HOW TO: Wire E-manage for all harnesses. - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > Turbo Guides
Old 02-18-2005, 10:55 PM   #1 (permalink)
oh so LAZY
Feedback Score: 8 reviews
This is how to wire your Emanage for the injector, ignition, and main harness, without buying all the harnesses.
A great new resource is the emanage forums: http://www.emanageforums.com/
Start off with the Rotary Switches set like Tomcat says here:
Originally Posted by Tomcat5678
I have the rotary settings, the three screws on the inside you can't see from the outside, set to 2-0-7 and that is on my B14. If you are using your stock MAF then just leave the setting to what it picks by defult.
I think those settings are true for both B13 and B14's.
-Erik
Here's for the noobs:
http://www.mohdparts.com/emanage/ins...elp/index.html
First picture is of main harness.
We have 4 injectors, unless someone with an RB is reading this or other non-Nissan 6 cylinder, so we use:
Injector 1: blue/red
Injecotr 2: orange/red
Injector 3: yellow/red
Injecotr 4: purple/red
Injector Ground: black/red
Now those colors don't HAVE to be that, those are just to reference the locations on that picture. Just write down what color wires you used from the ignition harness for your application.
Second picture:
Ignition harness (plug 2 that comes with the ignition harness)
1) Cut your ignition wire that goes to your ECU.
2) ECU to E-manage Ch. 1 in (blue/white)
3) E-manage to car Ch. 1 out (blue/black)
Done!
Those colors you should not have to change, you can use those exact colors.
Now you have full control of ignition and injector maps.
Hope this helps.
Did I get everything Nate? I better ask because you will check my sh*t out.
This is my own diagram of what each wire is on the Main Harness
here is the wire diagram for the b14/p11 provided by tomcat, it corresponds dirrectly with the daigram above.
Here is the wire diagram from phatg20.net for the b13/p10
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 04-21-2005, 05:54 PM   #2 (permalink)
Will,
Could you update the picture location to this please:
http://www.sr20forum.com/img/data/500/OBDII_Wiring1.jpg
'97 SE-R with BB T25 setup, G20 ECU, E-Manage, Starion FMIC, SPEC 6 puck stage 3 clutch, KYB AGX's, fully shaved doors including side molding, Royal Sapphire Pearl (Toyota Supra) paint, Stock headlights (Halo headlights included), Aerogear vented hood, 98 Sentra Grille, modified stock front bumper (Vis Extreme front bumper included), Andy's Autosport rear bumper, and Kenwood Excellon CD player
Tomcat5678 is offline   Reply With Quote
Old 06-20-2005, 12:18 PM   #3 (permalink)
Feedback Score: 42 reviews
OK, Im aobut to go install my emange... Thanks for the info!
However, I just noticed an error that might not get picked up by others. The harness u have labeled going from Injectors 1-4, should be the other way around going from injector 4-1, left to right of the picture.
Looking for a cheap SR20 mechanic in the NYC area, or a garage w/ Tools... PM me.
Erikbronx is offline   Reply With Quote
Old 06-20-2005, 03:11 PM   #4 (permalink)
oh so LAZY
I just checked that out, you are absolutly correct. Now Im a bit concearned that mine are hooked up wrong , ill change the daigram.
Old 06-20-2005, 03:22 PM   #5 (permalink)
Can't believe Nate or myself didn't catch that before. Weird!
Old 06-28-2005, 12:54 PM   #6 (permalink)
Feedback Score: 6 reviews
Hi guys,
The info you posted here is great, but I have a question about the airflow meter hookup.
My GA16DE (Mexico built) has 2 wires (Orange and white) which goes to the ECU as "Mass Airflow sensor 1" and "Mass Airflow sensor 2" as shown on your diagram.
Do I intercept one of these wires to the emanage unit? Or do I intercept the Green/Yellow ( goes to ECU pin #27)
Thanks
Adam
http://www.execulink.com/~jkube/Adam...entrapage.html
sentra2bturbod is offline   Reply With Quote
Old 06-28-2005, 01:53 PM   #7 (permalink)
You don't use Mass Airflow Sensor 2 unless you have two MAF's like a Skyline or similar setup. (You can use MAF input 2 if you have a wideband but that is a totally more involved setup then your standard wiring.)
You should intercept only one wire coming from the MAF, it's the signal wire, you don't want the constant power wire. What year car do you have? (OBDII or OBDI)
Old 06-28-2005, 02:10 PM   #8 (permalink)
oh so LAZY
you mean MAF in and MAF out? are you talking about on the emanage or on the ECU harness?
Old 02-03-2007, 01:38 PM   #9 (permalink)
can anyone post up little instructions on how to actually move around the program and tune the software for b13. ANYONE?
502whp STOCK SR20DE BABY!!!!!!!!!
Soon to come 600+WHP SR20DE-T (Fully Built)
danilo20 is offline   Reply With Quote
Old 05-02-2007, 04:22 PM   #10 (permalink)
8000rpm crew
Feedback Score: 22 reviews
How about ignition control? is it worth it?
VVL Power
gtswrx is offline   Reply With Quote
Old 11-01-2007, 02:34 AM   #11 (permalink)
Feedback Score: 18 reviews
Project Shift_Rebirth
i buy blown trannies
Nyc Sr20PowerD is offline   Reply With Quote
HTML code is On
