Go Back   SR20 Forum > What's New > Technical Information Library > Turbo Guides
Old 09-13-2004, 01:51 AM   #1 (permalink)
sr20boston
1998ccs of fury
Trader Rating: 15 (100%)
The long lost T25/T28 parts list thread
Note: This thread originally was online, but was mistakenly deleted. Old backups were used to get it back, but it had to be manually copied-and-pasted here.
Original thread started by Ben.
After doing much research, this is what I have found that will work well for those of you bolting a T25 or T28 setup to your originally naturally aspirated SR20DE.
Starting at the block where the stock oil pressure sending unit for the dash idiot light is:
1. http://www.nissport.com/catalog/prod...EquipmentType=
This goes in place of the oil pressure sending unit into the block. The stock sender fits in the female end of this piece (not seen because it is sitting on that end), and there are three 1/8" NPT female ports used to connect your feed line and other items, such as an oil pressure gauge sending unit or oil temp sending unit. $49.00
2. http://www.sr20deforum.com/showthrea...threadid=35577
.060" oil restrictor. This is to ensure the proper amount of oil is getting to your T25. Unrestricted oil flow will blow through the turbo oil seals and coat the insides of your intercooler pipes. It has 1/8" NPT threads will fit into the nissport adapter. $15.00
3. http://www.anplumbing.com : -3 steel NPT male (P/N 961603)
This is to fit the straight end of the braided line into the oil restrictor. $1.24
4. http://www.anplumbing.com : -3 steel braided 44” brakeline (P/N 63011744)
This is the line itself. It has -3AN female ends on it. One end is straight, the other is a curved 90 degree piece. $26.08
5. http://www.anplumbing.com : -3AN to 7/16-20 brake adapter (P/N 591932) edit comments from myprojectB13 - "The correct size is a -3 AN to 7/16-24. It is part #591932, but AN Plumbing has it listed as a 7/16-20 on their site."
This is to fit the 90 degree angle end of the above braided line into your T25. $7.31
TOTAL COST: $98.63
Thanks to SERPrise in WV, myprojectB13, and the folks at nissport.com for adding to this article.
Old 09-13-2004, 01:53 AM   #2 (permalink)
sr20boston
1998ccs of fury
Originally posted by HotshtSR20
i would run a restrictor anyway, otherwise your turbo will be hogging a lot of oil pressure that could be lubing those fragile bearings. better safe than sorry, especially considering your turbo doesnt need jack sh*t for oil pressure.
on a 3 way tee, i would plug the feed into the middle one, and the oil pressure sending unit and restrictor on opposing sides. that way, the turbo and oil pressure gauge get the same readings. if you put the feed and turbo opposite each other, oil will shoot from one to the other without giving you an accurate reading.
Old 05-18-2007, 03:54 AM   #3 (permalink)
skeeter149
Tryin' To Be Like You
not to bring up a old thread but i used this and another to just now order the water and turbo feed lines. well on the turbo feed lines should i use teflon tape to seal them. like on the line to nissport adapter or in my case restrictor to adapter and line to adapter? well thanks..
Originally Posted by Shawn B
Purple monkey Fritos elbow dishwasher cigarette can-opener!
Acorn lug-wrench carpet vibrator Gatorade?!?
i am about to make that my sig shawn if you will allow it?
hell i did it so if you want me to i can get rid of it but i thought it was hella funny
skeeter149 is offline   Reply With Quote
Old 05-18-2007, 04:19 AM   #4 (permalink)
TeKKiE
work in progress...
Trader Rating: 26 (100%)
I would imagine that using teflon tape wouldn't hurt anything.
SR20DEEP in TX
Old 06-04-2007, 01:14 PM   #5 (permalink)
classicaddict
this foreum= FAIL
ok, i am getting a stock t28 setup soon TMIC and all. however i am replacing all the lines. i have bought all the parts to make my feed line minus the stainless line, i am unclear on how long it needs to be. in this thread it says 3.5 feet (44 inches) i have read else were "for a stock setup you dont need anymore than 12 inches." thats a massive differance and i dont want to end up with a crap load of extra hose i need to stuff inside my engine bay.
also, i have not found much at all about the oil return and water feed/return lines. for the oil drain, does it just drain directly into the oil pan? what parts will i need for the drain line and water lines?
THIS FORUM HAS BEEN AROUND SINCE 2000........TRUST ME WHEN I SAY YOUR QUESTION HAS ALREADY BEEN ASKED. SEARCH BEFORE YOU POST....PLEASE
please read this link to expand on above.
Old 06-04-2007, 03:39 PM   #6 (permalink)
boostednx
addicted to boost
you have to drill the block for the return line and the oil feed line is pretty long it has to go around the whole motor i dont really know where the water lines come from but i will check for you later
INFAMOUS PERFORMANCE
boostednx is offline   Reply With Quote
Old 06-04-2007, 05:30 PM   #7 (permalink)
jen36
Im Not A Chick
ohhhh ok. so even *** i bought a nissport adaptor i still need to drill the block. got ya
damnit, this is classicaddict sorry.
jen36 is online now   Reply With Quote
Old 07-22-2007, 01:19 AM   #8 (permalink)
squabzter
Trader Rating: 24 (100%)
Wait so where would the oil restrictor sit? and how many things can you hook up to the nissport adaptor? Could i run my pressur and temp gauge off of it?
93 NX2K---Boosted!
92 NX2K---stock and staying that way--loaned
99 G20 ---Comfy for everyday cruisin
squabzter is offline   Reply With Quote
Old 08-01-2007, 04:03 PM   #9 (permalink)
TeKKiE
work in progress...
Recommended that it sits on the turbine.
You can hook up a total of 4 items. 3 on the sides, and one on the top. (stock sending unit goes on top)
Old 08-12-2007, 12:10 PM   #10 (permalink)
squabzter
Thank you, but i looked on ATP turbo and all they have is the .065 restrictor does this work or am I not looking well enough?
Old 08-15-2007, 06:05 PM   #11 (permalink)
Mike I am a moderator
_______
Mike's Avatar
Trader Rating: 51 (100%)
This one? link
It should work just fine.
Mike
Mike is offline   Reply With Quote
Old 09-26-2007, 03:00 AM   #12 (permalink)
JuSt Ta GeT By
(S)(E)-(R)
So what would i need for and oil restrictor? Which one is for a t28?
JuSt Ta GeT By is offline   Reply With Quote
Old 02-04-2008, 11:29 PM   #13 (permalink)
Saml01
Heres a heads up, you cant put the restrictor near the turbine, there are no fittings available to make the necessary conversions from a 3an to the restrictor and back to the inlet fittings. I couldnt find a female/female 1/8npt to -3an adapter.
At the block fittings is the easiest.
Saml01 is offline   Reply With Quote
Old 02-28-2008, 11:44 AM   #14 (permalink)
ThaDude01
SE-R Sleeperzzz
ok...now what fittings do you need for the water lines? I just bought a t25 setup...the oil lines i figured out..I know where I can source the water lines...But do i use the stock water lines or get some new ones? and if new ones are recommended, what type of lines and size? And also what size do you drill the block and then does anyone have part numbers and fitting sizes for the block tap and fitting for oil return?
ThaDude01 is offline   Reply With Quote
HTML code is On
