Old 06-07-2009, 07:17 PM   #1 (permalink)
As a vanity post, just wanted to pass along that Tuner Tools is now a fully stocking and authorized warehouse distributor for PLX Devices. Dealer inquiries are welcomed.
PLX Devices has a complete line of sensors, sensor modules, and SEMA award winning customizable gauges which can combine OBD data and multiple external sensors together into one or more skinable and customizable gauge pod.
Their M300 Tuner Edition AFR Wideband Meter & Controller is one of the most highly rated in this price range.
TunerTools is offline
Old 06-07-2009, 07:17 PM   #2 (permalink)
Description of what the PLX Multi-Gauge is:
The PLX MULTI-GAUGE is designed specifically to display a wide variety of automotive information far superior to that of a standard automotive gauge. The MULTI-GAUGE can display up to 4 different sensors of your choice simultaneously. Unlike other automotive displays on the market where the user has no choice but to view the data presented in one form PLX has designed the MULTI-GAUGE so that you can set and change your viewing preferences at any time. All styles have their unique advantages and you should not be limited to one option.
Description of the PLX Multi-Gaue w/ OBD-II:
The PLX MULTI-GAUGE with OBDII has taken the automotive display to a whole new level. Now not only can you daisy chain our Sensor Modules but you also have access to all data on your ECU. This allows you to view all parameters of your vehicle and also act as a scan tool to check and clear engine codes when necessary. Unlike other automotive displays on the market where the user has no choice but to view the data presented in one form PLX has designed the MULTI-GAUGE so that you can set and change your viewing preferences at any time. All styles have their unique advantages and you should not be limited to one option.
