HOWTO: Make a pressure tester - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > Turbo Guides
Old 09-13-2004, 03:00 AM   #1 (permalink)
1998ccs of fury
Feedback Score: 19 reviews
Note: This thread originally was online, but was mistakenly deleted. Old backups were used to get it back, but it had to be manually copied-and-pasted here.
Original thread started by HotshtSR20.
buy a 2" PVC cap at home depot. it should be 2.5" OD.
buy some valve stems from Kragen, Pep Boys or Autozone (if going to Pep Boys or Autozone, make sure to pick up some ricey lights, wings and mufflers while there)
drill a hole the same size as the skinny part of the valve stem between to two rubber bumps.
add some RTV silicone to make sure its leak free.
hose clamp it onto the compressor inlet or inlet piping (try to clamp it onto something bead rolled, otherwise, it likes to shoot right off, dont ask me how i know) and pressurize until your boost gauge hits whatever max PSI you plan on hitting.
listen for leaks and fix them.
i like to unplug the BOV recirc pipe to see if the BOV is leaking.
Old 04-24-2005, 02:53 AM   #2 (permalink)
Wants Primera Race Motor
http://www.stealth316.com/2-pressuretester.htm
a site linked to me by a friend, and well in depth.
i was looking for something like this, since i had no pictures to go by, and i guess i ended buying the wrong thing but now i know what do exactly.
Brian
95 Black 200sx SE-R(totaled)
97 Teal 200sx SE-R(Sold)
12.5@ 114 boosted
295 whp 298 tq (street tuned)
303 whp 301 tq (dyno tuned)
01 Black G20t
04 GSXR 600
BlkB14 is offline   Reply With Quote
Old 05-31-2005, 11:32 AM   #3 (permalink)
Master Cunnilingust
Feedback Score: 37 reviews
It's probably cheaper to build your own, but if you don't want to mess with it, just buy a plumbing pressure tester at Home Depot.
- Rob
Old 11-10-2007, 03:26 PM   #4 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 109 reviews
It's THIS simple.
Old 11-12-2007, 03:02 PM   #5 (permalink)
officially a boost addict
Feedback Score: 10 reviews
this is a great tool takes like 15 mins to make... you can use any size cap also, depending on what silicone couplers you have laying around.
You can also put an air pressure reg after the ball valve to set the amount of pressure that is going into the piping.
http://www.sr20-forum.com/members-ri...ebs-build.html
U13 SR20DET, Turbonetics 60-1 hi fi .63 ar, Brian Crower Stage 2's, 520cc injectors, .3 bar fuel pressure, n62 maf, log manifold, Tial 38mm wastegate (9lb spring), 3" downpipe-3" VRS Exhaust, PLX Wideband, Calum basic ecu.
Balls to the wall until you see God, wait three seconds then hit the brakes...
nsusammyeb is offline   Reply With Quote
Old 08-12-2008, 05:00 PM   #6 (permalink)
Feedback Score: 40 reviews
Can somebody help me out with this? I don't understand the valve stem part? Wouldn't i want to buy a npt adapter? Can somebody post up some pic's? And maybe a better how to??
EDIT: I think I can figure it out looking at the linked up websites mixing and matching parts and using 2" instead of the 3" they are using in the stealth one.
91 SE-R: SR20DE (soon to be stock)
jonwepa is offline   Reply With Quote
Old 08-12-2008, 05:02 PM   #7 (permalink)
chriscar's Avatar
Skip the valve stem adapter. This pic is self-explanatory.
Old 01-26-2009, 09:02 PM   #8 (permalink)
chriscar's Avatar
Bump for fixed picture. Thanks Tekkie
Old 01-27-2009, 07:58 PM   #9 (permalink)
Done.
Feedback Score: 27 reviews
I panicked because I had this thread bookmarked, and couldn't see any pics! Thanks
SR20DEEP MD
05 Armada - Tow Truck
04 Subaru WRX 'goon
Cliff is offline   Reply With Quote
Old 05-12-2009, 12:02 PM   #10 (permalink)
slave to the grind
TOOQIKK's Avatar
Feedback Score: 33 reviews
gonna have to make one once i get my 2.3l gti-r motor built...hehe this is great!
94-XE 4D.... boost in the near future...stay tuned....
THE WEBSITE for all your synthetic oil and filter needs...AMSOIL First in Synthetics
Old 06-15-2009, 04:40 AM   #11 (permalink)
SLOW SE-R
... Use a soapy water solution and spray on all weld beads and silicone coupler/connectors and look for bubbles forming. If you have access to a nitrogen bottle and a GOOD regulator it would be a million times better. With plain air from a compressor or pump and high ambient temps the pressure will just rise even if you have a leak. Nitrogen on the other hand is not as sensitive to the heat.
97 B14 SE-R 5spd
00 Stillen Maxima
FS: FRESHLY Machined SR20-HP CylHead w/receipts. ALL NEW. ALL OEM + ValveJob. $200 shippd
FS:Auto/Trans + TQ Conv. FRM NO MOD 97 SE-R. GREAT COND. LOTS of life left. MAKE OFFER OR $145 shippd
WTB$:
1.SR CLUTCH+PP, Turbo MANI., SOLID MTR MNTS INSTALLD IN MNTS. Direct fit FMIC w/ piping, couplings, clamps. Injectors.
97SR20DE is offline   Reply With Quote
HTML code is On
