Sludge can be from just not changing the oil enough, I can cean it out really well before install and throw some new bearings in it. Plus it has a slush box on it, so it may not have been reved enough, so oiling on the topend wasnt as good as it should have been.
i bought my setup from these guys... my motor was extremely clean inside... i got all that except the downpipe shown.... i paid 1099 for mine.... the motor works great too and so do the ECU and MAF...
2001 Wolfsburg Jetta w/ CAI, Full 3" Exhaust, Greddy Type-S, Forge TIP, FMIC, Prothane Dog Bone Mounts, & Unitronic Stage 2 Reflash... All That = FUN
Latest Dyno: 225whp & 276whtq before adding the Unitronic Stage 2, FMIC & Forge TIP...
yeh, thats what we plan on doing. We bought a JWT ECU for it, but I want to get a baseline for a stock motor, you know? Plus the JWT ECU is programed for 72lb injectors and a 300zx MAF.
make sure u change the bearings and so on...not a bad dig at all
Originally Posted by paNX2K&SE-R
So what ever happened with this? Did the motor work out for you?
