HOW TO: make your own manual boost controller - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > Turbo Guides
Old 05-26-2005, 01:43 AM   #1 (permalink)
The Genesis
Feedback Score: 12 reviews
Materials needed:
1 x 1/8" NPT 1/4" Barbed Nipple (Male Fitting)
1 x 1/8" NPT 1/4" Barbed Nipple (Female Fitting)
1 x 3/16" Ball Bearing
1 x Utility Spring
2 x 1/2" Hose Clamps
The barbed fittings are used from compressors, but you should screw them onto each other so that you have a nipple on each end. The spring and ball bearing go inside so that essentially the spring presses on the ball bearing firmly against the inside of one of the fittings to seal the hole off. If the spring is too short, you can pull on it to make it a little bit longer, but if its too long, you can cut a big of the spring off, enough so that the spring presses against the fitting. Once everything is in together, you will be able to adjust the boost by simply turning the fittings together. this is an effective way to manipulate boost manually, all for under 5$
Dork!
Old 05-27-2005, 05:48 AM   #2 (permalink)
Feedback Score: 10 reviews
do you have pictures of it
dirk
Nx2000 317whp ex
s13 rb26dett swap done
micra k10 sr20 1672 lbs
http://i642.photobucket.com/albums/u...n/SDC11980.jpg
Dirk is offline   Reply With Quote
Old 01-16-2006, 08:06 PM   #3 (permalink)
NXTACY
yes i too would like to see a diagram of this or at least the parts just to finish off my imagination before such a $5 venture...
-~10.8:1 CR (2mm Shave) + 17° timing
-WAI: Aluminium Intake w/ OBX Foam POD
-Hurricane Headers w/ 1.75' Secondaries
-2.5' Mandrel Bent Cat Back system.
-KYB GR2 Struts on Stock Springs
-Prothane Motor Mount Inserts
-NGK Iridiums (BR6) + Top Gun 8mm Leads
-Shortshifter + Nismo GK
- Crane LX91 Ignition Coil
-Adj. FPR @ 45psi Vac On
-JDM Inlet Manifold (No EGR!!!)
dsp26 is offline   Reply With Quote
Old 03-31-2006, 09:19 PM   #4 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Feedback Score: 34 reviews
Pictures make the world go round.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 05-16-2006, 07:26 PM   #5 (permalink)
_scott
CivicsSuck's Avatar
Feedback Score: 9 reviews
.........interesting,,,,,,,,,,,,,,,,,,pics please---------please
13.29 - 108 mph
226whp 225trq
My Avenir Project:
http://www.sr20forum.com/members-rides/157517-avenir-section-402-a.html
06 Frontier, Nismo package
http://memimage.cardomain.net/member...51_26_full.jpg
06 Honda 450R, few goodies
http://memimage.cardomain.net/member...51_27_full.jpg
CivicsSuck is offline   Reply With Quote
Old 05-19-2006, 07:51 AM   #6 (permalink)
JRios's Avatar
Feedback Score: 7 reviews
Have a look at this site, it explains the procedure just as above and it also has pics.
http://www.c-speedracing.com/howto/mbc/mbc.php
Jorge
1996 SE-R
Old 05-19-2006, 08:58 AM   #7 (permalink)
Master Cunnilingust
Feedback Score: 37 reviews
You could also go to Harbor Freight and buy an air regulator for ~$3 and the same two male and female barbed nipples for ~$.99 each, thread one on to each side and there you go.
- Rob
Old 05-24-2006, 03:08 AM   #8 (permalink)
Made this one today.. Very good idea and I see how it works, but, I got really bad boost spiking..
Wastegate = 7psi, and I slowly up'd the boost with the homemade mbc,
Spike to 10, back down to 7-8 ish
spike to 13, back down to 7-9 ish
Spike to 16, back down to 7-9 ish
Anyone have any ideas?
N14 Gti Pulsar
Gtir engine, Hybrid FMIC kit, Walbro 255, Nismo FPR, 3" mandrel bent exhaust w/ chrome RPS tip, 4 puk ceramic clutch, 2000lb pressure plate, Lightened, balanced flywheel, Greddy Type-RS BOV, Apexi AVCR - To be installed, 7psi for now!
Click here for a little vid of my speedo! - Thanks to Markbuts3 for editing and hosting!
NZ_GTiR is offline   Reply With Quote
Old 05-24-2006, 07:35 PM   #9 (permalink)
Dimer
Try using a stiffer spring and readjust the fittings for the same boost. This should give you smoother open/close of the mbc. Also make sure the surface the ball is pressing against inside the fitting is clean and smooth. If it's dinged up or rough at all use a tapered honing stone (like the ones you use in a dremmel tool) to clean it up, or better yet, jsut go back to the hardware store and buy one that has a nice clean finish inside.
more_toys is offline   Reply With Quote
Old 05-24-2006, 08:31 PM   #10 (permalink)
10psi of fury...
pressure regulators work good too... but I notice some spiking in third and fourth gear!
immoble is offline   Reply With Quote
Old 05-24-2006, 08:54 PM   #11 (permalink)
utahnissans.com
Feedback Score: 53 reviews
Buy a Hallman Pro?
Old 05-24-2006, 11:48 PM   #12 (permalink)
Iv got an apexi avcr, but thanks
Just wanted a feel for the car at higher boost before putting the avcr in. Im thinking about selling the car and dont want to put the avcr in unless I decide to keep it.. If that makes sense lol
Old 06-28-2006, 02:13 AM   #13 (permalink)
Feedback Score: 15 reviews
can't find the ball bearing anywhere where i live
-Richard
06 Subaru Wrx Sti
95 Civic EG Hatch(daily driver)
02 Civic EX------FOR SALE
95 200sx se-r-----FOR SALE
91 se-r--------R.I.P.(hurricane katrina killed it)
91 maxima se i/h/e
StreetSentra is offline   Reply With Quote
Old 06-28-2006, 03:42 AM   #14 (permalink)
Not sure bout others, but I found it didnt work very well anyways in my gtir.. Real bad spike, then back down to standard boost...
Old 12-17-2007, 01:30 PM   #15 (permalink)
how much will it let you boost???
lunaticracer21 is offline   Reply With Quote
HTML code is On
