I'm a bit conused here. Which compressor housing do you use. The writeup says you have the T25 Compressor housing milled to fit the T28 Inducer. I presume you then replace the T25 Inducer with the T28 Inducer. However, everyones comments suggest one would use the T28 Compressor Housing.
Will you clarify?
Matthew "iNGEN" Woods
SweetPea has to go. 61k and clean as a whistle. Lots of extra parts including rebuilt turbo thrown in. PM me for details.
Will you clarify?
Yes you use the T25 compressor housing. Here ill give you a synopse
Items needed,
Full T28
Compressor Housing off a T25
Wastegate actuator from a T25
Take the T28, remove compressor housing. Take The T25 and remove its compressor housing. Have a machine shop machine the T25 comprssor housing so it fits over the T28's compressor wheel. Then bolt on the T25's machined compressor housing on the T28, along with the watesgate actuator and you avenir or bluebird j-pipe (one hole may need to be enlarged for fitment).
So basically your using a complete T28, just with a smaller compressor housing, so it clears the block with the bb/ avenir manifolds, and without spending alot on manifold, downpipe and j-pipe, like you would have to using the T28 straight out of the box.
Jonathan Schultz
1997 200SX SE-R U13 Swap
2005 Toyota Avalon Limited
Wouldn't it be cheaper and easier to just make adapter plates to bolt the T28 up to the T25 manifold and DP? I'm assuming not but I had to ask. If not what's the reason for that?
I've thought about this. Just some sort of angle adapter on the manfiold to kick the turbo an inch away from the block to make sure the turbo doesn't hit the block. Wonder if anyone has tried this.
'97 SE-R with BB T25 setup, G20 ECU, E-Manage, Starion FMIC, SPEC 6 puck stage 3 clutch, D2 coilovers, fully shaved doors including side molding, Royal Sapphire Pearl (Toyota Supra) paint, Halo headlights, Aerogear vented hood, 98 Sentra Grille, Vis Extreme front bumper, Andy's Autosport rear bumper, and Kenwood Excellon CD player (Formerly Raser-X's car) http://www.uwm.edu/~elh3/Pictures/20...rbocharger.jpg
Sorry for the late responce, I thought of that as well, but I dont like that idea. Something just doesnt seem like it would work right.
quick question.. what's the max boost you can run? i know max for a t25 is 15 so what's the max on this hybrid? the same?
I would say(im not responsible for any damage that may occur) that for brief runs, like the 1/4mile. 18 psi is as high as I would go. (Again, I hold no responsibility for any damage.)
I was planning on running mine at 18psi at the track with 50# injectors or GTiR's at 4Bar..
Missing my sr20 b14, but still showing some love. Possible new project when I return!
Old car: 1999 Sentra SE-L Turbo: USDM sr20de, t25 turbo, hot shot intercooler kit, BIG ass fmic, nismo fpr, autometer fp gauge/boost gauge, mbc set at stock boost for now! 7psi= more traction>11psi=less traction.
the car sure is fast cause i bought the car from tuned200! i have it set 11psi on low and 14psi on high on a dual mbc. it boost right after 3k and bam it hauls. good setup and i always get complement from the dsm guys how this thing is a beast!
I have just installed my T28/25 and yes it pulls hard all the way thru 6 - 7K (not like my old t25) but it doesn't really start pulling until just before 4k. My old t25 would start kicking about 3k and I got real used to that. Is there anyway to make my new one boost sooner? I've got a mbc and it's set to 11 psi if that makes any difference.
If you had an EBC, such as an Apex'I AVC-R you could tune the wastegate duty cycle to be hyperactive at lower RPMs and "encourage" it to spool faster. With a manual BC, there may not be a suitable alternative.
You're in Arab? My girlfriend goes to Snead State, and I'm down there all the time for her softball games. Maybe we should get together? There's about 5 of us holding down Madison County. Hit me up!
///Harry
**EDIT - I think Pat should mill these and sell 'em - I'd be down for AT LEAST one **
