Standard O2 sensor - SR20 Forum
Old 05-17-2006, 04:39 PM   #1 (permalink)
Standard O2 sensor
i was wondering if a standard N/A O2 sensor can work with the turbo charged ECUs without a problem
The Harder They Come The Faster They FALL
Nissan is King is offline   Reply With Quote
Old 05-19-2006, 03:22 PM   #2 (permalink)
The voltage suppose to be the same i am going to give it a try
Old 05-19-2006, 06:19 PM   #3 (permalink)
Nissan Mut Car...
Feedback Score: 8 reviews
You need the o2 sensor to match your ecu. so if you have the usdm ecu, just a standard fat o2 sensor should work. If you have a jdm ecu, i believe you will need the long skinny type o2 sensor.
But i would search just to make sure
Chris Gault
1995 B14 Turbo 200sx SE-R
"You might think your hot sh*t in a champaign glass, when your really just cold diarrhea in a Dixie cup...."
NaLLa8705 is offline   Reply With Quote
