Rear Diff ratio's s14 vs gtir - SR20 Forum
post #1 of 25 (permalink) Old 02-27-2006, 08:11 AM Thread Starter
N14 Sr20ve + T
derm's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hi
Maybe one of you guys can tell me what the diff ratio is, of a GTir rear diff compared and a s14 rear diff
N14 chassis @ 11.57 120.24mph
derm is offline
post #2 of 25 (permalink) Old 02-27-2006, 02:04 PM
Quoted: 0 Post(s)
Sorry, I don't know, but the diff off the gti-r is a 190mm ring gear diff and a s14 is a 200mm. I think I read this somewhere, but am not sure. Correct me if I am wrong, the s14 uses a r200 diff and the gti-r uses a h190. Don't take my word for it. Do soem research and let us know
"A couple of Nissan Sr20's will pull a premium one week before race wars." (Johnny Tran, fast and furious) LOL
420sxDET is offline
post #3 of 25 (permalink) Old 02-27-2006, 04:39 PM Thread Starter
N14 Sr20ve + T
derm's Avatar
Quoted: 0 Post(s)
(Thread Starter)
the gtir diff is 181mm and the s14 is 200mm the ratio on the gtir is 3.7 and the ratio on the r200 is 3.692 good for goverment purposes
Thanx anyway
derm is offline
post #4 of 25 (permalink) Old 02-27-2006, 06:42 PM
Import Tech.
Quoted: 0 Post(s)
The front ratio on the GTi-R is 4.125 so I would think the rear has to be the same , unless they chage it in the transfercase gearing ....I guess it may depend on the years ...
SHAWN
Ger-Brock Performance
Portland OR.
'98 Sentra SE.. Time Attack
'06 Pathfinder SE
'93 Infiniti G20 5spd.
My Nissan Site !!
SHAWNATGERBROCK is offline
post #5 of 25 (permalink) Old 02-27-2006, 06:49 PM
Jah Rastafari
Quoted: 0 Post(s)
Feedback Score: 61 reviews
GTIR has a R180
S14 has a R200, diff ratios are 4.44 and 4.11
You can get a 3.90 diff in a Infiniti J30
Andreas Miko is offline
post #6 of 25 (permalink) Old 02-28-2006, 01:12 AM
Quoted: 0 Post(s)
I think that sounds a little better for teh s14 ratio. 3.692 was a little low
420sxDET is offline
post #7 of 25 (permalink) Old 02-28-2006, 02:41 AM Thread Starter
N14 Sr20ve + T
derm's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Now I am confused.
What is the stock gtir front diff ratio and the rear diff ratio?
As I had it it was 3.7 front and the same rear
derm is offline
post #8 of 25 (permalink) Old 02-28-2006, 09:31 AM
I like the boost!
Quoted: 0 Post(s)
The GTi-R uses a 3.70 rear diff and 4.125 front diff the transfercase is a reducer. It was done primarily to reduce driveshaft speed.
turboAZ2 is offline
post #9 of 25 (permalink) Old 02-28-2006, 02:35 PM Thread Starter
N14 Sr20ve + T
derm's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Thanx this make sense.
I tested the front diff and it boils down to 3.7 to 1. That's now through the transfercase.
Now the big question:
If I use the rear diff of the s14 that have a ratio of 3.692
The difference is 0.216%
In other words the rear diff will turn 0.21% faster than the front one. Will this be the end of the world
Will the visco over work?
derm is offline
post #10 of 25 (permalink) Old 02-28-2006, 08:00 PM
Import Tech.
Quoted: 0 Post(s)
Figure out a tire diameter difference that will make them come out the same ...
SHAWN
Portland OR.
'06 Pathfinder SE
My Nissan Site !!
post #11 of 25 (permalink) Old 02-28-2006, 09:06 PM
SE-R Geek / Nissan Tech
Quoted: 0 Post(s)
Feedback Score: 3 reviews
^^^until the tires wear down unevenly, and the angle drive starts spittin oil all over your driveway. if you swap, you hafta swap the front too, to the same front~rear reduction ratio as stock, or you'll just make a big, expensive mess. we had a volvo customer last week that had new tires on the rear, and worn ones on the front, and now he needs a new angle drive. this tells us that even the difference of a few millimeters between the two will do great damage to the mechanical components, such as differentials, transmissions, angle drives/t-cases, and deiveshafts. nissan spent the money on the engineering to make it work. a resource most of us dont have.
92 SE-R Autocrosser "BRE" tribute
71 MGB GT "The Great Pumpkin"
07 Frontier SE Nismo
BRE92SER is offline
post #12 of 25 (permalink) Old 05-22-2006, 09:15 AM
The Fast One
Quoted: 0 Post(s)
Feedback Score: 12 reviews
so does any US nissan rwd rearend match or work with a gti-r tranny or is the gti-r rearend the only one? Does any aftermarket place make gears for the 240 rearend?
http://www.sr20forum.com/members-rides/124356-gti-r-swap-done.html
Go figure the only sr20 in afghanistan is the x-trail sr20vet
se200 is offline
post #13 of 25 (permalink) Old 05-23-2006, 12:16 AM
No more SR :(
Quoted: 0 Post(s)
Feedback Score: 8 reviews
Originally Posted by Andreas Miko
GTIR has a R180
S14 has an R200 or R200V
USDM cars have 4.083
JDM has 4.083 (N/a) or 3.692 (Turbo)
EDM has 3.692 (All Turbo)
No such gear as a 4.44 (might be thinking of a 4.36 (S13 Silvia), and the 4.11 is found in the Skylines (ECR33 / BNR32 etc.)
95 BMW M3
217 HP / 204 TQ.
Nismo_Freak is offline
post #14 of 25 (permalink) Old 05-23-2006, 12:18 AM
No more SR :(
Quoted: 0 Post(s)
Not at the moment. You can always have one made but it isn't cheap.
Besides why are you wanting to run a RWD differential with a GTiR gearbox? Wouldn't it just be easier to find a GTiR part-out?
95 BMW M3
217 HP / 204 TQ.
post #15 of 25 (permalink) Old 05-23-2006, 03:12 AM
Enemy of the stupid
Quoted: 0 Post(s)
Feedback Score: 9 reviews
No the BNR32 GTS rear diff is higher than 4.11. Been discused many times in the RB fourms.
91 NX2000 VE forsale
Protech-Fabrication
http://www.OSRdyno.com/
Yellow4g63 is offline
post #16 of 25 (permalink) Old 05-24-2006, 09:24 PM
No more SR :(
Quoted: 0 Post(s)
A BNR32 is an R32 GTR... an HCR32 is a GTS-t, two very different cars.
95 BMW M3
217 HP / 204 TQ.
post #17 of 25 (permalink) Old 05-24-2006, 10:03 PM
Enemy of the stupid
Quoted: 0 Post(s)
Opps ment to say HCR32 my jdm is kinda stale.
Protech-Fabrication
post #18 of 25 (permalink) Old 05-25-2006, 01:36 PM
Quoted: 0 Post(s)
Be surprised if you saw that issue with the Nissan diff. The GM sourced differentials have VERY suseptale to tyre wear differances. The Vauxhall(Opel) Calibra my Dad has warns you in the hand book not to have the tyres more than 3mm different for tyre wear front to rear. I believe the Volvos use the same system. This isn't an issue with the GTIR or any other "true" 4WD system I know of.
Mind you I still don't think that I'd change the ratio front to back - what would be the point?
Cris is offline
post #19 of 25 (permalink) Old 05-25-2006, 08:09 PM
No more SR :(
Quoted: 0 Post(s)
Hehhe... the HCR32 uses a 4.30 or 4.36 gear ratio if I recall correctly.
95 BMW M3
217 HP / 204 TQ.
post #20 of 25 (permalink) Old 05-25-2006, 08:16 PM
The Fast One
Quoted: 0 Post(s)
yeah I found a gti-r full rearend so I'm just gonna go with it.
http://www.sr20forum.com/showthread.php?t=124356
se200 is offline
  SR20 Forum > Main Forums > Turbo
User Tag List
